MacBook Pro 13" 2022 M2 (A2338 EMC 8162) MacBook Pro 13" 2020 M1 (A2338 EMC 3578) MacBook Pro 13" 2020 (A2289 EMC 3456) MacBook Pro 13" 2020 (A2251 A2159 - EMC 3348) Macbook Pro 13" Retina Début 2019 (A1989 A2159) MacBook Pro 13" Mi 2018 (A1989 EMC 3214) MacBook Pro 13" Retina Mi 2017 (A1708 A1706) MacBook Pro 13" Retina Fin 2016 (A1708 A1706) MacBook Pro 13" Retina Début 2015 (A1502 - EMC 2835) MacBook Pro 13" Retina Mi 2014 (A1502 - EMC 2875) MacBook Pro 13" Retina Fin 2013 (A1502 - EMC 2678) MacBook Pro 13" Retina Début 2013 (A1425 - EMC 2672) MacBook Pro Retina 13" 2020 (A2338)MacBook Pro 13" Retina Fin 2012 (A1425 - EMC 2557) MacBook Pro 13" Unibody Mi 2012 (A1278 - EMC 2554) MacBook Pro 13" Unibody Fin 2011 (A1278 - EMC 2555) MacBook Pro 13" Unibody Début 2011 (A1278 - EMC 2419) MacBook Pro 13" Unibody Mi 2010 (A1278 - EMC 2351) MacBook Pro 13" Unibody Mi 2009 (A1278 - EMC 2326) MacBook Pro 13" Unibody Fin 2008 (A1278 - EMC 2254)Macbook Pro 14 pouces 2024 M4 Max (A3185) MacBook Pro 14 pouces 2024 M4 Pro (A3401) MacBook Pro 14 pouces 2024 M4 (A3112) Macbook Pro 14 pouces 2023 M3 Pro M3 Pro Max (A2992) Macbook Pro 14 pouces 2023 M3 (A2918) MacBook Pro 14 pouces 2023 M2 Pro M2 Max (A2779) MacBook Pro 14 pouces M1 Pro M1 Max 2021 (A2442)MacBook Pro 15" Retina Mi 2019 (A1990 - EMC 3359) MacBook Pro 15" Retina Mi 2018 (A1990 - EMC 3215) MacBook Pro 15" Retina Mi 2017 (A1707 - EMC 3162) MacBook Pro 15" Retina Fin 2016 (A1707 - EMC 3072) MacBook Pro 15" Retina Mi 2015 (A1398 - EMC 2909/2910) MacBook Pro 15" Retina Mi 2014 (A1398 - EMC 2876 & 2881) MacBook Pro 15" Retina fin 2013 (A1398 - EMC 2674 & 2745) MacBook Pro 15" Retina Début 2013 (A1398 - EMC 2673) MacBook Pro 15" Retina Mi 2012 (A1398 - EMC 2512) MacBook Pro 15" Unibody Mi 2012 (A1286 - EMC 2556)MacBook Pro 15" Unibody Fin 2011 (A1286 - EMC 2563) MacBook Pro 15" Unibody Début 2011 (A1286 - EMC 2353-1) MacBook Pro 15" Unibody Mi 2010 (A1286 - EMC 2353) MacBook Pro 15" Unibody Mi 2009 (A1286 - EMC 2324 & 2325) MacBook Pro 15" Unibody Début 2009 (A1286 - EMC 2255) MacBook Pro 15" Unibody Fin 2008 (A1286 - EMC 2255) MacBook Pro 15" Début 2008 (A1260 - EMC 2198) MacBook Pro 15" Mi/Fin 2007 (A1226 - EMC 2136) MacBook Pro 15" Fin 2006 (A1211 - EMC 2120) MacBook Pro 15" Original 2006 (A1150 - EMC 2101) -
Guide de réparation : Bloc écran - Démontage complet Galaxy Z Fold5 Galaxy Z Fold 5
Le démontage complet du Samsung Galaxy Z Fold5 permet d’accéder à tous les composants de l’appareil pour les remplacer un par un : batteries, connecteur USB-C, écran externe, carte mère, carte fille, lecteur d’empreintes, haut-parleurs ou modules caméras.
Pourquoi réaliser soi-même la réparation de son Galaxy Z Fold5 ?
Pour faire de belles économies, éviter les frais de main-d’œuvre et l’immobilisation de votre appareil. C’est aussi un geste pour la planète.
Précaution importante : pensez à sauvegarder vos données personnelles avant la manipulation.
Attention : le Galaxy Z Fold5 est certifié IPX8. Pour conserver la protection contre l’eau, remplacez les joints d’étanchéité et les stickers de batterie lors du remontage. Le démontage d’un smartphone pliant demande une attention particulière, notamment autour de la charnière et des deux cellules de batterie à déconnecter séparément.
Aperçu des étapes du démontage complet : La réparation commence par le retrait du rack SIM et de la vitre arrière par chauffage progressif. On retire ensuite la nappe de recharge par induction / NFC, la plaquette réseau, puis on déconnecte la batterie secondaire avant de retirer l’antenne du bas et les nappes FRC et d’interconnexion. La batterie secondaire est extraite, suivie du connecteur USB-C, du vibreur, puis de la carte mère (Snapdragon 8 Gen 2), des objectifs caméras et du lecteur d’empreintes. On passe ensuite à l’écran externe, à l’écouteur interne, à la carte fille, au haut-parleur externe, à la nappe réseau, à la batterie principale et aux cartes réseau. Le remontage s’effectue en sens inverse, jusqu’à la pose de la vitre arrière avec joints d’étanchéité neufs.
L’écran ne répond plus au toucher ou présente des fissures, taches noires, lignes ou affichage blanc
Le pli de l’écran présente une bosse, un décollement ou un dysfonctionnement visible
Une autonomie qui chute brutalement ou une batterie qui se décharge en quelques heures
Un téléphone qui s’éteint tout seul malgré un pourcentage de charge restant, ou une batterie gonflée qui déforme le châssis
Un port USB-C abîmé, une charge rapide 25W qui ne fonctionne plus ou un téléphone qui ne charge plus
Un haut-parleur externe ou un écouteur interne muet, grésillant ou saturé
