MacBook Pro 13" 2022 M2 (A2338 EMC 8162) MacBook Pro 13" 2020 M1 (A2338 EMC 3578) MacBook Pro 13" 2020 (A2289 EMC 3456) MacBook Pro 13" 2020 (A2251 A2159 - EMC 3348) Macbook Pro 13" Retina Début 2019 (A1989 A2159) MacBook Pro 13" Mi 2018 (A1989 EMC 3214) MacBook Pro 13" Retina Mi 2017 (A1708 A1706) MacBook Pro 13" Retina Fin 2016 (A1708 A1706) MacBook Pro 13" Retina Début 2015 (A1502 - EMC 2835) MacBook Pro 13" Retina Mi 2014 (A1502 - EMC 2875) MacBook Pro 13" Retina Fin 2013 (A1502 - EMC 2678) MacBook Pro 13" Retina Début 2013 (A1425 - EMC 2672) MacBook Pro Retina 13" 2020 (A2338)MacBook Pro 13" Retina Fin 2012 (A1425 - EMC 2557) MacBook Pro 13" Unibody Mi 2012 (A1278 - EMC 2554) MacBook Pro 13" Unibody Fin 2011 (A1278 - EMC 2555) MacBook Pro 13" Unibody Début 2011 (A1278 - EMC 2419) MacBook Pro 13" Unibody Mi 2010 (A1278 - EMC 2351) MacBook Pro 13" Unibody Mi 2009 (A1278 - EMC 2326) MacBook Pro 13" Unibody Fin 2008 (A1278 - EMC 2254)Macbook Pro 14 pouces 2024 M4 Max (A3185) MacBook Pro 14 pouces 2024 M4 Pro (A3401) MacBook Pro 14 pouces 2024 M4 (A3112) Macbook Pro 14 pouces 2023 M3 Pro M3 Pro Max (A2992) Macbook Pro 14 pouces 2023 M3 (A2918) MacBook Pro 14 pouces 2023 M2 Pro M2 Max (A2779) MacBook Pro 14 pouces M1 Pro M1 Max 2021 (A2442)MacBook Pro 15" Retina Mi 2019 (A1990 - EMC 3359) MacBook Pro 15" Retina Mi 2018 (A1990 - EMC 3215) MacBook Pro 15" Retina Mi 2017 (A1707 - EMC 3162) MacBook Pro 15" Retina Fin 2016 (A1707 - EMC 3072) MacBook Pro 15" Retina Mi 2015 (A1398 - EMC 2909/2910) MacBook Pro 15" Retina Mi 2014 (A1398 - EMC 2876 & 2881) MacBook Pro 15" Retina fin 2013 (A1398 - EMC 2674 & 2745) MacBook Pro 15" Retina Début 2013 (A1398 - EMC 2673) MacBook Pro 15" Retina Mi 2012 (A1398 - EMC 2512) MacBook Pro 15" Unibody Mi 2012 (A1286 - EMC 2556)MacBook Pro 15" Unibody Fin 2011 (A1286 - EMC 2563) MacBook Pro 15" Unibody Début 2011 (A1286 - EMC 2353-1) MacBook Pro 15" Unibody Mi 2010 (A1286 - EMC 2353) MacBook Pro 15" Unibody Mi 2009 (A1286 - EMC 2324 & 2325) MacBook Pro 15" Unibody Début 2009 (A1286 - EMC 2255) MacBook Pro 15" Unibody Fin 2008 (A1286 - EMC 2255) MacBook Pro 15" Début 2008 (A1260 - EMC 2198) MacBook Pro 15" Mi/Fin 2007 (A1226 - EMC 2136) MacBook Pro 15" Fin 2006 (A1211 - EMC 2120) MacBook Pro 15" Original 2006 (A1150 - EMC 2101) -
Guide de réparation : Écran OLED complet Nintendo Switch OLED
Quand faut-il envisager de remplacer l’écran de votre Nintendo Switch OLED ?
Un choc, une chute ou une pression excessive peuvent entraîner des dommages visibles ou internes à l’écran de votre Nintendo Switch OLED. Même si la console reste allumée, plusieurs signes peuvent indiquer que l’écran est endommagé : absence d’affichage, scintillements, couleurs altérées, ou une surface tactile qui ne répond plus correctement. Des fissures sur la dalle ou des zones inactives peuvent rendre l’usage de la console difficile, voire impossible.
La Nintendo Switch OLED est équipée d’un écran OLED tactile capacitif de 7 pouces, avec une résolution de 1280 × 720 pixels en mode portable. L’image est transmise en 1080p via HDMI lorsque la console est placée sur son dock en mode téléviseur. Cette dalle OLED offre un contraste élevé et des couleurs vives, mais reste sensible aux chocs comme toute surface en verre. Le remplacement de l’écran est indispensable pour retrouver une expérience de jeu fluide et immersive.
Chez SOSav, nous mettons à votre disposition des écrans OLED de remplacement, testés et entièrement compatibles avec la Nintendo Switch OLED. Nos tutoriels détaillés et illustrés vous permettent de réaliser cette intervention vous-même, même sans compétences techniques préalables.
Pourquoi remplacer soi-même l’écran de la Switch OLED ?
Effectuer cette réparation vous-même permet de faire des économies importantes par rapport à une intervention en centre de service. C’est aussi une démarche responsable qui permet de prolonger la durée de vie de votre console tout en limitant le gaspillage électronique.
Pensez à sauvegarder vos données, éteindre la console et retirer les Joy-Con avant toute manipulation.
Signes courants d’un écran à remplacer :
- Fissures ou rayures profondes sur la dalle
- Écran noir ou absence d’image
- Tactile non réactif ou imprécis
- Affichage déformé, couleurs altérées ou taches sombres
- Lignes ou pixels défectueux à l’écran
Compatibilité et vérification du modèle
Cette pièce est conçue exclusivement pour le modèle Nintendo Switch OLED, identifiable par son écran de 7 pouces bord à bord, son support ajustable large à l’arrière, et son dock équipé d’un port Ethernet. Vérifiez cette information dans les paramètres de la console ou sur l’étiquette du produit avant de commander.
Une fois l’écran remplacé, vous retrouverez un affichage net, des couleurs intenses et une sensibilité tactile optimale, pour profiter à nouveau pleinement de vos sessions de jeu.
Ecran - Nintendo Switch OLED 143.91€ Voir le produit visibility
Pièces en option
Kit d'outils pour Nintendo Switch 7.11€ Voir le produit visibility
Comment changer écran oled complet pour Nintendo Switch OLED - Guide vidéo
Comment remplacer écran oled complet pour Nintendo Switch OLED - Guide images
Dès réception de votre commande, installez-vous dans un environnement tranquille, munissez-vous des outils nécessaires, du gabarit de montage et de ce guide à portée de main avant de débuter l’intervention. Éteignez soigneusement la console, puis retirez toute cartouche de jeu ainsi que la carte microSD si elle est présente.
Appuyez sur les boutons avant de faire glisser les joy-cons hors de la console.
Faites basculer la plaquette vers la droite.
Glisser le câble coaxial sous les accroches.
Sortir la plaquette métallique du châssis.
Retirez le petit adhésif blanc à l'aide de la Brucelles pour découvrir la vis cachée.
Ôtez la vis avec le tournevis cruciforme.
Sortir l'élément composé du lecteur de cartouches, du lecteur de carte SD ainsi que la prise jack.
Collez la ventouse sur l'écran près d'un bord.
Insérez le médiator en métal entre la vitre avant et le châssis.
Remplacez le médiator en métal par celui en plastique afin de continuer le décollage.
Nettoyez le châssis des résidus de colle à l'aide du levier en nylon.
Retirer le sticker de protection de l'arrière du nouvel écran.
Repliez la nappe de ce dernier afin de pouvoir plus facilement l'introduire dans le châssis lors du collage.
Laissez sécher la colle environ 45 minutes en disposant la console sous presse à l'aide de pinces ou de gros livres.
Remonter votre appareil en suivant les étapes dans le sens contraire.
Terminez par nettoyer l'écran de votre console à l'aide d'une lingette imbibée.
