MacBook Pro 13" 2022 M2 (A2338 EMC 8162) MacBook Pro 13" 2020 M1 (A2338 EMC 3578) MacBook Pro 13" 2020 (A2289 EMC 3456) MacBook Pro 13" 2020 (A2251 A2159 - EMC 3348) Macbook Pro 13" Retina Début 2019 (A1989 A2159) MacBook Pro 13" Mi 2018 (A1989 EMC 3214) MacBook Pro 13" Retina Mi 2017 (A1708 A1706) MacBook Pro 13" Retina Fin 2016 (A1708 A1706) MacBook Pro 13" Retina Début 2015 (A1502 - EMC 2835) MacBook Pro 13" Retina Mi 2014 (A1502 - EMC 2875) MacBook Pro 13" Retina Fin 2013 (A1502 - EMC 2678) MacBook Pro 13" Retina Début 2013 (A1425 - EMC 2672) MacBook Pro Retina 13" 2020 (A2338)MacBook Pro 13" Retina Fin 2012 (A1425 - EMC 2557) MacBook Pro 13" Unibody Mi 2012 (A1278 - EMC 2554) MacBook Pro 13" Unibody Fin 2011 (A1278 - EMC 2555) MacBook Pro 13" Unibody Début 2011 (A1278 - EMC 2419) MacBook Pro 13" Unibody Mi 2010 (A1278 - EMC 2351) MacBook Pro 13" Unibody Mi 2009 (A1278 - EMC 2326) MacBook Pro 13" Unibody Fin 2008 (A1278 - EMC 2254)Macbook Pro 14 pouces 2024 M4 Max (A3185) MacBook Pro 14 pouces 2024 M4 Pro (A3401) MacBook Pro 14 pouces 2024 M4 (A3112) Macbook Pro 14 pouces 2023 M3 Pro M3 Pro Max (A2992) Macbook Pro 14 pouces 2023 M3 (A2918) MacBook Pro 14 pouces 2023 M2 Pro M2 Max (A2779) MacBook Pro 14 pouces M1 Pro M1 Max 2021 (A2442)MacBook Pro 15" Retina Mi 2019 (A1990 - EMC 3359) MacBook Pro 15" Retina Mi 2018 (A1990 - EMC 3215) MacBook Pro 15" Retina Mi 2017 (A1707 - EMC 3162) MacBook Pro 15" Retina Fin 2016 (A1707 - EMC 3072) MacBook Pro 15" Retina Mi 2015 (A1398 - EMC 2909/2910) MacBook Pro 15" Retina Mi 2014 (A1398 - EMC 2876 & 2881) MacBook Pro 15" Retina fin 2013 (A1398 - EMC 2674 & 2745) MacBook Pro 15" Retina Début 2013 (A1398 - EMC 2673) MacBook Pro 15" Retina Mi 2012 (A1398 - EMC 2512) MacBook Pro 15" Unibody Mi 2012 (A1286 - EMC 2556)MacBook Pro 15" Unibody Fin 2011 (A1286 - EMC 2563) MacBook Pro 15" Unibody Début 2011 (A1286 - EMC 2353-1) MacBook Pro 15" Unibody Mi 2010 (A1286 - EMC 2353) MacBook Pro 15" Unibody Mi 2009 (A1286 - EMC 2324 & 2325) MacBook Pro 15" Unibody Début 2009 (A1286 - EMC 2255) MacBook Pro 15" Unibody Fin 2008 (A1286 - EMC 2255) MacBook Pro 15" Début 2008 (A1260 - EMC 2198) MacBook Pro 15" Mi/Fin 2007 (A1226 - EMC 2136) MacBook Pro 15" Fin 2006 (A1211 - EMC 2120) MacBook Pro 15" Original 2006 (A1150 - EMC 2101) -
Guide de réparation : Batteries Galaxy Z Flip5
Quand faut-il remplacer les deux batteries de votre Galaxy Z Flip5 ?
Avec l’usage, votre Galaxy Z Flip5 peut présenter une baisse notable de son autonomie ou des soucis lors de la recharge, causés par l’usure naturelle de ses batteries internes. Ce téléphone pliable intègre en effet une batterie principale ainsi qu’une batterie secondaire, toutes deux essentielles pour assurer son bon fonctionnement. Si votre appareil se décharge rapidement, s’éteint sans prévenir ou recharge de manière aléatoire, il est peut-être temps d’envisager leur remplacement.
Chez SOSav, nous comprenons que la perte d’autonomie peut devenir gênante au quotidien. Pour autant, il n’est pas nécessaire de remplacer l’intégralité du smartphone pour un simple problème de batterie. Nous vous proposons une solution accessible, économique et pratique pour restaurer les performances de votre appareil. Afin de faciliter le changement des deux batteries du Galaxy Z Flip5, nous avons conçu un tutoriel illustré. Ce guide explicatif comprend des consignes précises, des photos étape par étape et des conseils utiles, vous permettant de mener à bien la réparation en toute autonomie et en toute sécurité.
En optant pour le remplacement des batteries par vous-même, vous participez activement à la réduction des déchets électroniques et à la lutte contre l’obsolescence prématurée. C’est une démarche responsable, à la fois économique et écologique. Et si un doute survient durant l’intervention, nos techniciens sont là pour vous épauler à chaque étape du processus.
N’oubliez pas de sauvegarder l’ensemble de vos fichiers personnels avant d’entamer la procédure de remplacement des batteries.
Signes indiquant un remplacement nécessaire :
- Perte rapide de charge
- Difficultés de recharge ou lenteur
- Arrêts inopinés de l’appareil
- Démarrage impossible sans alimentation secteur
- Échauffement excessif pendant l’utilisation ou la recharge
Kit outils Spécial - N°1 8.01€ Voir le produit visibility
Comment changer batteries pour Galaxy Z Flip5 - Guide vidéo
Comment remplacer batteries pour Galaxy Z Flip5 - Guide images
Vous avez bien reçu vos pièces ? Vous pouvez commencer la réparation.
Eteindre votre téléphone si cela est possible, ou laissez-le se décharger tout seul.
Retirez le tiroir contenant la carte SIM avec l'outil présent dans le Kit.
Coussin chauffant : Passez le coussin au micro-ondes environ 1-2 minutes avant de le mettre sur le dos du smartphone
Décapeur thermique : Chauffez le contour de l'appareil, à une distance de 5cm, pendant 20 à 30 secondes.
Collez la ventouse sur le bas du téléphone.
Introduisez le médiator en métal troué entre le châssis et la vitre arrière.
Enlevez les résidus de joint.
Enlever la plaquette et placez-la sur votre patron d'aide au montage.
Déconnectez la premiere batterie
Insérez les médiators en plastique sous le médiator en métal, retirez le médiator en métal.
Faites circuler les médiators sur tout le tour du téléphone pour décoller petite à petit la vitre arrière.
Basculez doucement l'écran externe de gauche à droite, il est encore connecté avec une nappe au châssis.
Déconnectez la nappe de l'écran externe.
Ôter la plaquette métallique et la mettre de côté.
Déconnectez la seconde batterie, et continuez votre réparation en toute sécurité.
Déconnectez et décollez la nappe NFC, puis mettez-la de côté.
Décollez le sticker bleu de la batterie, et tirez fermement pour sortir la batterie du châssis.
La batterie principale est retirée.
♻️ Jetez votre batterie hors service dans le bac de recyclage approprié. Merci !
Déconnectez les deux nappes de la rallonge pour pouvoir accéder aux adhésifs de la batterie.
Décoller les stickers un par un.
Tirez fermement sur le sticker et retirez la batterie.
La batterie secondaire est retirée.
