Xiaomi Pad
MacBook Pro 13" 2022 M2 (A2338 EMC 8162) MacBook Pro 13" 2020 M1 (A2338 EMC 3578) MacBook Pro 13" 2020 (A2289 EMC 3456) MacBook Pro 13" 2020 (A2251 A2159 - EMC 3348) Macbook Pro 13" Retina Début 2019 (A1989 A2159) MacBook Pro 13" Mi 2018 (A1989 EMC 3214) MacBook Pro 13" Retina Mi 2017 (A1708 A1706) MacBook Pro 13" Retina Fin 2016 (A1708 A1706) MacBook Pro 13" Retina Début 2015 (A1502 - EMC 2835) MacBook Pro 13" Retina Mi 2014 (A1502 - EMC 2875) MacBook Pro 13" Retina Fin 2013 (A1502 - EMC 2678) MacBook Pro 13" Retina Début 2013 (A1425 - EMC 2672) MacBook Pro Retina 13" 2020 (A2338)MacBook Pro 13" Retina Fin 2012 (A1425 - EMC 2557) MacBook Pro 13" Unibody Mi 2012 (A1278 - EMC 2554) MacBook Pro 13" Unibody Fin 2011 (A1278 - EMC 2555) MacBook Pro 13" Unibody Début 2011 (A1278 - EMC 2419) MacBook Pro 13" Unibody Mi 2010 (A1278 - EMC 2351) MacBook Pro 13" Unibody Mi 2009 (A1278 - EMC 2326) MacBook Pro 13" Unibody Fin 2008 (A1278 - EMC 2254)Macbook Pro 14 pouces 2024 M4 Max (A3185) MacBook Pro 14 pouces 2024 M4 Pro (A3401) MacBook Pro 14 pouces 2024 M4 (A3112) Macbook Pro 14 pouces 2023 M3 Pro M3 Pro Max (A2992) Macbook Pro 14 pouces 2023 M3 (A2918) MacBook Pro 14 pouces 2023 M2 Pro M2 Max (A2779) MacBook Pro 14 pouces M1 Pro M1 Max 2021 (A2442)MacBook Pro 15" Retina Mi 2019 (A1990 - EMC 3359) MacBook Pro 15" Retina Mi 2018 (A1990 - EMC 3215) MacBook Pro 15" Retina Mi 2017 (A1707 - EMC 3162) MacBook Pro 15" Retina Fin 2016 (A1707 - EMC 3072) MacBook Pro 15" Retina Mi 2015 (A1398 - EMC 2909/2910) MacBook Pro 15" Retina Mi 2014 (A1398 - EMC 2876 & 2881) MacBook Pro 15" Retina fin 2013 (A1398 - EMC 2674 & 2745) MacBook Pro 15" Retina Début 2013 (A1398 - EMC 2673) MacBook Pro 15" Retina Mi 2012 (A1398 - EMC 2512) MacBook Pro 15" Unibody Mi 2012 (A1286 - EMC 2556)MacBook Pro 15" Unibody Fin 2011 (A1286 - EMC 2563) MacBook Pro 15" Unibody Début 2011 (A1286 - EMC 2353-1) MacBook Pro 15" Unibody Mi 2010 (A1286 - EMC 2353) MacBook Pro 15" Unibody Mi 2009 (A1286 - EMC 2324 & 2325) MacBook Pro 15" Unibody Début 2009 (A1286 - EMC 2255) MacBook Pro 15" Unibody Fin 2008 (A1286 - EMC 2255) MacBook Pro 15" Début 2008 (A1260 - EMC 2198) MacBook Pro 15" Mi/Fin 2007 (A1226 - EMC 2136) MacBook Pro 15" Fin 2006 (A1211 - EMC 2120) MacBook Pro 15" Original 2006 (A1150 - EMC 2101) -
Guide de réparation : Bloc écran - Démontage complet Xiaomi Redmi 15C
Le démontage complet du Xiaomi Redmi 15C 4G permet d'accéder à tous les composants de l'appareil pour les remplacer un par un. Que vous souhaitiez changer la batterie 6000 mAh, le connecteur USB-C, le haut-parleur ou les modules caméras (50 Mpx principal et 8 Mpx frontal), cette procédure est la clé d'une réparation durable. En isolant chaque pièce, vous ciblez précisément la panne et restaurez les fonctions de votre mobile sans le remplacer.
Pourquoi réaliser soi-même la réparation de son Redmi 15C 4G ?
Pour faire de belles économies, éviter les frais de main-d'œuvre et l'immobilisation de votre appareil en atelier. C'est aussi un geste pour la planète, qui permet de limiter les déchets électroniques.
Précaution importante : pensez à sauvegarder vos données personnelles avant la manipulation.
Attention : le Redmi 15C 4G est certifié IP64. Pour conserver la protection contre la poussière et les éclaboussures, pensez à remplacer le joint d'étanchéité au remontage.
- Autonomie en chute libre ou batterie qui gonfle
- Extinctions inopinées malgré une charge restante
- Charge rapide 33W qui ne fonctionne plus
- Faux contacts sur le port USB-C ou OTG défaillant
- Photos floues ou autofocus capricieux sur le capteur 50 Mpx
- Caméra frontale 8 Mpx hors service
- Haut-parleur muet, grésillant ou saturé
- Vibreur défaillant
- Lecteur d'empreintes latéral qui ne répond plus
- Ouverture : Décollage de la vitre arrière (verre ou simili-cuir).
- Accès interne : Retrait du châssis intermédiaire.
- Extraction de l'énergie : Retrait de la batterie 6000 mAh.
- Connexions : Retrait de la nappe d'interconnexion et du câble coaxial.
- Audio : Retrait du haut-parleur externe.
- Partie basse : Retrait du connecteur de charge USB-C.
- Vibreur : Retrait du moteur de vibration.
- Modules photo : Démontage des caméras arrière (50 Mpx) et frontale (8 Mpx).
- Cœur du système : Retrait de la carte mère (Helio G81 Ultra).
- Audio interne : Retrait du haut-parleur interne.
- Finalisation : Remontage et fermeture du smartphone avec joint neuf.
Plusieurs pannes courantes peuvent justifier un démontage complet de votre Redmi 15C 4G. Une batterie qui s'épuise rapidement, qui se gonfle ou qui empêche le téléphone de s'allumer est l'une des raisons les plus fréquentes, surtout sur ce modèle équipé d'une grosse cellule de 6000 mAh. Un connecteur de charge USB-C abîmé peut rendre la recharge impossible ou empêcher la charge rapide 33W de fonctionner correctement. Un haut-parleur externe muet, qui grésille ou qui sature peut gâcher vos appels et la lecture multimédia. Enfin, les modules caméras peuvent rencontrer des problèmes après un choc : photos floues, application caméra qui ne s'ouvre plus, ou autofocus défaillant.
Avant tout, pour faire de belles économies. Pas besoin de racheter un téléphone neuf ni de payer une réparation coûteuse en boutique. En remplaçant vous-même la pièce défectueuse, vous évitez les frais de main-d'œuvre et l'immobilisation prolongée de votre appareil en atelier. Réparer plutôt que jeter, c'est aussi un geste pour la planète, qui permet de limiter les déchets électroniques.
Précaution importante : pensez à sauvegarder vos données personnelles pour éviter toute perte pendant la manipulation.
Attention : le Redmi 15C 4G est certifié IP64, ce qui implique la présence d'un joint d'étanchéité autour du châssis. Pour conserver la protection contre la poussière et les éclaboussures après la réparation, il est conseillé de remplacer ce joint lors du remontage.
- Autonomie en chute libre ou batterie qui gonfle déformant la coque arrière
- Extinctions inopinées malgré un niveau de charge restant
- Charge rapide 33W qui ne fonctionne plus correctement
- Difficultés à brancher le câble USB-C ou faux contacts répétés
- Téléphone qui ne reconnaît plus le chargeur ou les périphériques en OTG
- Photos floues ou autofocus défaillant sur le capteur 50 Mpx
- Application caméra qui plante ou ne s'ouvre pas
- Haut-parleur externe muet, grésillant ou volume anormalement faible
- Vibreur défaillant ou téléphone qui ne vibre plus lors des notifications
Le Redmi 15C 4G dispose d'une conception accessible qui facilite l'accès à ses composants internes : sa batterie XXL de 6000 mAh avec charge filaire 33W, son connecteur USB-C, son haut-parleur et ses modules caméras. Même si l'ouverture demande de la patience et de la minutie (notamment à cause de l'étanchéité IP64), remettre votre appareil en état avec des pièces de rechange de qualité vous permettra de retrouver un smartphone pleinement fonctionnel à moindre coût.
Pour remettre à neuf votre appareil ou accéder aux composants internes, voici l'ordre des étapes :
- Ouverture : Décollage de la vitre arrière (en verre ou simili-cuir selon la version).
- Accès interne : Retrait du châssis intermédiaire pour libérer les composants.
- Modules photo : Démontage des caméras arrière (50 Mpx) et de la caméra frontale (8 Mpx).
- Cœur du système : Retrait de la carte mère supportant le processeur Helio G81 Ultra.
- Remontage : Repose des composants internes et de la batterie.
- Finalisation : Remontage du châssis intermédiaire et fermeture du smartphone avec remplacement du joint d'étanchéité.
Kit outils Spécial - N°1 8.01€ Voir le produit visibility
