MacBook Pro 13" 2022 M2 (A2338 EMC 8162) MacBook Pro 13" 2020 M1 (A2338 EMC 3578) MacBook Pro 13" 2020 (A2289 EMC 3456) MacBook Pro 13" 2020 (A2251 A2159 - EMC 3348) Macbook Pro 13" Retina Début 2019 (A1989 A2159) MacBook Pro 13" Mi 2018 (A1989 EMC 3214) MacBook Pro 13" Retina Mi 2017 (A1708 A1706) MacBook Pro 13" Retina Fin 2016 (A1708 A1706) MacBook Pro 13" Retina Début 2015 (A1502 - EMC 2835) MacBook Pro 13" Retina Mi 2014 (A1502 - EMC 2875) MacBook Pro 13" Retina Fin 2013 (A1502 - EMC 2678) MacBook Pro 13" Retina Début 2013 (A1425 - EMC 2672) MacBook Pro Retina 13" 2020 (A2338)MacBook Pro 13" Retina Fin 2012 (A1425 - EMC 2557) MacBook Pro 13" Unibody Mi 2012 (A1278 - EMC 2554) MacBook Pro 13" Unibody Fin 2011 (A1278 - EMC 2555) MacBook Pro 13" Unibody Début 2011 (A1278 - EMC 2419) MacBook Pro 13" Unibody Mi 2010 (A1278 - EMC 2351) MacBook Pro 13" Unibody Mi 2009 (A1278 - EMC 2326) MacBook Pro 13" Unibody Fin 2008 (A1278 - EMC 2254)Macbook Pro 14 pouces 2024 M4 Max (A3185) MacBook Pro 14 pouces 2024 M4 Pro (A3401) MacBook Pro 14 pouces 2024 M4 (A3112) Macbook Pro 14 pouces 2023 M3 Pro M3 Pro Max (A2992) Macbook Pro 14 pouces 2023 M3 (A2918) MacBook Pro 14 pouces 2023 M2 Pro M2 Max (A2779) MacBook Pro 14 pouces M1 Pro M1 Max 2021 (A2442)MacBook Pro 15" Retina Mi 2019 (A1990 - EMC 3359) MacBook Pro 15" Retina Mi 2018 (A1990 - EMC 3215) MacBook Pro 15" Retina Mi 2017 (A1707 - EMC 3162) MacBook Pro 15" Retina Fin 2016 (A1707 - EMC 3072) MacBook Pro 15" Retina Mi 2015 (A1398 - EMC 2909/2910) MacBook Pro 15" Retina Mi 2014 (A1398 - EMC 2876 & 2881) MacBook Pro 15" Retina fin 2013 (A1398 - EMC 2674 & 2745) MacBook Pro 15" Retina Début 2013 (A1398 - EMC 2673) MacBook Pro 15" Retina Mi 2012 (A1398 - EMC 2512) MacBook Pro 15" Unibody Mi 2012 (A1286 - EMC 2556)MacBook Pro 15" Unibody Fin 2011 (A1286 - EMC 2563) MacBook Pro 15" Unibody Début 2011 (A1286 - EMC 2353-1) MacBook Pro 15" Unibody Mi 2010 (A1286 - EMC 2353) MacBook Pro 15" Unibody Mi 2009 (A1286 - EMC 2324 & 2325) MacBook Pro 15" Unibody Début 2009 (A1286 - EMC 2255) MacBook Pro 15" Unibody Fin 2008 (A1286 - EMC 2255) MacBook Pro 15" Début 2008 (A1260 - EMC 2198) MacBook Pro 15" Mi/Fin 2007 (A1226 - EMC 2136) MacBook Pro 15" Fin 2006 (A1211 - EMC 2120) MacBook Pro 15" Original 2006 (A1150 - EMC 2101) -
Guide de réparation : Connecteur de charge Galaxy A71
Quand faut-il envisager de remplacer le port de charge de votre Galaxy A71 ?
Avec l’usage quotidien, le connecteur USB-C de votre Samsung Galaxy A71 peut s’user ou subir des dommages physiques. Vous pouvez constater plusieurs dysfonctionnements : impossibilité de charger l’appareil, déconnexion aléatoire, reconnaissance intermittente du câble ou transfert de données non fonctionnel. Même si le téléphone s’allume, un port abîmé peut nuire à son bon fonctionnement.
Le Galaxy A71 est doté d’un connecteur USB Type-C assurant la recharge rapide 25W et la synchronisation avec d’autres appareils. Ce composant est fortement sollicité et peut s’endommager avec le temps ou en cas de mauvaise manipulation. Remplacer ce module vous permet de restaurer une alimentation fiable et de retrouver un usage normal de votre appareil.
Chez SOSav, nous proposons des ports de charge neufs, compatibles et contrôlés, ainsi qu’un guide de réparation illustré et accessible à tous. Même sans formation technique, vous pouvez effectuer cette opération vous-même à l’aide de nos explications pas à pas.
Pourquoi changer soi-même le connecteur de charge du Galaxy A71 ?
Réparer cette pièce vous-même est un moyen rentable d’éviter une visite en centre de réparation ou le remplacement complet du téléphone. C’est aussi une démarche écoresponsable : prolonger la durée de vie de votre mobile permet de limiter les déchets électroniques.
Avant toute manipulation, sauvegardez vos données personnelles et éteignez totalement votre appareil.
Symptômes d’un connecteur de charge défectueux :
- Le câble ne tient plus correctement ou se débranche facilement
- Charge absente ou très lente malgré un chargeur fonctionnel
- Problèmes de transfert de données via USB
- Port endommagé, oxydé ou encrassé
- Obligation de positionner le câble dans un angle précis pour charger
Compatibilité et recommandations avant remplacement
Le Galaxy A71 est disponible en plusieurs variantes, dont SM-A715F et SM-A715F/DS. Avant de commander votre connecteur de remplacement, vérifiez cette information dans Paramètres > À propos du téléphone. Tous nos ports USB-C sont sélectionnés pour être compatibles avec ces modèles et peuvent être installés avec les outils en option proposés sur notre boutique.
Une fois le connecteur remplacé, votre Galaxy A71 pourra être rechargé efficacement et retrouvera toutes ses fonctions de connexion filaire.
Connecteur de charge (Officiel) - Galaxy A71 26.90€ Voir le produit visibility
Outils requis
Décapeur thermique petit format 8.91€ Voir le produit visibility
Poche chauffante - Petit format
6.21€
Voir tous les outils
Pièces en option
Kit outils Spécial - N°1 8.01€ Voir le produit visibility
Comment remplacer connecteur de charge pour Galaxy A71 - Guide images
Pour ce faire, rendez-vous dans les paramètres de votre appareil, puis ouvrez la section À propos du téléphone. Ou taper les numéros *#06# sur votre téléphone.
Le présent guide est spécifiquement conçu pour les modèles SM-A715F et SM-A715F/DS.
En cas de téléphone hors service, certains éléments visuels peuvent vous aider à l’identifier :
- Écran de grande taille avec poinçon centré pour la caméra frontale
- Module photo rectangulaire à l’arrière intégrant 4 capteurs
- Présence d’un port jack 3,5 mm
- Finition brillante typique de la gamme "Prism Crush"
Si vous avez un doute, notre équipe technique SOSav est à votre disposition pour vous aider à confirmer le modèle.
Une identification précise est indispensable pour réussir votre réparation et éviter les erreurs de compatibilité.
Une fois votre référence vérifiée : Éteignez votre smartphone.
Cet accessoire est inclus dans le kit outils spécial n°1, disponible en option sur notre boutique en ligne, conçu pour vous accompagner tout au long de votre réparation.
Si vous disposez d’un coussin chauffant, passez-le au micro-ondes pendant environ 2 minutes, puis appliquez-le sur la partie arrière du téléphone durant 40 secondes. Utilisez un sèche-cheveux ou un décapeur thermique pour diffuser de la chaleur sur les contours de la face arrière pendant environ 30 secondes.
Placez la ventouse sur la partie inférieure de la vitre arrière et tirez délicatement pour insérer le médiator en métal troué entre le verre et le châssis, vous allez créer un point d'insertion.
Insérez les médiators en plastique rouge et retirez le médiator en métal.
Retirer la vitre arrière. Retirer le joint usagé de votre vitre arrière. A la fin de notre réparation nous recollerons cette pièce.
A l'aide du levier en nylon, décollez délicatement les parties de la plaquette se trouvant de chaque coté de la batterie avant de déclipser l'intégralité du cache en plastique
Débranchez la nappe de l'écran.
Soulevez le connecteur de charge avec le levier en plastique orange et sortez-le du châssis.
♻️ Point recyclage ! Pensez à mettre votre dock de charge cassé dans le bac de tri approprié.
