Xiaomi Pad
MacBook Pro 13" 2022 M2 (A2338 EMC 8162) MacBook Pro 13" 2020 M1 (A2338 EMC 3578) MacBook Pro 13" 2020 (A2289 EMC 3456) MacBook Pro 13" 2020 (A2251 A2159 - EMC 3348) Macbook Pro 13" Retina Début 2019 (A1989 A2159) MacBook Pro 13" Mi 2018 (A1989 EMC 3214) MacBook Pro 13" Retina Mi 2017 (A1708 A1706) MacBook Pro 13" Retina Fin 2016 (A1708 A1706) MacBook Pro 13" Retina Début 2015 (A1502 - EMC 2835) MacBook Pro 13" Retina Mi 2014 (A1502 - EMC 2875) MacBook Pro 13" Retina Fin 2013 (A1502 - EMC 2678) MacBook Pro 13" Retina Début 2013 (A1425 - EMC 2672) MacBook Pro Retina 13" 2020 (A2338)MacBook Pro 13" Retina Fin 2012 (A1425 - EMC 2557) MacBook Pro 13" Unibody Mi 2012 (A1278 - EMC 2554) MacBook Pro 13" Unibody Fin 2011 (A1278 - EMC 2555) MacBook Pro 13" Unibody Début 2011 (A1278 - EMC 2419) MacBook Pro 13" Unibody Mi 2010 (A1278 - EMC 2351) MacBook Pro 13" Unibody Mi 2009 (A1278 - EMC 2326) MacBook Pro 13" Unibody Fin 2008 (A1278 - EMC 2254)Macbook Pro 14 pouces 2024 M4 Max (A3185) MacBook Pro 14 pouces 2024 M4 Pro (A3401) MacBook Pro 14 pouces 2024 M4 (A3112) Macbook Pro 14 pouces 2023 M3 Pro M3 Pro Max (A2992) Macbook Pro 14 pouces 2023 M3 (A2918) MacBook Pro 14 pouces 2023 M2 Pro M2 Max (A2779) MacBook Pro 14 pouces M1 Pro M1 Max 2021 (A2442)MacBook Pro 15" Retina Mi 2019 (A1990 - EMC 3359) MacBook Pro 15" Retina Mi 2018 (A1990 - EMC 3215) MacBook Pro 15" Retina Mi 2017 (A1707 - EMC 3162) MacBook Pro 15" Retina Fin 2016 (A1707 - EMC 3072) MacBook Pro 15" Retina Mi 2015 (A1398 - EMC 2909/2910) MacBook Pro 15" Retina Mi 2014 (A1398 - EMC 2876 & 2881) MacBook Pro 15" Retina fin 2013 (A1398 - EMC 2674 & 2745) MacBook Pro 15" Retina Début 2013 (A1398 - EMC 2673) MacBook Pro 15" Retina Mi 2012 (A1398 - EMC 2512) MacBook Pro 15" Unibody Mi 2012 (A1286 - EMC 2556)MacBook Pro 15" Unibody Fin 2011 (A1286 - EMC 2563) MacBook Pro 15" Unibody Début 2011 (A1286 - EMC 2353-1) MacBook Pro 15" Unibody Mi 2010 (A1286 - EMC 2353) MacBook Pro 15" Unibody Mi 2009 (A1286 - EMC 2324 & 2325) MacBook Pro 15" Unibody Début 2009 (A1286 - EMC 2255) MacBook Pro 15" Unibody Fin 2008 (A1286 - EMC 2255) MacBook Pro 15" Début 2008 (A1260 - EMC 2198) MacBook Pro 15" Mi/Fin 2007 (A1226 - EMC 2136) MacBook Pro 15" Fin 2006 (A1211 - EMC 2120) MacBook Pro 15" Original 2006 (A1150 - EMC 2101) -
Guide de réparation : Bloc écran - Démontage complet Redmi Note 14 Pro+ 5G
Le démontage complet du bloc écran du Xiaomi Redmi Note 14 Pro+ 5G permet d'accéder à tous les composants de l'appareil pour les remplacer un par un. Que vous souhaitiez changer la batterie 5110 mAh, le connecteur USB-C, le lecteur d'empreintes sous écran, les haut-parleurs stéréo ou le superbe module caméra 200 Mpx avec OIS, cette procédure est la clé d'une réparation durable. En isolant chaque pièce, vous ciblez précisément la panne et restaurez les fonctions de votre mobile sans le remplacer.
Pourquoi réaliser soi-même la réparation de son Redmi Note 14 Pro+ 5G ?
Pour faire de belles économies, éviter les frais de main-d'œuvre et l'immobilisation de votre appareil en atelier. C'est aussi un geste pour la planète, qui permet de limiter les déchets électroniques.
Précaution importante : pensez à sauvegarder vos données personnelles avant la manipulation.
Attention : le Redmi Note 14 Pro+ 5G est certifié IP68. Pour conserver la protection contre l'eau et la poussière, il est indispensable de remplacer les joints d'étanchéité et les stickers de batterie lors du remontage.
- Autonomie en chute libre ou batterie qui gonfle
- Extinctions inopinées malgré une charge restante
- Charge rapide 120W qui ne fonctionne plus correctement
- Faux contacts sur le port USB-C ou OTG défaillant
- Photos floues ou OIS défaillant sur le capteur 200 Mpx
- Ultra grand-angle 8 Mpx ou capteur macro 2 Mpx hors service
- Caméra frontale 20 Mpx qui ne fonctionne plus
- Haut-parleurs stéréo muets, grésillants ou saturés
- Vibreur défaillant
- Lecteur d'empreintes sous écran qui ne répond plus
- Ouverture : Décollage de la vitre arrière (verre ou simili-cuir selon la version).
- Plaquette réseau : Retrait de la plaquette protégeant les antennes.
- Extraction de l'énergie : Retrait de la batterie 5110 mAh.
- Connexions : Déconnexion des nappes d'interconnexion.
- Audio : Retrait du haut-parleur externe.
- Câbles : Retrait de la nappe et des câbles coaxiaux.
- Modules photo : Démontage des objectifs caméras (200 Mpx, ultra grand-angle, macro et frontale).
- Cœur du système : Extraction de la carte mère (Snapdragon 7s Gen 3).
- Composants périphériques : Retrait du lecteur d'empreintes sous écran, du connecteur de charge USB-C et du vibreur.
- Audio interne : Retrait du haut-parleur interne.
- Finalisation : Transfert des composants dans le nouveau bloc écran, pose de nouveaux stickers batterie et fermeture du smartphone avec joints neufs.
Kit outils Spécial - N°1 8.01€ Voir le produit visibility
