MacBook Pro 13" 2022 M2 (A2338 EMC 8162) MacBook Pro 13" 2020 M1 (A2338 EMC 3578) MacBook Pro 13" 2020 (A2289 EMC 3456) MacBook Pro 13" 2020 (A2251 A2159 - EMC 3348) Macbook Pro 13" Retina Début 2019 (A1989 A2159) MacBook Pro 13" Mi 2018 (A1989 EMC 3214) MacBook Pro 13" Retina Mi 2017 (A1708 A1706) MacBook Pro 13" Retina Fin 2016 (A1708 A1706) MacBook Pro 13" Retina Début 2015 (A1502 - EMC 2835) MacBook Pro 13" Retina Mi 2014 (A1502 - EMC 2875) MacBook Pro 13" Retina Fin 2013 (A1502 - EMC 2678) MacBook Pro 13" Retina Début 2013 (A1425 - EMC 2672) MacBook Pro Retina 13" 2020 (A2338)MacBook Pro 13" Retina Fin 2012 (A1425 - EMC 2557) MacBook Pro 13" Unibody Mi 2012 (A1278 - EMC 2554) MacBook Pro 13" Unibody Fin 2011 (A1278 - EMC 2555) MacBook Pro 13" Unibody Début 2011 (A1278 - EMC 2419) MacBook Pro 13" Unibody Mi 2010 (A1278 - EMC 2351) MacBook Pro 13" Unibody Mi 2009 (A1278 - EMC 2326) MacBook Pro 13" Unibody Fin 2008 (A1278 - EMC 2254)Macbook Pro 14 pouces 2024 M4 Max (A3185) MacBook Pro 14 pouces 2024 M4 Pro (A3401) MacBook Pro 14 pouces 2024 M4 (A3112) Macbook Pro 14 pouces 2023 M3 Pro M3 Pro Max (A2992) Macbook Pro 14 pouces 2023 M3 (A2918) MacBook Pro 14 pouces 2023 M2 Pro M2 Max (A2779) MacBook Pro 14 pouces M1 Pro M1 Max 2021 (A2442)MacBook Pro 15" Retina Mi 2019 (A1990 - EMC 3359) MacBook Pro 15" Retina Mi 2018 (A1990 - EMC 3215) MacBook Pro 15" Retina Mi 2017 (A1707 - EMC 3162) MacBook Pro 15" Retina Fin 2016 (A1707 - EMC 3072) MacBook Pro 15" Retina Mi 2015 (A1398 - EMC 2909/2910) MacBook Pro 15" Retina Mi 2014 (A1398 - EMC 2876 & 2881) MacBook Pro 15" Retina fin 2013 (A1398 - EMC 2674 & 2745) MacBook Pro 15" Retina Début 2013 (A1398 - EMC 2673) MacBook Pro 15" Retina Mi 2012 (A1398 - EMC 2512) MacBook Pro 15" Unibody Mi 2012 (A1286 - EMC 2556)MacBook Pro 15" Unibody Fin 2011 (A1286 - EMC 2563) MacBook Pro 15" Unibody Début 2011 (A1286 - EMC 2353-1) MacBook Pro 15" Unibody Mi 2010 (A1286 - EMC 2353) MacBook Pro 15" Unibody Mi 2009 (A1286 - EMC 2324 & 2325) MacBook Pro 15" Unibody Début 2009 (A1286 - EMC 2255) MacBook Pro 15" Unibody Fin 2008 (A1286 - EMC 2255) MacBook Pro 15" Début 2008 (A1260 - EMC 2198) MacBook Pro 15" Mi/Fin 2007 (A1226 - EMC 2136) MacBook Pro 15" Fin 2006 (A1211 - EMC 2120) MacBook Pro 15" Original 2006 (A1150 - EMC 2101) -
Guide de réparation : Vitre arrière Galaxy A22 (5G)
Avec le temps ou après une chute, la vitre arrière de votre Galaxy A22 5G peut se fissurer, se rayer profondément ou se décoller partiellement. Même si cela n'affecte pas directement le fonctionnement du téléphone, une coque endommagée nuit à l'esthétique et peut compromettre l'étanchéité de l'appareil.
Chez SOSav, nous vous proposons une solution simple et abordable : remplacer uniquement la face arrière, sans changer tout le smartphone. Notre guide illustré vous accompagne pas à pas pour effectuer cette réparation vous-même, facilement et en toute sécurité.
Pourquoi remplacer soi-même la vitre arrière de son Galaxy A22 5G ?
Pour faire des économies, éviter une réparation coûteuse, et redonner un aspect neuf à votre téléphone.
C’est aussi un geste durable pour prolonger sa vie sans générer de déchets électroniques inutiles.
Conseil : Chauffez légèrement la coque avec un sèche-cheveux ou un coussin chauffant pour ramollir l’adhésif avant le retrait. Utilisez des outils adaptés comme une ventouse et un médiator pour éviter d’endommager les composants internes.
Kit outils Spécial - N°1 8.01€ Voir le produit visibility
Comment remplacer vitre arrière pour Galaxy A22 (5G) - Guide images
Pour cela, accédez aux paramètres de votre appareil, puis consultez la section "À propos du téléphone" pour confirmer le numéro de modèle exact.
Le guide que nous mettons à votre disposition concerne exclusivement la version SM-A226B.
N’oubliez pas d’éteindre complètement votre smartphone avant de débuter l’intervention, afin de garantir votre sécurité et préserver les composants internes. Une fois le téléphone éteint retirer le tiroir SIM avec l'outil prévu à cette effet.
Vous retrouverez cet outil dans le kit outil spécial n°1 disponible en option.
Utilisez un sèche-cheveux ou un décapeur thermique pour diffuser de la chaleur sur les contours de la face arrière pendant environ 30 secondes.
Si vous disposez d’un coussin chauffant, passez-le au micro-ondes pendant environ 2 minutes, puis appliquez-le sur la partie arrière du téléphone durant 40 secondes.
Placez la ventouse sur la partie inférieure de la vitre arrière et tirez délicatement pour insérer un médiator métallique troué entre le verre et le châssis, créant ainsi un point d’entrée.
Insérer les médiators en plastique rouge et retirez le médiator en métal.
Posez un léger filet de colle tout autour du châssis avant de mettre sous presse au moins une demi heure, à l'aide de pinces ou sous une pile de livres.
Ouvrez votre vitre arrière et mettez-la de côté
♻️ Pensez au recyclage : Ne jetez pas vos anciens composants, déposez-les dans un point de collecte agréé.
