MacBook Pro 13" 2022 M2 (A2338 EMC 8162) MacBook Pro 13" 2020 M1 (A2338 EMC 3578) MacBook Pro 13" 2020 (A2289 EMC 3456) MacBook Pro 13" 2020 (A2251 A2159 - EMC 3348) Macbook Pro 13" Retina Début 2019 (A1989 A2159) MacBook Pro 13" Mi 2018 (A1989 EMC 3214) MacBook Pro 13" Retina Mi 2017 (A1708 A1706) MacBook Pro 13" Retina Fin 2016 (A1708 A1706) MacBook Pro 13" Retina Début 2015 (A1502 - EMC 2835) MacBook Pro 13" Retina Mi 2014 (A1502 - EMC 2875) MacBook Pro 13" Retina Fin 2013 (A1502 - EMC 2678) MacBook Pro 13" Retina Début 2013 (A1425 - EMC 2672) MacBook Pro Retina 13" 2020 (A2338)MacBook Pro 13" Retina Fin 2012 (A1425 - EMC 2557) MacBook Pro 13" Unibody Mi 2012 (A1278 - EMC 2554) MacBook Pro 13" Unibody Fin 2011 (A1278 - EMC 2555) MacBook Pro 13" Unibody Début 2011 (A1278 - EMC 2419) MacBook Pro 13" Unibody Mi 2010 (A1278 - EMC 2351) MacBook Pro 13" Unibody Mi 2009 (A1278 - EMC 2326) MacBook Pro 13" Unibody Fin 2008 (A1278 - EMC 2254)Macbook Pro 14 pouces 2024 M4 Max (A3185) MacBook Pro 14 pouces 2024 M4 Pro (A3401) MacBook Pro 14 pouces 2024 M4 (A3112) Macbook Pro 14 pouces 2023 M3 Pro M3 Pro Max (A2992) Macbook Pro 14 pouces 2023 M3 (A2918) MacBook Pro 14 pouces 2023 M2 Pro M2 Max (A2779) MacBook Pro 14 pouces M1 Pro M1 Max 2021 (A2442)MacBook Pro 15" Retina Mi 2019 (A1990 - EMC 3359) MacBook Pro 15" Retina Mi 2018 (A1990 - EMC 3215) MacBook Pro 15" Retina Mi 2017 (A1707 - EMC 3162) MacBook Pro 15" Retina Fin 2016 (A1707 - EMC 3072) MacBook Pro 15" Retina Mi 2015 (A1398 - EMC 2909/2910) MacBook Pro 15" Retina Mi 2014 (A1398 - EMC 2876 & 2881) MacBook Pro 15" Retina fin 2013 (A1398 - EMC 2674 & 2745) MacBook Pro 15" Retina Début 2013 (A1398 - EMC 2673) MacBook Pro 15" Retina Mi 2012 (A1398 - EMC 2512) MacBook Pro 15" Unibody Mi 2012 (A1286 - EMC 2556)MacBook Pro 15" Unibody Fin 2011 (A1286 - EMC 2563) MacBook Pro 15" Unibody Début 2011 (A1286 - EMC 2353-1) MacBook Pro 15" Unibody Mi 2010 (A1286 - EMC 2353) MacBook Pro 15" Unibody Mi 2009 (A1286 - EMC 2324 & 2325) MacBook Pro 15" Unibody Début 2009 (A1286 - EMC 2255) MacBook Pro 15" Unibody Fin 2008 (A1286 - EMC 2255) MacBook Pro 15" Début 2008 (A1260 - EMC 2198) MacBook Pro 15" Mi/Fin 2007 (A1226 - EMC 2136) MacBook Pro 15" Fin 2006 (A1211 - EMC 2120) MacBook Pro 15" Original 2006 (A1150 - EMC 2101) -
Guide de réparation : Démontage complet Galaxy Tab A9+
Le démontage complet de votre Samsung Galaxy Tab A9+ permet d'accéder à tous les composants de l'appareil pour les remplacer un par un. Que vous souhaitiez changer la batterie 7040 mAh, le connecteur USB-C, les quatre haut-parleurs stéréo, la carte mère ou l'écran de 11 pouces, cette procédure est la clé d'une réparation durable. En isolant chaque pièce, vous ciblez précisément la panne et restaurez les fonctions de votre tablette sans avoir à la remplacer.
Pourquoi réaliser soi-même la réparation de sa Galaxy Tab A9+ ?
Pour faire de belles économies, éviter les frais de main-d'œuvre et l'immobilisation prolongée de votre tablette en atelier. C'est aussi un geste pour la planète, qui permet de limiter les déchets électroniques.
Précaution importante : pensez à sauvegarder vos données personnelles avant la manipulation.
Bon à savoir : l'ouverture de la Galaxy Tab A9+ se fait par l'écran, qui est collé sur tout le pourtour du châssis. Cette étape demande de la patience et un chauffage progressif pour ne pas casser la dalle. Pensez à remplacer les adhésifs lors du remontage pour garantir une bonne étanchéité et un maintien optimal de l'écran.
- Écran cassé, fissuré ou décollé du châssis
- Tactile qui ne répond plus ou de façon aléatoire
- Affichage noir, bandes colorées ou pixels morts
- Fluidité 90 Hz qui ne fonctionne plus correctement
- Autonomie en chute libre ou batterie qui gonfle et déforme la tablette
- Extinctions inopinées malgré une charge restante
- Charge filaire 15W qui ne fonctionne plus correctement
- Faux contacts sur le port USB-C
- Un ou plusieurs des quatre haut-parleurs muets, grésillants ou saturés
- Photos floues ou capteur 8 Mpx hors service
- Caméra frontale 5 Mpx qui ne fonctionne plus
- Tablette qui ne reconnaît plus la carte microSD ou la carte SIM (version cellulaire)
- Ouverture : Décollage progressif de l'écran collé au châssis par chauffage.
- Sécurité : Déconnexion de la batterie et de la nappe écran pour éviter tout court-circuit.
- Extraction de l'énergie : Retrait de la batterie 7040 mAh.
- Audio gauche : Retrait des deux haut-parleurs situés du côté gauche.
- Protection : Retrait du cache connecteur de charge.
- Connexions : Retrait de la nappe principale.
- Partie basse : Retrait du connecteur de charge USB-C.
- Audio droite : Retrait des deux haut-parleurs situés du côté droit.
- SIM et stockage : Retrait du lecteur SIM / carte microSD.
- Remontage : Repose du lecteur SIM / carte SD, des haut-parleurs de droite, du connecteur de charge et de la nappe principale.
- Cœur du système : Remise en place de la carte mère (Snapdragon 695 5G).
- Audio et protection : Repose des haut-parleurs de gauche et de la plaquette de protection.
- Écran : Remise en place de la batterie et pose de l'écran avec adhésif neuf.
- Finalisation : Fermeture de la tablette après vérification de tous les branchements.
Kit outils Spécial - N°1 8.01€ Voir le produit visibility
Kit outils Pro - Android
11.61€
