MacBook Pro 13" 2022 M2 (A2338 EMC 8162) MacBook Pro 13" 2020 M1 (A2338 EMC 3578) MacBook Pro 13" 2020 (A2289 EMC 3456) MacBook Pro 13" 2020 (A2251 A2159 - EMC 3348) Macbook Pro 13" Retina Début 2019 (A1989 A2159) MacBook Pro 13" Mi 2018 (A1989 EMC 3214) MacBook Pro 13" Retina Mi 2017 (A1708 A1706) MacBook Pro 13" Retina Fin 2016 (A1708 A1706) MacBook Pro 13" Retina Début 2015 (A1502 - EMC 2835) MacBook Pro 13" Retina Mi 2014 (A1502 - EMC 2875) MacBook Pro 13" Retina Fin 2013 (A1502 - EMC 2678) MacBook Pro 13" Retina Début 2013 (A1425 - EMC 2672) MacBook Pro Retina 13" 2020 (A2338)MacBook Pro 13" Retina Fin 2012 (A1425 - EMC 2557) MacBook Pro 13" Unibody Mi 2012 (A1278 - EMC 2554) MacBook Pro 13" Unibody Fin 2011 (A1278 - EMC 2555) MacBook Pro 13" Unibody Début 2011 (A1278 - EMC 2419) MacBook Pro 13" Unibody Mi 2010 (A1278 - EMC 2351) MacBook Pro 13" Unibody Mi 2009 (A1278 - EMC 2326) MacBook Pro 13" Unibody Fin 2008 (A1278 - EMC 2254)Macbook Pro 14 pouces 2024 M4 Max (A3185) MacBook Pro 14 pouces 2024 M4 Pro (A3401) MacBook Pro 14 pouces 2024 M4 (A3112) Macbook Pro 14 pouces 2023 M3 Pro M3 Pro Max (A2992) Macbook Pro 14 pouces 2023 M3 (A2918) MacBook Pro 14 pouces 2023 M2 Pro M2 Max (A2779) MacBook Pro 14 pouces M1 Pro M1 Max 2021 (A2442)MacBook Pro 15" Retina Mi 2019 (A1990 - EMC 3359) MacBook Pro 15" Retina Mi 2018 (A1990 - EMC 3215) MacBook Pro 15" Retina Mi 2017 (A1707 - EMC 3162) MacBook Pro 15" Retina Fin 2016 (A1707 - EMC 3072) MacBook Pro 15" Retina Mi 2015 (A1398 - EMC 2909/2910) MacBook Pro 15" Retina Mi 2014 (A1398 - EMC 2876 & 2881) MacBook Pro 15" Retina fin 2013 (A1398 - EMC 2674 & 2745) MacBook Pro 15" Retina Début 2013 (A1398 - EMC 2673) MacBook Pro 15" Retina Mi 2012 (A1398 - EMC 2512) MacBook Pro 15" Unibody Mi 2012 (A1286 - EMC 2556)MacBook Pro 15" Unibody Fin 2011 (A1286 - EMC 2563) MacBook Pro 15" Unibody Début 2011 (A1286 - EMC 2353-1) MacBook Pro 15" Unibody Mi 2010 (A1286 - EMC 2353) MacBook Pro 15" Unibody Mi 2009 (A1286 - EMC 2324 & 2325) MacBook Pro 15" Unibody Début 2009 (A1286 - EMC 2255) MacBook Pro 15" Unibody Fin 2008 (A1286 - EMC 2255) MacBook Pro 15" Début 2008 (A1260 - EMC 2198) MacBook Pro 15" Mi/Fin 2007 (A1226 - EMC 2136) MacBook Pro 15" Fin 2006 (A1211 - EMC 2120) MacBook Pro 15" Original 2006 (A1150 - EMC 2101) -
Guide de réparation : Démontage complet - Bloc écran Xiaomi Redmi 10C
Le démontage complet du Xiaomi Redmi 10C permet d'accéder à tous les composants de l'appareil pour les remplacer un par un. Que vous souhaitiez changer la batterie 5000 mAh, le connecteur USB-C, le lecteur d'empreintes arrière, les haut-parleurs ou les modules caméras (50 Mpx principal et 5 Mpx frontal), cette procédure est la clé d'une réparation durable. En isolant chaque pièce, vous ciblez précisément la panne et restaurez les fonctions de votre mobile sans le remplacer.
Bonne nouvelle : le Redmi 10C est particulièrement simple à ouvrir. Sa coque arrière en plastique se déclipse sans collage ni chauffage, ce qui rend l'accès aux composants internes bien plus facile que sur la plupart des smartphones actuels.
Pourquoi réaliser soi-même la réparation de son Redmi 10C ?
Pour faire de belles économies, éviter les frais de main-d'œuvre et l'immobilisation de votre appareil en atelier. C'est aussi un geste pour la planète, qui permet de limiter les déchets électroniques.
Précaution importante : pensez à sauvegarder vos données personnelles avant la manipulation.
- Autonomie en chute libre ou batterie qui gonfle
- Extinctions inopinées malgré une charge restante
- Charge filaire 18W qui ne fonctionne plus correctement
- Faux contacts sur le port USB-C ou OTG défaillant
- Photos floues ou autofocus défaillant sur le capteur 50 Mpx
- Caméra frontale 5 Mpx hors service
- Application caméra qui plante ou ne s'ouvre pas
- Haut-parleur muet, grésillant ou saturé
- Vibreur défaillant
- Lecteur d'empreintes arrière qui ne répond plus
- Ouverture : Retrait de la coque arrière en plastique par simple déclipsage (sans collage).
- Caches : Retrait du cache antenne et des caches lentilles.
- Empreinte : Déconnexion du lecteur d'empreintes arrière.
- Extraction de l'énergie : Déconnexion et retrait de la batterie 5000 mAh.
- Audio : Retrait du haut-parleur externe.
- Partie basse : Retrait du câble coaxial et du connecteur de charge USB-C.
- Cœur du système : Retrait de la carte mère (Snapdragon 680).
- Modules photo : Retrait des caméras arrière (50 Mpx) et frontale (5 Mpx).
- Audio interne : Retrait du haut-parleur interne.
- Vibreur : Retrait du moteur de vibration.
- Finalisation : Remontage des composants, pose d'un nouveau sticker batterie, reconnexion du lecteur d'empreintes et fermeture du smartphone par simple clipsage de la coque arrière.
Ecran complet - Redmi 10C 35.91€ Voir le produit visibility
Batterie (Officielle) - Xiaomi Redmi 10A, 10C et 10 (2022)
26.91€
Outils requis
Poche chauffante - Petit format 6.21€ Voir le produit visibility
Décapeur thermique petit format
8.91€
Voir tous les outils
Pièces en option
Kit outils Spécial - N°1 8.01€ Voir le produit visibility
