MacBook Pro 13" 2022 M2 (A2338 EMC 8162) MacBook Pro 13" 2020 M1 (A2338 EMC 3578) MacBook Pro 13" 2020 (A2289 EMC 3456) MacBook Pro 13" 2020 (A2251 A2159 - EMC 3348) Macbook Pro 13" Retina Début 2019 (A1989 A2159) MacBook Pro 13" Mi 2018 (A1989 EMC 3214) MacBook Pro 13" Retina Mi 2017 (A1708 A1706) MacBook Pro 13" Retina Fin 2016 (A1708 A1706) MacBook Pro 13" Retina Début 2015 (A1502 - EMC 2835) MacBook Pro 13" Retina Mi 2014 (A1502 - EMC 2875) MacBook Pro 13" Retina Fin 2013 (A1502 - EMC 2678) MacBook Pro 13" Retina Début 2013 (A1425 - EMC 2672) MacBook Pro Retina 13" 2020 (A2338)MacBook Pro 13" Retina Fin 2012 (A1425 - EMC 2557) MacBook Pro 13" Unibody Mi 2012 (A1278 - EMC 2554) MacBook Pro 13" Unibody Fin 2011 (A1278 - EMC 2555) MacBook Pro 13" Unibody Début 2011 (A1278 - EMC 2419) MacBook Pro 13" Unibody Mi 2010 (A1278 - EMC 2351) MacBook Pro 13" Unibody Mi 2009 (A1278 - EMC 2326) MacBook Pro 13" Unibody Fin 2008 (A1278 - EMC 2254)Macbook Pro 14 pouces 2024 M4 Max (A3185) MacBook Pro 14 pouces 2024 M4 Pro (A3401) MacBook Pro 14 pouces 2024 M4 (A3112) Macbook Pro 14 pouces 2023 M3 Pro M3 Pro Max (A2992) Macbook Pro 14 pouces 2023 M3 (A2918) MacBook Pro 14 pouces 2023 M2 Pro M2 Max (A2779) MacBook Pro 14 pouces M1 Pro M1 Max 2021 (A2442)MacBook Pro 15" Retina Mi 2019 (A1990 - EMC 3359) MacBook Pro 15" Retina Mi 2018 (A1990 - EMC 3215) MacBook Pro 15" Retina Mi 2017 (A1707 - EMC 3162) MacBook Pro 15" Retina Fin 2016 (A1707 - EMC 3072) MacBook Pro 15" Retina Mi 2015 (A1398 - EMC 2909/2910) MacBook Pro 15" Retina Mi 2014 (A1398 - EMC 2876 & 2881) MacBook Pro 15" Retina fin 2013 (A1398 - EMC 2674 & 2745) MacBook Pro 15" Retina Début 2013 (A1398 - EMC 2673) MacBook Pro 15" Retina Mi 2012 (A1398 - EMC 2512) MacBook Pro 15" Unibody Mi 2012 (A1286 - EMC 2556)MacBook Pro 15" Unibody Fin 2011 (A1286 - EMC 2563) MacBook Pro 15" Unibody Début 2011 (A1286 - EMC 2353-1) MacBook Pro 15" Unibody Mi 2010 (A1286 - EMC 2353) MacBook Pro 15" Unibody Mi 2009 (A1286 - EMC 2324 & 2325) MacBook Pro 15" Unibody Début 2009 (A1286 - EMC 2255) MacBook Pro 15" Unibody Fin 2008 (A1286 - EMC 2255) MacBook Pro 15" Début 2008 (A1260 - EMC 2198) MacBook Pro 15" Mi/Fin 2007 (A1226 - EMC 2136) MacBook Pro 15" Fin 2006 (A1211 - EMC 2120) MacBook Pro 15" Original 2006 (A1150 - EMC 2101) -
Guide de réparation : Démontage complet Galaxy A22 4G
Le démontage complet du Samsung Galaxy A22 4G est une opération qui permet d'accéder à l'ensemble des composants vitaux de l'appareil pour les remplacer individuellement. Qu'il s'agisse de redonner de l'énergie à votre téléphone avec une batterie neuve, de corriger des problèmes de charge via le connecteur USB-C, de remplacer des modules caméras défaillants ou de transférer votre carte mère dans un nouveau châssis, cette procédure est la clé d'une réparation durable. En isolant chaque élément, du vibreur au haut-parleur interne, vous avez la possibilité de cibler précisément la panne et de restaurer l'intégralité des fonctions de votre mobile sans avoir à en changer.
À la suite d’une chute ou d’un choc brutal, l’écran de votre Galaxy A22 4G peut également présenter des dégâts matériels, tels que des fêlures ou des bris de glace plus ou moins profonds. Il arrive que le système d'affichage défaille : image figée, écran totalement noir ou bugs visuels, quand bien même le téléphone émet encore des vibrations ou des notifications sonores. La couche tactile peut cesser de répondre ou agir de façon incontrôlée, rendant la manipulation du smartphone pénible. Des éraflures persistantes, des colonnes colorées ou des parties de la dalle devenues insensibles peuvent aussi survenir.
Pourquoi entreprendre vous-même la réparation de votre Galaxy A22 4G ?
D'abord, pour réaliser des économies budgétaires importantes. Il n’est pas utile de racheter un mobile neuf ou de régler une facture de réparation onéreuse. En procédant vous-même à l'échange de la pièce défectueuse, vous supprimez les coûts de main-d’œuvre tout en évitant l'immobilisation prolongée de votre appareil en atelier spécialisé. Privilégier la réparation au remplacement est également une démarche écologique forte, contribuant à la diminution des débris technologiques.
Précaution importante : effectuez systématiquement une sauvegarde de vos fichiers personnels afin de prévenir toute perte de données accidentelle durant le processus.
- Vitre externe brisée ou tactile HS
- Perte d'autonomie ou batterie qui gonfle
- Difficultés à insérer le câble de charge ou faux contacts
- Photos floues ou application caméra qui ne s'ouvre plus
- Plus de son lors des appels (écouteur interne)
- Le téléphone ne vibre plus lors des notifications
Le Galaxy A22 4G bénéficie d'une conception modulaire qui facilite l'accès à sa technologie Super AMOLED de 6,4" et à sa batterie de 5000 mAh. Bien que l'ouverture demande de la minutie, restaurer votre appareil avec des pièces de rechange de qualité vous permettra de retrouver un smartphone parfaitement fonctionnel à moindre coût.
Pour remettre à neuf votre appareil ou accéder aux composants internes, voici la chronologie de l'intervention :
- Ouverture : Décollage de la façade arrière en plastique.
- Accès interne : Retrait du châssis intermédiaire pour libérer les composants.
- Sécurité : Déconnexion immédiate de la batterie pour éviter tout court-circuit.
- Démontage des liaisons : Retrait de la nappe d'interconnexion reliant les différentes cartes.
- Extraction de l'énergie : Retrait de la batterie.
- Partie basse : Dépose du connecteur de charge (port USB-C).
- Cœur du système : Retrait de la carte mère supportant le processeur Helio G80.
- Composants périphériques : Extraction du moteur de vibration, du haut-parleur interne et des objectifs caméras.
Ecran complet NOIR - Galaxy A22 29.84€ 31.41€ Voir le produit visibility
Connecteur de charge avec prise jack (Officiel reconditionné) - Galaxy A22 4G
9.41€ 9.90€
Outils requis
iSesamo (Spatule en métal) 7.61€ 8.01€ Voir le produit visibility
Décapeur thermique petit format
8.46€ 8.91€
Voir tous les outils
Pièces en option
Kit outils Spécial - N°1 7.61€ 8.01€ Voir le produit visibility
