MacBook Pro 13" 2022 M2 (A2338 EMC 8162) MacBook Pro 13" 2020 M1 (A2338 EMC 3578) MacBook Pro 13" 2020 (A2289 EMC 3456) MacBook Pro 13" 2020 (A2251 A2159 - EMC 3348) Macbook Pro 13" Retina Début 2019 (A1989 A2159) MacBook Pro 13" Mi 2018 (A1989 EMC 3214) MacBook Pro 13" Retina Mi 2017 (A1708 A1706) MacBook Pro 13" Retina Fin 2016 (A1708 A1706) MacBook Pro 13" Retina Début 2015 (A1502 - EMC 2835) MacBook Pro 13" Retina Mi 2014 (A1502 - EMC 2875) MacBook Pro 13" Retina Fin 2013 (A1502 - EMC 2678) MacBook Pro 13" Retina Début 2013 (A1425 - EMC 2672) MacBook Pro Retina 13" 2020 (A2338)MacBook Pro 13" Retina Fin 2012 (A1425 - EMC 2557) MacBook Pro 13" Unibody Mi 2012 (A1278 - EMC 2554) MacBook Pro 13" Unibody Fin 2011 (A1278 - EMC 2555) MacBook Pro 13" Unibody Début 2011 (A1278 - EMC 2419) MacBook Pro 13" Unibody Mi 2010 (A1278 - EMC 2351) MacBook Pro 13" Unibody Mi 2009 (A1278 - EMC 2326) MacBook Pro 13" Unibody Fin 2008 (A1278 - EMC 2254)Macbook Pro 14 pouces 2024 M4 Max (A3185) MacBook Pro 14 pouces 2024 M4 Pro (A3401) MacBook Pro 14 pouces 2024 M4 (A3112) Macbook Pro 14 pouces 2023 M3 Pro M3 Pro Max (A2992) Macbook Pro 14 pouces 2023 M3 (A2918) MacBook Pro 14 pouces 2023 M2 Pro M2 Max (A2779) MacBook Pro 14 pouces M1 Pro M1 Max 2021 (A2442)MacBook Pro 15" Retina Mi 2019 (A1990 - EMC 3359) MacBook Pro 15" Retina Mi 2018 (A1990 - EMC 3215) MacBook Pro 15" Retina Mi 2017 (A1707 - EMC 3162) MacBook Pro 15" Retina Fin 2016 (A1707 - EMC 3072) MacBook Pro 15" Retina Mi 2015 (A1398 - EMC 2909/2910) MacBook Pro 15" Retina Mi 2014 (A1398 - EMC 2876 & 2881) MacBook Pro 15" Retina fin 2013 (A1398 - EMC 2674 & 2745) MacBook Pro 15" Retina Début 2013 (A1398 - EMC 2673) MacBook Pro 15" Retina Mi 2012 (A1398 - EMC 2512) MacBook Pro 15" Unibody Mi 2012 (A1286 - EMC 2556)MacBook Pro 15" Unibody Fin 2011 (A1286 - EMC 2563) MacBook Pro 15" Unibody Début 2011 (A1286 - EMC 2353-1) MacBook Pro 15" Unibody Mi 2010 (A1286 - EMC 2353) MacBook Pro 15" Unibody Mi 2009 (A1286 - EMC 2324 & 2325) MacBook Pro 15" Unibody Début 2009 (A1286 - EMC 2255) MacBook Pro 15" Unibody Fin 2008 (A1286 - EMC 2255) MacBook Pro 15" Début 2008 (A1260 - EMC 2198) MacBook Pro 15" Mi/Fin 2007 (A1226 - EMC 2136) MacBook Pro 15" Fin 2006 (A1211 - EMC 2120) MacBook Pro 15" Original 2006 (A1150 - EMC 2101) -
Station de Micro-soudure portable AiXun T380
La station AiXun T380 vous offre la liberté d'intervenir n'importe où avec une efficacité professionnelle grâce à sa conception portable et autonome.
Station de Micro-soudure portable AiXun T380 pour remplacer les composants en micro-soudure
Voici la station qu'il vous faut pour réaliser vos micro-soudures de précision sur site ou en atelier. Conçue pour les composants les plus délicats comme les SMD ou CPU, elle vous accompagne dans toutes vos interventions grâce à sa batterie intégrée.
- Plage de température : 100 °C à 450 °C
- Puissance : 80 W
- Chauffe ultra-rapide : atteint 450 °C en moins d'une seconde
- Batterie : 18650 de 2600 mAh intégrée
- Autonomie : Jusqu’à 40 minutes d’utilisation continue à 400 °C
- Alimentation : Batterie ou secteur (110–230 V)
- Matériau : Boîtier en alliage d'aluminium
- Poids : Environ 1,2 kg
- Connectivité : Wi-Fi et Bluetooth pour mises à jour et commandes vocales
- Contenu du pack : Station T380, poignée T210, panne C210 K-tip, support de panne, câbles et manuel
Diagnostic
- Idéal pour la soudure de composants de surface (SMD)
- Permet la réparation de puces BGA ou CPU
- Indispensable pour les travaux de micro-soudure en déplacement
- Nécessaire pour intervenir sur des composants sensibles avec une chauffe stable et contrôlée
- Poignée T210 (incluse)
- Poignée T115 (non incluse)
Infos sur la réparation
Une réparation de micro-soudure est estimée entre 30 et 60 minutes selon le composant, et est classée Très difficile par nos techniciens. Retrouvez les outils nécessaires en option.
En achetant votre matériel chez SOSav, vous avez l'assurance d'un produit testé et vérifié par nos experts, couvert par une garantie de 2 ans. Basée en France, notre équipe expédie votre commande le jour même si elle est passée avant 14h et reste à votre écoute pour toute question.
- Fer à souder
