MacBook Pro 13" 2022 M2 (A2338 EMC 8162) MacBook Pro 13" 2020 M1 (A2338 EMC 3578) MacBook Pro 13" 2020 (A2289 EMC 3456) MacBook Pro 13" 2020 (A2251 A2159 - EMC 3348) Macbook Pro 13" Retina Début 2019 (A1989 A2159) MacBook Pro 13" Mi 2018 (A1989 EMC 3214) MacBook Pro 13" Retina Mi 2017 (A1708 A1706) MacBook Pro 13" Retina Fin 2016 (A1708 A1706) MacBook Pro 13" Retina Début 2015 (A1502 - EMC 2835) MacBook Pro 13" Retina Mi 2014 (A1502 - EMC 2875) MacBook Pro 13" Retina Fin 2013 (A1502 - EMC 2678) MacBook Pro 13" Retina Début 2013 (A1425 - EMC 2672) MacBook Pro Retina 13" 2020 (A2338)MacBook Pro 13" Retina Fin 2012 (A1425 - EMC 2557) MacBook Pro 13" Unibody Mi 2012 (A1278 - EMC 2554) MacBook Pro 13" Unibody Fin 2011 (A1278 - EMC 2555) MacBook Pro 13" Unibody Début 2011 (A1278 - EMC 2419) MacBook Pro 13" Unibody Mi 2010 (A1278 - EMC 2351) MacBook Pro 13" Unibody Mi 2009 (A1278 - EMC 2326) MacBook Pro 13" Unibody Fin 2008 (A1278 - EMC 2254)Macbook Pro 14 pouces 2024 M4 Max (A3185) MacBook Pro 14 pouces 2024 M4 Pro (A3401) MacBook Pro 14 pouces 2024 M4 (A3112) Macbook Pro 14 pouces 2023 M3 Pro M3 Pro Max (A2992) Macbook Pro 14 pouces 2023 M3 (A2918) MacBook Pro 14 pouces 2023 M2 Pro M2 Max (A2779) MacBook Pro 14 pouces M1 Pro M1 Max 2021 (A2442)MacBook Pro 15" Retina Mi 2019 (A1990 - EMC 3359) MacBook Pro 15" Retina Mi 2018 (A1990 - EMC 3215) MacBook Pro 15" Retina Mi 2017 (A1707 - EMC 3162) MacBook Pro 15" Retina Fin 2016 (A1707 - EMC 3072) MacBook Pro 15" Retina Mi 2015 (A1398 - EMC 2909/2910) MacBook Pro 15" Retina Mi 2014 (A1398 - EMC 2876 & 2881) MacBook Pro 15" Retina fin 2013 (A1398 - EMC 2674 & 2745) MacBook Pro 15" Retina Début 2013 (A1398 - EMC 2673) MacBook Pro 15" Retina Mi 2012 (A1398 - EMC 2512) MacBook Pro 15" Unibody Mi 2012 (A1286 - EMC 2556)MacBook Pro 15" Unibody Fin 2011 (A1286 - EMC 2563) MacBook Pro 15" Unibody Début 2011 (A1286 - EMC 2353-1) MacBook Pro 15" Unibody Mi 2010 (A1286 - EMC 2353) MacBook Pro 15" Unibody Mi 2009 (A1286 - EMC 2324 & 2325) MacBook Pro 15" Unibody Début 2009 (A1286 - EMC 2255) MacBook Pro 15" Unibody Fin 2008 (A1286 - EMC 2255) MacBook Pro 15" Début 2008 (A1260 - EMC 2198) MacBook Pro 15" Mi/Fin 2007 (A1226 - EMC 2136) MacBook Pro 15" Fin 2006 (A1211 - EMC 2120) MacBook Pro 15" Original 2006 (A1150 - EMC 2101) -
Guide de réparation : Bloc écran - Démontage complet Xiaomi Redmi 12C
Le démontage complet du Xiaomi Redmi 12C permet d'accéder à tous les composants de l'appareil pour les remplacer un par un : batterie 5000 mAh, connecteur microUSB, lecteur d'empreintes arrière, haut-parleurs ou modules caméras (50 Mpx principal et 5 Mpx frontal).
Bonne nouvelle : le Redmi 12C est particulièrement simple à ouvrir. Sa coque arrière en plastique se déclipse sans collage ni chauffage, ce qui rend l'accès aux composants internes bien plus facile que sur la plupart des smartphones actuels.
Pourquoi réaliser soi-même la réparation de son Redmi 12C ?
Pour faire de belles économies, éviter les frais de main-d'œuvre et l'immobilisation de votre appareil en atelier. C'est aussi un geste pour la planète, qui permet de limiter les déchets électroniques.
Précaution importante : pensez à sauvegarder vos données personnelles avant la manipulation.
- Batterie qui gonfle ou autonomie en chute libre
- Extinctions inopinées malgré une charge restante
- Faux contacts sur le port microUSB
- Photos floues ou autofocus défaillant sur le capteur 50 Mpx
- Caméra frontale 5 Mpx hors service
- Haut-parleur ou écouteur interne muet ou grésillant
- Vibreur défaillant
- Lecteur d'empreintes arrière qui ne répond plus
- Ouverture : Retrait de la coque arrière en plastique par simple déclipsage (sans collage).
- Cache supérieur : Retrait du cache supérieur avec le lecteur d'empreintes.
- Extraction de l'énergie : Déconnexion et retrait de la batterie 5000 mAh.
- Audio : Retrait du haut-parleur externe.
- Écran : Déconnexion de la petite nappe de l'écran.
- Câbles : Retrait du câble coaxial.
- Partie basse : Retrait du connecteur de charge microUSB.
- Modules photo : Retrait des caméras arrière (50 Mpx) et frontale (5 Mpx).
- Cœur du système : Retrait de la carte mère (Helio G85).
- Audio interne : Retrait de l'écouteur interne.
- Vibreur : Retrait du moteur de vibration.
- Finalisation : Remontage des composants internes, de la batterie, du lecteur d'empreintes et du cache supérieur, puis fermeture du smartphone.
Ecran complet LCD - Redmi 12C 31.41€ Voir le produit visibility
Batterie - Xiaomi Redmi 12C
17.01€
Outils requis
iSesamo (Spatule en métal) 8.01€ Voir le produit visibility
Décapeur thermique petit format
8.91€
Voir tous les outils
Pièces en option
Kit outils Spécial - N°4 7.11€ Voir le produit visibility
