MacBook Pro 13" 2022 M2 (A2338 EMC 8162) MacBook Pro 13" 2020 M1 (A2338 EMC 3578) MacBook Pro 13" 2020 (A2289 EMC 3456) MacBook Pro 13" 2020 (A2251 A2159 - EMC 3348) Macbook Pro 13" Retina Début 2019 (A1989 A2159) MacBook Pro 13" Mi 2018 (A1989 EMC 3214) MacBook Pro 13" Retina Mi 2017 (A1708 A1706) MacBook Pro 13" Retina Fin 2016 (A1708 A1706) MacBook Pro 13" Retina Début 2015 (A1502 - EMC 2835) MacBook Pro 13" Retina Mi 2014 (A1502 - EMC 2875) MacBook Pro 13" Retina Fin 2013 (A1502 - EMC 2678) MacBook Pro 13" Retina Début 2013 (A1425 - EMC 2672) MacBook Pro Retina 13" 2020 (A2338)MacBook Pro 13" Retina Fin 2012 (A1425 - EMC 2557) MacBook Pro 13" Unibody Mi 2012 (A1278 - EMC 2554) MacBook Pro 13" Unibody Fin 2011 (A1278 - EMC 2555) MacBook Pro 13" Unibody Début 2011 (A1278 - EMC 2419) MacBook Pro 13" Unibody Mi 2010 (A1278 - EMC 2351) MacBook Pro 13" Unibody Mi 2009 (A1278 - EMC 2326) MacBook Pro 13" Unibody Fin 2008 (A1278 - EMC 2254)Macbook Pro 14 pouces 2024 M4 Max (A3185) MacBook Pro 14 pouces 2024 M4 Pro (A3401) MacBook Pro 14 pouces 2024 M4 (A3112) Macbook Pro 14 pouces 2023 M3 Pro M3 Pro Max (A2992) Macbook Pro 14 pouces 2023 M3 (A2918) MacBook Pro 14 pouces 2023 M2 Pro M2 Max (A2779) MacBook Pro 14 pouces M1 Pro M1 Max 2021 (A2442)MacBook Pro 15" Retina Mi 2019 (A1990 - EMC 3359) MacBook Pro 15" Retina Mi 2018 (A1990 - EMC 3215) MacBook Pro 15" Retina Mi 2017 (A1707 - EMC 3162) MacBook Pro 15" Retina Fin 2016 (A1707 - EMC 3072) MacBook Pro 15" Retina Mi 2015 (A1398 - EMC 2909/2910) MacBook Pro 15" Retina Mi 2014 (A1398 - EMC 2876 & 2881) MacBook Pro 15" Retina fin 2013 (A1398 - EMC 2674 & 2745) MacBook Pro 15" Retina Début 2013 (A1398 - EMC 2673) MacBook Pro 15" Retina Mi 2012 (A1398 - EMC 2512) MacBook Pro 15" Unibody Mi 2012 (A1286 - EMC 2556)MacBook Pro 15" Unibody Fin 2011 (A1286 - EMC 2563) MacBook Pro 15" Unibody Début 2011 (A1286 - EMC 2353-1) MacBook Pro 15" Unibody Mi 2010 (A1286 - EMC 2353) MacBook Pro 15" Unibody Mi 2009 (A1286 - EMC 2324 & 2325) MacBook Pro 15" Unibody Début 2009 (A1286 - EMC 2255) MacBook Pro 15" Unibody Fin 2008 (A1286 - EMC 2255) MacBook Pro 15" Début 2008 (A1260 - EMC 2198) MacBook Pro 15" Mi/Fin 2007 (A1226 - EMC 2136) MacBook Pro 15" Fin 2006 (A1211 - EMC 2120) MacBook Pro 15" Original 2006 (A1150 - EMC 2101) -
Guide de réparation : Ecran, connecteur de charge et batterie Galaxy A37
Le démontage complet du Samsung Galaxy A37 5G permet d’accéder à tous les composants de l’appareil pour les remplacer un par un : batterie 5000 mAh, connecteur USB-C, lecteur d’empreintes sous écran, haut-parleurs stéréo ou modules caméras (50 Mpx avec OIS, ultra grand-angle 8 Mpx, macro 5 Mpx et frontale 12 Mpx).
Pourquoi réaliser soi-même la réparation de son Galaxy A37 5G ?
Pour faire de belles économies, éviter les frais de main-d’œuvre et l’immobilisation de votre appareil en atelier. C’est aussi un geste pour la planète, qui permet de limiter les déchets électroniques.
Précaution importante : pensez à sauvegarder vos données personnelles avant la manipulation.
La réparation commence par l’extinction du smartphone et le retrait du rack SIM, suivie du retrait de la vitre arrière par chauffage progressif. On retire ensuite l’écouteur interne, puis on déconnecte les nappes et on retire le haut-parleur externe. Après le retrait des nappes de connexion, on procède au retrait de la batterie 5000 mAh, du connecteur de charge USB-C et de la carte mère (Exynos 1480). Vient ensuite le retrait des objectifs caméras, des caméras arrière et du lecteur d’empreintes sous écran. Le remontage s’e
Autonomie en chute libre, extinctions inopinées ou batterie gonflée qui déforme le châssis.
Charge rapide inopérante, port USB-C abîmé ou recharge devenue anormalement lente.
Photos floues, OIS défaillant sur les capteurs photo.
Haut-parleurs stéréo muets, grésillant ou saturés lors de la lecture.
Lecteur d’empreintes sous écran qui ne répond plus ou écran qui présente des défauts d’affichage.
Batterie - Samsung Galaxy A37 et A57 5G 11.61€ Voir le produit visibility
Ecran Samsung Galaxy A37 5G - OLED - Blanc
44.90€
