MacBook Pro 13" 2022 M2 (A2338 EMC 8162) MacBook Pro 13" 2020 M1 (A2338 EMC 3578) MacBook Pro 13" 2020 (A2289 EMC 3456) MacBook Pro 13" 2020 (A2251 A2159 - EMC 3348) Macbook Pro 13" Retina Début 2019 (A1989 A2159) MacBook Pro 13" Mi 2018 (A1989 EMC 3214) MacBook Pro 13" Retina Mi 2017 (A1708 A1706) MacBook Pro 13" Retina Fin 2016 (A1708 A1706) MacBook Pro 13" Retina Début 2015 (A1502 - EMC 2835) MacBook Pro 13" Retina Mi 2014 (A1502 - EMC 2875) MacBook Pro 13" Retina Fin 2013 (A1502 - EMC 2678) MacBook Pro 13" Retina Début 2013 (A1425 - EMC 2672) MacBook Pro Retina 13" 2020 (A2338)MacBook Pro 13" Retina Fin 2012 (A1425 - EMC 2557) MacBook Pro 13" Unibody Mi 2012 (A1278 - EMC 2554) MacBook Pro 13" Unibody Fin 2011 (A1278 - EMC 2555) MacBook Pro 13" Unibody Début 2011 (A1278 - EMC 2419) MacBook Pro 13" Unibody Mi 2010 (A1278 - EMC 2351) MacBook Pro 13" Unibody Mi 2009 (A1278 - EMC 2326) MacBook Pro 13" Unibody Fin 2008 (A1278 - EMC 2254)Macbook Pro 14 pouces 2024 M4 Max (A3185) MacBook Pro 14 pouces 2024 M4 Pro (A3401) MacBook Pro 14 pouces 2024 M4 (A3112) Macbook Pro 14 pouces 2023 M3 Pro M3 Pro Max (A2992) Macbook Pro 14 pouces 2023 M3 (A2918) MacBook Pro 14 pouces 2023 M2 Pro M2 Max (A2779) MacBook Pro 14 pouces M1 Pro M1 Max 2021 (A2442)MacBook Pro 15" Retina Mi 2019 (A1990 - EMC 3359) MacBook Pro 15" Retina Mi 2018 (A1990 - EMC 3215) MacBook Pro 15" Retina Mi 2017 (A1707 - EMC 3162) MacBook Pro 15" Retina Fin 2016 (A1707 - EMC 3072) MacBook Pro 15" Retina Mi 2015 (A1398 - EMC 2909/2910) MacBook Pro 15" Retina Mi 2014 (A1398 - EMC 2876 & 2881) MacBook Pro 15" Retina fin 2013 (A1398 - EMC 2674 & 2745) MacBook Pro 15" Retina Début 2013 (A1398 - EMC 2673) MacBook Pro 15" Retina Mi 2012 (A1398 - EMC 2512) MacBook Pro 15" Unibody Mi 2012 (A1286 - EMC 2556)MacBook Pro 15" Unibody Fin 2011 (A1286 - EMC 2563) MacBook Pro 15" Unibody Début 2011 (A1286 - EMC 2353-1) MacBook Pro 15" Unibody Mi 2010 (A1286 - EMC 2353) MacBook Pro 15" Unibody Mi 2009 (A1286 - EMC 2324 & 2325) MacBook Pro 15" Unibody Début 2009 (A1286 - EMC 2255) MacBook Pro 15" Unibody Fin 2008 (A1286 - EMC 2255) MacBook Pro 15" Début 2008 (A1260 - EMC 2198) MacBook Pro 15" Mi/Fin 2007 (A1226 - EMC 2136) MacBook Pro 15" Fin 2006 (A1211 - EMC 2120) MacBook Pro 15" Original 2006 (A1150 - EMC 2101) -
Guide de réparation : Batterie Galaxy S24
Après plusieurs mois d'utilisation ou à la suite d’un choc, la batterie de votre Galaxy S24 peut montrer des signes de faiblesse. Cela se manifeste souvent par une autonomie réduite, des redémarrages intempestifs, une chauffe inhabituelle ou un refus de charge. Même si le smartphone reste fonctionnel, une batterie défaillante nuit fortement à l’expérience utilisateur au quotidien. Parmi les problèmes récurrents : pourcentage de batterie instable, extinction soudaine, charge lente ou absence de réaction au branchement d’un câble.
Chez SOSav, nous savons que même si le Galaxy S24 est un appareil haut de gamme, sa batterie Li-Ion de 4000 mAh n’est pas inusable. Compatible avec la recharge filaire 25W (Power Delivery 3.0) permettant d’atteindre 50% en seulement 30 minutes, ainsi qu’avec la recharge sans fil 15W (Qi) et la charge inversée à 4.5W, cette batterie assure une utilisation polyvalente. Toutefois, au fil du temps ou après une chute, ses performances peuvent chuter. Remplacer la batterie vous-même à l’aide de nos guides illustrés est une solution économique, fiable et durable, qui prolonge la vie de votre smartphone.
Signes d’une batterie à remplacer :
- Autonomie anormalement faible
- Redémarrages imprévus
- Batterie qui gonfle ou chauffe excessivement
- Charge très lente voire absente
- Pourcentage erratique ou bloqué
- Problèmes de reconnaissance de chargeur ou de charge sans fil
Batterie - Galaxy S24 14.45€ 15.21€ Voir le produit visibility
Batterie - Galaxy S24 (Officielle)
52.16€ 54.90€
Comment changer batterie pour Galaxy S24 - Guide vidéo
Comment remplacer batterie pour Galaxy S24 - Guide images
Vous avez bien reçu vos pièces de rechange ? Vous êtes prêt à commencer la réparation.
Éteignez votre Galaxy S24 si cela est possible, ou laissez-le se décharger complètement avant toute manipulation.
Retirez le tiroir SIM à l’aide de l’outil prévu à cet effet, inclus dans votre kit de réparation.
Coussin chauffant : Passez le coussin au micro-ondes environ 1-2 minutes avant de le mettre sur le dos du smartphone
Décapeur thermique : Si vous avez choisi le pistolet, chauffez le contour de l'appareil, à une distance de 5cm pendant 20 à 30 secondes. Idem avec le sèche cheveux.
Insérez le médiator en plastique sous le médiator en métal puis faites le glissez tout autour du composant.
Déconnectez la nappe de la carte mère.
Décoller les languettes de la nappe à induction du haut-parleur externe, utilisez un sèche cheveux ou un décapeur thermique une dizaine de seconde pour chauffer et ramollir la colle, et décollez la nappe en totalité.
Soulevez le haut-parleur externe avec la pincette et mettez-le de côté.
Chauffez légèrement l'arrière de la batterie à travers l'écran.
Tirez la languette pour décoller la batterie.
Nettoyez les restes de stickers encore présents sur la vitre arrière et le châssis.
Appliquez un filet de colle sur tout le contour du châssis de votre Galaxy S24.
Mettez sous presse votre S24 et le laisser sécher environ 1 heure à l'aide de pinces ou de gros livres.
