MacBook Pro 13" 2022 M2 (A2338 EMC 8162) MacBook Pro 13" 2020 M1 (A2338 EMC 3578) MacBook Pro 13" 2020 (A2289 EMC 3456) MacBook Pro 13" 2020 (A2251 A2159 - EMC 3348) Macbook Pro 13" Retina Début 2019 (A1989 A2159) MacBook Pro 13" Mi 2018 (A1989 EMC 3214) MacBook Pro 13" Retina Mi 2017 (A1708 A1706) MacBook Pro 13" Retina Fin 2016 (A1708 A1706) MacBook Pro 13" Retina Début 2015 (A1502 - EMC 2835) MacBook Pro 13" Retina Mi 2014 (A1502 - EMC 2875) MacBook Pro 13" Retina Fin 2013 (A1502 - EMC 2678) MacBook Pro 13" Retina Début 2013 (A1425 - EMC 2672) MacBook Pro Retina 13" 2020 (A2338)MacBook Pro 13" Retina Fin 2012 (A1425 - EMC 2557) MacBook Pro 13" Unibody Mi 2012 (A1278 - EMC 2554) MacBook Pro 13" Unibody Fin 2011 (A1278 - EMC 2555) MacBook Pro 13" Unibody Début 2011 (A1278 - EMC 2419) MacBook Pro 13" Unibody Mi 2010 (A1278 - EMC 2351) MacBook Pro 13" Unibody Mi 2009 (A1278 - EMC 2326) MacBook Pro 13" Unibody Fin 2008 (A1278 - EMC 2254)Macbook Pro 14 pouces 2024 M4 Max (A3185) MacBook Pro 14 pouces 2024 M4 Pro (A3401) MacBook Pro 14 pouces 2024 M4 (A3112) Macbook Pro 14 pouces 2023 M3 Pro M3 Pro Max (A2992) Macbook Pro 14 pouces 2023 M3 (A2918) MacBook Pro 14 pouces 2023 M2 Pro M2 Max (A2779) MacBook Pro 14 pouces M1 Pro M1 Max 2021 (A2442)MacBook Pro 15" Retina Mi 2019 (A1990 - EMC 3359) MacBook Pro 15" Retina Mi 2018 (A1990 - EMC 3215) MacBook Pro 15" Retina Mi 2017 (A1707 - EMC 3162) MacBook Pro 15" Retina Fin 2016 (A1707 - EMC 3072) MacBook Pro 15" Retina Mi 2015 (A1398 - EMC 2909/2910) MacBook Pro 15" Retina Mi 2014 (A1398 - EMC 2876 & 2881) MacBook Pro 15" Retina fin 2013 (A1398 - EMC 2674 & 2745) MacBook Pro 15" Retina Début 2013 (A1398 - EMC 2673) MacBook Pro 15" Retina Mi 2012 (A1398 - EMC 2512) MacBook Pro 15" Unibody Mi 2012 (A1286 - EMC 2556)MacBook Pro 15" Unibody Fin 2011 (A1286 - EMC 2563) MacBook Pro 15" Unibody Début 2011 (A1286 - EMC 2353-1) MacBook Pro 15" Unibody Mi 2010 (A1286 - EMC 2353) MacBook Pro 15" Unibody Mi 2009 (A1286 - EMC 2324 & 2325) MacBook Pro 15" Unibody Début 2009 (A1286 - EMC 2255) MacBook Pro 15" Unibody Fin 2008 (A1286 - EMC 2255) MacBook Pro 15" Début 2008 (A1260 - EMC 2198) MacBook Pro 15" Mi/Fin 2007 (A1226 - EMC 2136) MacBook Pro 15" Fin 2006 (A1211 - EMC 2120) MacBook Pro 15" Original 2006 (A1150 - EMC 2101) -
Guide de réparation : Batterie Xiaomi Mi 11 Lite 5G
À la suite d’un choc, d’une chute ou simplement avec le temps, la batterie de votre Xiaomi Mi 11 Lite 5G peut perdre en efficacité. Vous pouvez remarquer une baisse notable de l’autonomie, des extinctions soudaines, ou un appareil qui chauffe anormalement. Dans certains cas, le téléphone peut ne plus tenir la charge, redémarrer en boucle ou afficher un pourcentage incohérent. Une batterie vieillissante peut également gonfler, entraînant des risques de sécurité et déformant parfois la coque.
Chez SOSav, nous savons que l’autonomie est essentielle pour une utilisation confortable au quotidien. Le Xiaomi Mi 11 Lite 5G est équipé d’une batterie Lithium-Polymère de 4250 mAh, compatible avec une charge rapide de 33W (Power Delivery 3.0 et Quick Charge 4). Remplacer entièrement l’appareil n’est pas nécessaire : le changement de la batterie est une solution fiable, économique et durable. Grâce à nos tutoriels détaillés, illustrés étape par étape, vous pouvez effectuer cette opération chez vous, même si vous êtes débutant.
Le remplacement de la batterie demande de retirer la coque arrière puis de déconnecter soigneusement les différents composants. Bien que la batterie soit collée, elle peut être retirée à l’aide d’un médiator et d’un peu de patience. Le tout s’effectue sans soudures, à condition d’utiliser les outils adaptés et de suivre les consignes à la lettre.
Pourquoi changer soi-même la batterie de son Mi 11 Lite 5G ?
Pour éviter des frais inutiles liés à une réparation en boutique, et prolonger la durée de vie de votre smartphone. Vous gagnez en autonomie et en fiabilité, tout en évitant les contraintes de l’envoi ou du remplacement de l’appareil complet. Réaliser la réparation soi-même, c’est aussi poser un geste écologique en réduisant les déchets électroniques.
Avant toute intervention, pensez à effectuer une sauvegarde complète de vos données pour éviter toute perte accidentelle.
Symptômes d’une batterie défectueuse :
- Autonomie fortement réduite
- Extinctions imprévues
- Temps de charge anormalement long
- Pourcentage de batterie instable ou erratique
- Échauffement inhabituel de l’appareil
- Batterie gonflée ou coque déformée
Le Xiaomi Mi 11 Lite 5G offre une bonne autonomie grâce à sa batterie 4250 mAh, et peut retrouver tout son potentiel après un remplacement effectué dans les règles de l’art. Associée à sa compatibilité avec la charge rapide 33W, une nouvelle batterie redonne à votre smartphone sa réactivité et son endurance d’origine.
Batterie compatible - Mi 11 Lite 4G et 5G 19.58€ 20.61€ Voir le produit visibility
Batterie (Officielle) - Mi 11 Lite 4G et 5G
55.49€ 58.41€
Outils requis
Décapeur thermique petit format 8.46€ 8.91€ Voir le produit visibility
Poche chauffante - Petit format
5.90€ 6.21€
Voir tous les outils
Pièces en option
Kit outils Spécial - N°1 7.61€ 8.01€ Voir le produit visibility
Comment remplacer batterie pour Xiaomi Mi 11 Lite 5G - Guide images
Pour cela, accédez aux paramètres de votre téléphone, dans la section "À propos de l’appareil", afin de consulter avec précision la référence exacte du produit.
Le guide que nous mettons à votre disposition ici s’applique uniquement aux modèles portant l’une des désignations suivantes : M2101K9G, M2101K9C ou M2101K9R.
Avant de commencer votre réparation, éteignez votre smartphone, et retirer le tiroir SIM avec l'outil prévu à cette effet. Vous retrouverez cet outil dans le kit outil spécial n°1 disponible en option.
Utilisez un sèche-cheveux ou un pistolet à air chaud pour appliquer de la chaleur sur les bords de la coque durant environ 30 secondes.
Si vous disposez d’un coussin chauffant, placez-le au micro-ondes pendant environ 2 minutes, puis appliquez-le sur la face arrière du téléphone pendant 40 secondes.
Une fois que vous avez chauffé la vitre arrière :
Insérer le médiator métallique ajouré entre la vitre et le cadre afin de créer un point d’ouverture.
Faire ensuite glisser les médiators rouges dans l’interstice, puis retirez le médiator en métal.
Faire tout le tour de la vitre arrière avec les médiators en plastique pour la décoller petit à petit.
Insérez le levier en plastique sous la carte mère pour l'extraire du châssis.
Déconnectez la nappe du lecteur SIM, attachée à la carte mère.
Retirez le composant avec la pince brucelles et mettez-le de côté.
Tirez la partie A pour sortir la batterie de son emplacement.
Récupérez le film transparent se trouvant dans le châssis et collez-le sur votre nouvelle batterie, sauf si elle a des stickers intégrés.
♻️ Pensez au recyclage ! Choisissez un point de collecte pour jeter votre batterie usagée.
Nettoyez le châssis et la vitre arrière des restes de colles ou de joint avant de poser un filet de colle sur tout le contour du téléphone.
Laissez sécher sous presse environ 30 minutes à l'aide de pinces ou de livres.
Retirez les résidus de colle en utilisant une lingette imbibée.
