MacBook Pro 13" 2022 M2 (A2338 EMC 8162) MacBook Pro 13" 2020 M1 (A2338 EMC 3578) MacBook Pro 13" 2020 (A2289 EMC 3456) MacBook Pro 13" 2020 (A2251 A2159 - EMC 3348) Macbook Pro 13" Retina Début 2019 (A1989 A2159) MacBook Pro 13" Mi 2018 (A1989 EMC 3214) MacBook Pro 13" Retina Mi 2017 (A1708 A1706) MacBook Pro 13" Retina Fin 2016 (A1708 A1706) MacBook Pro 13" Retina Début 2015 (A1502 - EMC 2835) MacBook Pro 13" Retina Mi 2014 (A1502 - EMC 2875) MacBook Pro 13" Retina Fin 2013 (A1502 - EMC 2678) MacBook Pro 13" Retina Début 2013 (A1425 - EMC 2672) MacBook Pro Retina 13" 2020 (A2338)MacBook Pro 13" Retina Fin 2012 (A1425 - EMC 2557) MacBook Pro 13" Unibody Mi 2012 (A1278 - EMC 2554) MacBook Pro 13" Unibody Fin 2011 (A1278 - EMC 2555) MacBook Pro 13" Unibody Début 2011 (A1278 - EMC 2419) MacBook Pro 13" Unibody Mi 2010 (A1278 - EMC 2351) MacBook Pro 13" Unibody Mi 2009 (A1278 - EMC 2326) MacBook Pro 13" Unibody Fin 2008 (A1278 - EMC 2254)Macbook Pro 14 pouces 2024 M4 Max (A3185) MacBook Pro 14 pouces 2024 M4 Pro (A3401) MacBook Pro 14 pouces 2024 M4 (A3112) Macbook Pro 14 pouces 2023 M3 Pro M3 Pro Max (A2992) Macbook Pro 14 pouces 2023 M3 (A2918) MacBook Pro 14 pouces 2023 M2 Pro M2 Max (A2779) MacBook Pro 14 pouces M1 Pro M1 Max 2021 (A2442)MacBook Pro 15" Retina Mi 2019 (A1990 - EMC 3359) MacBook Pro 15" Retina Mi 2018 (A1990 - EMC 3215) MacBook Pro 15" Retina Mi 2017 (A1707 - EMC 3162) MacBook Pro 15" Retina Fin 2016 (A1707 - EMC 3072) MacBook Pro 15" Retina Mi 2015 (A1398 - EMC 2909/2910) MacBook Pro 15" Retina Mi 2014 (A1398 - EMC 2876 & 2881) MacBook Pro 15" Retina fin 2013 (A1398 - EMC 2674 & 2745) MacBook Pro 15" Retina Début 2013 (A1398 - EMC 2673) MacBook Pro 15" Retina Mi 2012 (A1398 - EMC 2512) MacBook Pro 15" Unibody Mi 2012 (A1286 - EMC 2556)MacBook Pro 15" Unibody Fin 2011 (A1286 - EMC 2563) MacBook Pro 15" Unibody Début 2011 (A1286 - EMC 2353-1) MacBook Pro 15" Unibody Mi 2010 (A1286 - EMC 2353) MacBook Pro 15" Unibody Mi 2009 (A1286 - EMC 2324 & 2325) MacBook Pro 15" Unibody Début 2009 (A1286 - EMC 2255) MacBook Pro 15" Unibody Fin 2008 (A1286 - EMC 2255) MacBook Pro 15" Début 2008 (A1260 - EMC 2198) MacBook Pro 15" Mi/Fin 2007 (A1226 - EMC 2136) MacBook Pro 15" Fin 2006 (A1211 - EMC 2120) MacBook Pro 15" Original 2006 (A1150 - EMC 2101) -
Guide de réparation : Lecteur de cartouche, carte SD et prise jack Nintendo Switch OLED
Quand faut-il envisager de remplacer le module lecteur de cartouche / carte SD / prise jack de votre Nintendo Switch OLED ?
Avec une utilisation intensive ou suite à une chute, le connecteur multifonction de votre Nintendo Switch OLED peut présenter des signes de faiblesse. Un port défectueux peut entraîner une impossibilité de lire les jeux physiques, une carte microSD non reconnue ou l'absence de son lors de l'utilisation d’un casque filaire. Ces dysfonctionnements indiquent souvent un problème au niveau de ce composant essentiel.
La Switch OLED intègre un module combiné qui regroupe le lecteur de cartouches de jeu, le port microSD pour le stockage étendu, ainsi que la prise casque jack 3,5 mm. Si l'une de ces fonctions cesse de répondre correctement, le remplacement du module est recommandé pour garantir une expérience d’utilisation complète et sans compromis.
Chez SOSav, nous proposons des pièces de rechange vérifiées et compatibles, conformes aux spécifications d’origine de la Nintendo Switch OLED. Nos guides de réparation détaillés, avec photos et explications étape par étape, rendent l’intervention accessible même aux débutants.
Pourquoi remplacer vous-même ce module multifonction ?
Effectuer la réparation chez soi permet de faire d'importantes économies par rapport à une réparation professionnelle. C’est aussi un acte écoresponsable : plutôt que de remplacer toute la console pour un souci localisé, vous prolongez sa durée de vie en remplaçant uniquement la pièce défectueuse.
Pensez à éteindre complètement la console, à retirer les Joy-Con et à travailler sur une surface propre et bien éclairée avant toute opération.
Signes fréquents d’un module à remplacer :
- Les cartouches de jeu ne sont pas détectées
- La carte microSD n'est plus reconnue ou demande une réparation
- Le casque branché en jack ne produit aucun son
- Des faux contacts ou des coupures intermittentes lors de la lecture audio
- Erreurs système liées à la lecture de données externes
Compatibilité et identification du modèle
Ce module est spécialement conçu pour la Nintendo Switch OLED, identifiable par son écran OLED de 7 pouces, son support arrière orientable et son dock avec port Ethernet intégré. Assurez-vous d’avoir le bon modèle en consultant les paramètres système ou les indications inscrites au dos de votre console.
Une fois le composant remplacé, votre console retrouvera toutes ses fonctionnalités : lecture des jeux physiques, stockage externe via microSD et sortie audio par casque, pour une expérience fluide et complète.
Lecteur de cartes de jeux, micro SD et prise Jack - Nintendo Switch OLED 26.91€ Voir le produit visibility
Pièces en option
Kit d'outils pour Nintendo Switch 7.11€ Voir le produit visibility
Comment remplacer lecteur de cartouche, carte sd et prise jack pour Nintendo Switch OLED - Guide images
Dès réception de votre commande, installez-vous dans un environnement tranquille, munissez-vous des outils nécessaires, du gabarit de montage et de ce guide à portée de main avant de débuter l’intervention. Éteignez soigneusement la console, puis retirez toute cartouche de jeu ainsi que la carte microSD si elle est présente.
Appuyez sur les boutons avant de faire glisser les joy-cons hors de la console.
Faites basculer la plaquette vers la droite.
Glisser le câble coaxial sous les accroches.
Sortir la plaquette métallique du châssis.
Retirez le petit adhésif blanc à l'aide de la Brucelles pour découvrir la vis cachée.
Ôtez la vis avec le tournevis cruciforme.
Sortir l'élément composé du lecteur de cartouches, du lecteur de carte SD ainsi que la prise jack.
Vous avez terminé ! Reprenez ce tutoriel en sens inverse pour remonter votre console.
♻️Mettez votre composant défectueux dans le bac de recyclage approprié.
