MacBook Pro 13" 2022 M2 (A2338 EMC 8162) MacBook Pro 13" 2020 M1 (A2338 EMC 3578) MacBook Pro 13" 2020 (A2289 EMC 3456) MacBook Pro 13" 2020 (A2251 A2159 - EMC 3348) Macbook Pro 13" Retina Début 2019 (A1989 A2159) MacBook Pro 13" Mi 2018 (A1989 EMC 3214) MacBook Pro 13" Retina Mi 2017 (A1708 A1706) MacBook Pro 13" Retina Fin 2016 (A1708 A1706) MacBook Pro 13" Retina Début 2015 (A1502 - EMC 2835) MacBook Pro 13" Retina Mi 2014 (A1502 - EMC 2875) MacBook Pro 13" Retina Fin 2013 (A1502 - EMC 2678) MacBook Pro 13" Retina Début 2013 (A1425 - EMC 2672) MacBook Pro Retina 13" 2020 (A2338)MacBook Pro 13" Retina Fin 2012 (A1425 - EMC 2557) MacBook Pro 13" Unibody Mi 2012 (A1278 - EMC 2554) MacBook Pro 13" Unibody Fin 2011 (A1278 - EMC 2555) MacBook Pro 13" Unibody Début 2011 (A1278 - EMC 2419) MacBook Pro 13" Unibody Mi 2010 (A1278 - EMC 2351) MacBook Pro 13" Unibody Mi 2009 (A1278 - EMC 2326) MacBook Pro 13" Unibody Fin 2008 (A1278 - EMC 2254)Macbook Pro 14 pouces 2024 M4 Max (A3185) MacBook Pro 14 pouces 2024 M4 Pro (A3401) MacBook Pro 14 pouces 2024 M4 (A3112) Macbook Pro 14 pouces 2023 M3 Pro M3 Pro Max (A2992) Macbook Pro 14 pouces 2023 M3 (A2918) MacBook Pro 14 pouces 2023 M2 Pro M2 Max (A2779) MacBook Pro 14 pouces M1 Pro M1 Max 2021 (A2442)MacBook Pro 15" Retina Mi 2019 (A1990 - EMC 3359) MacBook Pro 15" Retina Mi 2018 (A1990 - EMC 3215) MacBook Pro 15" Retina Mi 2017 (A1707 - EMC 3162) MacBook Pro 15" Retina Fin 2016 (A1707 - EMC 3072) MacBook Pro 15" Retina Mi 2015 (A1398 - EMC 2909/2910) MacBook Pro 15" Retina Mi 2014 (A1398 - EMC 2876 & 2881) MacBook Pro 15" Retina fin 2013 (A1398 - EMC 2674 & 2745) MacBook Pro 15" Retina Début 2013 (A1398 - EMC 2673) MacBook Pro 15" Retina Mi 2012 (A1398 - EMC 2512) MacBook Pro 15" Unibody Mi 2012 (A1286 - EMC 2556)MacBook Pro 15" Unibody Fin 2011 (A1286 - EMC 2563) MacBook Pro 15" Unibody Début 2011 (A1286 - EMC 2353-1) MacBook Pro 15" Unibody Mi 2010 (A1286 - EMC 2353) MacBook Pro 15" Unibody Mi 2009 (A1286 - EMC 2324 & 2325) MacBook Pro 15" Unibody Début 2009 (A1286 - EMC 2255) MacBook Pro 15" Unibody Fin 2008 (A1286 - EMC 2255) MacBook Pro 15" Début 2008 (A1260 - EMC 2198) MacBook Pro 15" Mi/Fin 2007 (A1226 - EMC 2136) MacBook Pro 15" Fin 2006 (A1211 - EMC 2120) MacBook Pro 15" Original 2006 (A1150 - EMC 2101) -
Guide de réparation : Batterie Galaxy A07 4G
Après plusieurs années d'utilisation ou suite à des chocs répétés, la batterie de votre Galaxy A07 4G peut montrer des signes d'usure. Vous remarquerez peut-être que l'autonomie chute brutalement, que le téléphone s'éteint tout seul ou que la recharge devient instable. Il arrive aussi que l'appareil chauffe anormalement ou affiche un pourcentage de batterie incohérent. Une batterie gonflée ou abîmée peut également déformer la coque arrière, ce qui pose un vrai problème de sécurité. Sans une batterie fiable, il devient difficile de profiter pleinement de votre téléphone toute la journée.
Chez SOSav, nous savons que les batteries, y compris celle du Galaxy A07 4G avec sa belle capacité de 5000 mAh, finissent par s'user au fil du temps. Pas besoin pour autant de changer tout l'appareil. Nous vous proposons une solution simple et économique : remplacez vous-même la batterie, en suivant nos tutoriels pas à pas pensés pour tous les niveaux.
Pour vous aider à changer la batterie de votre Galaxy A07 4G, nous avons préparé un guide vidéo étape par étape. Illustré par des images claires et un commentaire explicatif, il vous accompagne tout au long de l'opération, que vous soyez débutant ou habitué aux réparations de téléphone.
Pourquoi remplacer soi-même la batterie du Galaxy A07 4G ?
Avant tout pour faire de belles économies. Pas besoin de passer par un atelier coûteux ni d'acheter un nouveau téléphone. En réalisant l'échange vous-même, vous évitez les frais de main-d'œuvre ainsi que les délais d'attente souvent longs des services après-vente. C'est aussi un geste pour la planète, qui permet de limiter les déchets électroniques.
Avant de commencer, pensez à sauvegarder vos données pour éviter toute perte pendant la manipulation.
Signes d'une batterie à remplacer :
- Autonomie qui diminue rapidement
- Téléphone qui s'éteint sans prévenir
- Temps de recharge anormalement long
- Appareil qui chauffe de manière excessive
- Pourcentage de batterie instable ou incohérent
- Batterie gonflée ou coque arrière déformée
- Charge rapide 25W qui ne fonctionne plus correctement
- Téléphone qui s'éteint alors qu'il indique encore de la batterie
Le Galaxy A07 4G est équipé d'une batterie de 5000 mAh compatible avec la charge rapide 25W, prévue pour tenir toute une journée d'utilisation. Avec les bons outils et une batterie compatible de qualité, vous pourrez redonner un second souffle à votre téléphone sans vous ruiner, et continuer à l'utiliser sereinement.
Aperçu des étapes du changement de batterie :
Pour remplacer la batterie de votre Galaxy A07 4G, voici l'ordre des étapes à suivre :
- Ouverture : Retrait de la vitre arrière en plastique (collée au châssis).
- Accès interne : Retrait du châssis intermédiaire pour libérer la batterie.
- Extraction : Retrait de la batterie usagée.
- Remontage : Mise en place de la nouvelle batterie.
- Finalisation : Nettoyage du châssis et fermeture du smartphone.
Kit outils Spécial - N°1 8.01€ Voir le produit visibility
