Xiaomi Pad
MacBook Pro 13" 2022 M2 (A2338 EMC 8162) MacBook Pro 13" 2020 M1 (A2338 EMC 3578) MacBook Pro 13" 2020 (A2289 EMC 3456) MacBook Pro 13" 2020 (A2251 A2159 - EMC 3348) Macbook Pro 13" Retina Début 2019 (A1989 A2159) MacBook Pro 13" Mi 2018 (A1989 EMC 3214) MacBook Pro 13" Retina Mi 2017 (A1708 A1706) MacBook Pro 13" Retina Fin 2016 (A1708 A1706) MacBook Pro 13" Retina Début 2015 (A1502 - EMC 2835) MacBook Pro 13" Retina Mi 2014 (A1502 - EMC 2875) MacBook Pro 13" Retina Fin 2013 (A1502 - EMC 2678) MacBook Pro 13" Retina Début 2013 (A1425 - EMC 2672) MacBook Pro Retina 13" 2020 (A2338)MacBook Pro 13" Retina Fin 2012 (A1425 - EMC 2557) MacBook Pro 13" Unibody Mi 2012 (A1278 - EMC 2554) MacBook Pro 13" Unibody Fin 2011 (A1278 - EMC 2555) MacBook Pro 13" Unibody Début 2011 (A1278 - EMC 2419) MacBook Pro 13" Unibody Mi 2010 (A1278 - EMC 2351) MacBook Pro 13" Unibody Mi 2009 (A1278 - EMC 2326) MacBook Pro 13" Unibody Fin 2008 (A1278 - EMC 2254)Macbook Pro 14 pouces 2024 M4 Max (A3185) MacBook Pro 14 pouces 2024 M4 Pro (A3401) MacBook Pro 14 pouces 2024 M4 (A3112) Macbook Pro 14 pouces 2023 M3 Pro M3 Pro Max (A2992) Macbook Pro 14 pouces 2023 M3 (A2918) MacBook Pro 14 pouces 2023 M2 Pro M2 Max (A2779) MacBook Pro 14 pouces M1 Pro M1 Max 2021 (A2442)MacBook Pro 15" Retina Mi 2019 (A1990 - EMC 3359) MacBook Pro 15" Retina Mi 2018 (A1990 - EMC 3215) MacBook Pro 15" Retina Mi 2017 (A1707 - EMC 3162) MacBook Pro 15" Retina Fin 2016 (A1707 - EMC 3072) MacBook Pro 15" Retina Mi 2015 (A1398 - EMC 2909/2910) MacBook Pro 15" Retina Mi 2014 (A1398 - EMC 2876 & 2881) MacBook Pro 15" Retina fin 2013 (A1398 - EMC 2674 & 2745) MacBook Pro 15" Retina Début 2013 (A1398 - EMC 2673) MacBook Pro 15" Retina Mi 2012 (A1398 - EMC 2512) MacBook Pro 15" Unibody Mi 2012 (A1286 - EMC 2556)MacBook Pro 15" Unibody Fin 2011 (A1286 - EMC 2563) MacBook Pro 15" Unibody Début 2011 (A1286 - EMC 2353-1) MacBook Pro 15" Unibody Mi 2010 (A1286 - EMC 2353) MacBook Pro 15" Unibody Mi 2009 (A1286 - EMC 2324 & 2325) MacBook Pro 15" Unibody Début 2009 (A1286 - EMC 2255) MacBook Pro 15" Unibody Fin 2008 (A1286 - EMC 2255) MacBook Pro 15" Début 2008 (A1260 - EMC 2198) MacBook Pro 15" Mi/Fin 2007 (A1226 - EMC 2136) MacBook Pro 15" Fin 2006 (A1211 - EMC 2120) MacBook Pro 15" Original 2006 (A1150 - EMC 2101) -
Guide de réparation : Démontage complet Galaxy A06 4G
Pour bien réparer votre Samsung Galaxy A06, il est essentiel de connaître les spécificités techniques de l'appareil. Ce modèle est doté d'un grand écran PLS LCD de 6,7 pouces offrant une résolution HD+ (720 x 1600 pixels). Contrairement aux versions précédentes, le Galaxy A06 adopte un design plus fin avec une structure interne optimisée pour faciliter l'accès aux composants modulaires.
Ce guide de démontage complet vous accompagne étape par étape pour accéder au cœur du téléphone. Après avoir retiré la face arrière, vous découvrirez une architecture organisée autour de plusieurs éléments clés :
- La Batterie : Un bloc de 5000 mAh occupant une large place centrale. Son remplacement résout les problèmes d'autonomie ou de surchauffe. Elle supporte la charge rapide 25W.
- Le Connecteur de Charge : Indépendant de la carte mère principale, il est situé sur une carte fille en bas du châssis. C'est la pièce maîtresse à remplacer en cas de faux contacts ou d'impossibilité de charger l'appareil via le port USB-C.
- Le Système Photo : Le Galaxy A06 embarque un double capteur arrière, dont un module principal de 50 Mpx. Ces capteurs sont accessibles dès le retrait du châssis intermédiaire.
- Le Bouton Power / Empreinte : La nappe du lecteur d'empreinte digitale est intégrée à la tranche latérale. Elle nécessite une manipulation délicate lors de l'ouverture pour éviter toute déchirure.
Que vous deviez remplacer un écran cassé, une batterie fatiguée ou un connecteur de charge défectueux, nos instructions détaillées vous permettront d'effectuer ces réparations en toute sécurité. Réparer soi-même son Galaxy A06 permet non seulement de réaliser des économies, mais aussi de prolonger la durée de vie de votre smartphone.
Conseil important : Avant toute intervention, nous vous recommandons d'éteindre votre Galaxy A06 et de réaliser une sauvegarde de vos données personnelles.
Symptômes couverts par ce guide :
- Écran brisé, noir ou tactile ne répondant plus.
- Batterie qui se décharge anormalement vite.
- Câble USB qui ne tient plus ou charge intermittente.
- Problèmes de son (haut-parleur muet ou grésillant).
- Appareil photo ne faisant plus la mise au point.
Kit outils Spécial - N°1 8.01€ Voir le produit visibility
