MacBook Pro 13" 2022 M2 (A2338 EMC 8162) MacBook Pro 13" 2020 M1 (A2338 EMC 3578) MacBook Pro 13" 2020 (A2289 EMC 3456) MacBook Pro 13" 2020 (A2251 A2159 - EMC 3348) Macbook Pro 13" Retina Début 2019 (A1989 A2159) MacBook Pro 13" Mi 2018 (A1989 EMC 3214) MacBook Pro 13" Retina Mi 2017 (A1708 A1706) MacBook Pro 13" Retina Fin 2016 (A1708 A1706) MacBook Pro 13" Retina Début 2015 (A1502 - EMC 2835) MacBook Pro 13" Retina Mi 2014 (A1502 - EMC 2875) MacBook Pro 13" Retina Fin 2013 (A1502 - EMC 2678) MacBook Pro 13" Retina Début 2013 (A1425 - EMC 2672) MacBook Pro Retina 13" 2020 (A2338)MacBook Pro 13" Retina Fin 2012 (A1425 - EMC 2557) MacBook Pro 13" Unibody Mi 2012 (A1278 - EMC 2554) MacBook Pro 13" Unibody Fin 2011 (A1278 - EMC 2555) MacBook Pro 13" Unibody Début 2011 (A1278 - EMC 2419) MacBook Pro 13" Unibody Mi 2010 (A1278 - EMC 2351) MacBook Pro 13" Unibody Mi 2009 (A1278 - EMC 2326) MacBook Pro 13" Unibody Fin 2008 (A1278 - EMC 2254)Macbook Pro 14 pouces 2024 M4 Max (A3185) MacBook Pro 14 pouces 2024 M4 Pro (A3401) MacBook Pro 14 pouces 2024 M4 (A3112) Macbook Pro 14 pouces 2023 M3 Pro M3 Pro Max (A2992) Macbook Pro 14 pouces 2023 M3 (A2918) MacBook Pro 14 pouces 2023 M2 Pro M2 Max (A2779) MacBook Pro 14 pouces M1 Pro M1 Max 2021 (A2442)MacBook Pro 15" Retina Mi 2019 (A1990 - EMC 3359) MacBook Pro 15" Retina Mi 2018 (A1990 - EMC 3215) MacBook Pro 15" Retina Mi 2017 (A1707 - EMC 3162) MacBook Pro 15" Retina Fin 2016 (A1707 - EMC 3072) MacBook Pro 15" Retina Mi 2015 (A1398 - EMC 2909/2910) MacBook Pro 15" Retina Mi 2014 (A1398 - EMC 2876 & 2881) MacBook Pro 15" Retina fin 2013 (A1398 - EMC 2674 & 2745) MacBook Pro 15" Retina Début 2013 (A1398 - EMC 2673) MacBook Pro 15" Retina Mi 2012 (A1398 - EMC 2512) MacBook Pro 15" Unibody Mi 2012 (A1286 - EMC 2556)MacBook Pro 15" Unibody Fin 2011 (A1286 - EMC 2563) MacBook Pro 15" Unibody Début 2011 (A1286 - EMC 2353-1) MacBook Pro 15" Unibody Mi 2010 (A1286 - EMC 2353) MacBook Pro 15" Unibody Mi 2009 (A1286 - EMC 2324 & 2325) MacBook Pro 15" Unibody Début 2009 (A1286 - EMC 2255) MacBook Pro 15" Unibody Fin 2008 (A1286 - EMC 2255) MacBook Pro 15" Début 2008 (A1260 - EMC 2198) MacBook Pro 15" Mi/Fin 2007 (A1226 - EMC 2136) MacBook Pro 15" Fin 2006 (A1211 - EMC 2120) MacBook Pro 15" Original 2006 (A1150 - EMC 2101) -
Guide de réparation : Démontage complet Xiaomi 15
Le démontage complet du Xiaomi 15 permet d'accéder à tous les composants de l'appareil pour les remplacer un par un. Que vous souhaitiez changer la batterie officielle Si/C 5240 mAh, le connecteur USB-C 3.2, les haut-parleurs stéréo, la vitre arrière officielle, le bloc écran officiel ou le prestigieux module caméra Leica avec ses trois capteurs 50 Mpx, cette procédure est la clé d'une réparation durable. Retrouvez toutes les pièces détachées compatibles avec le Xiaomi 15 sur notre boutique. En isolant chaque pièce, vous ciblez précisément la panne et restaurez les fonctions de votre mobile sans le remplacer.
Pourquoi réaliser soi-même la réparation de son Xiaomi 15 ?
Pour faire de belles économies, éviter les frais de main-d'œuvre et l'immobilisation de votre appareil en atelier. C'est aussi un geste pour la planète, qui permet de limiter les déchets électroniques.
Précaution importante : pensez à sauvegarder vos données personnelles avant la manipulation.
Attention : le Xiaomi 15 est certifié IP68. Pour conserver la protection contre l'eau et la poussière, il est indispensable de remplacer les joints d'étanchéité et les stickers de batterie lors du remontage.
- Autonomie en chute libre ou batterie qui gonfle
- Extinctions inopinées malgré une charge restante
- Charge rapide 90W filaire ou 50W sans fil qui ne fonctionne plus
- Faux contacts sur le port USB-C ou OTG défaillant
- Photos floues ou OIS défaillant sur le capteur principal 50 Mpx
- Téléobjectif ou ultra grand-angle Leica hors service
- Caméra frontale 32 Mpx qui ne fonctionne plus
- Enregistrement vidéo 8K qui plante
- Haut-parleurs stéréo muets, grésillants ou saturés
- Écouteur interne défaillant lors des appels
- Vibreur défaillant
- Lecteur d'empreintes ultrasonique sous écran qui ne répond plus
- NFC ou infrarouge qui ne fonctionne plus
- Vitre arrière fissurée ou éclatée
- Ouverture : Retrait de la vitre arrière par chauffage progressif.
- Caches : Retrait du cache antenne NFC et de l'écouteur interne.
- Extraction de l'énergie : Déconnexion et retrait de la batterie officielle Si/C 5240 mAh.
- Câbles : Déconnexion des câbles coaxiaux.
- Audio : Retrait du haut-parleur externe.
- Partie basse : Retrait du connecteur de charge USB-C 3.2.
- Vibreur : Retrait du moteur de vibration.
- Connexions : Retrait de la nappe d'interconnexion.
- Modules photo et cœur du système : Retrait des caméras Leica (principal 50 Mpx, téléobjectif, ultra grand-angle) et de la carte mère (Snapdragon 8 Elite).
- Finalisation : Remontage des composants internes, pose de nouveaux stickers batterie et fermeture du smartphone avec joints d'étanchéité neufs.
Retrouvez toutes les pièces compatibles avec votre appareil sur la page Xiaomi 15 de la boutique SOSav, notamment la dalle officielle pour un remplacement d'écran, la batterie officielle et la vitre arrière officielle.
