MacBook Pro 13" 2022 M2 (A2338 EMC 8162) MacBook Pro 13" 2020 M1 (A2338 EMC 3578) MacBook Pro 13" 2020 (A2289 EMC 3456) MacBook Pro 13" 2020 (A2251 A2159 - EMC 3348) Macbook Pro 13" Retina Début 2019 (A1989 A2159) MacBook Pro 13" Mi 2018 (A1989 EMC 3214) MacBook Pro 13" Retina Mi 2017 (A1708 A1706) MacBook Pro 13" Retina Fin 2016 (A1708 A1706) MacBook Pro 13" Retina Début 2015 (A1502 - EMC 2835) MacBook Pro 13" Retina Mi 2014 (A1502 - EMC 2875) MacBook Pro 13" Retina Fin 2013 (A1502 - EMC 2678) MacBook Pro 13" Retina Début 2013 (A1425 - EMC 2672) MacBook Pro Retina 13" 2020 (A2338)MacBook Pro 13" Retina Fin 2012 (A1425 - EMC 2557) MacBook Pro 13" Unibody Mi 2012 (A1278 - EMC 2554) MacBook Pro 13" Unibody Fin 2011 (A1278 - EMC 2555) MacBook Pro 13" Unibody Début 2011 (A1278 - EMC 2419) MacBook Pro 13" Unibody Mi 2010 (A1278 - EMC 2351) MacBook Pro 13" Unibody Mi 2009 (A1278 - EMC 2326) MacBook Pro 13" Unibody Fin 2008 (A1278 - EMC 2254)Macbook Pro 14 pouces 2024 M4 Max (A3185) MacBook Pro 14 pouces 2024 M4 Pro (A3401) MacBook Pro 14 pouces 2024 M4 (A3112) Macbook Pro 14 pouces 2023 M3 Pro M3 Pro Max (A2992) Macbook Pro 14 pouces 2023 M3 (A2918) MacBook Pro 14 pouces 2023 M2 Pro M2 Max (A2779) MacBook Pro 14 pouces M1 Pro M1 Max 2021 (A2442)MacBook Pro 15" Retina Mi 2019 (A1990 - EMC 3359) MacBook Pro 15" Retina Mi 2018 (A1990 - EMC 3215) MacBook Pro 15" Retina Mi 2017 (A1707 - EMC 3162) MacBook Pro 15" Retina Fin 2016 (A1707 - EMC 3072) MacBook Pro 15" Retina Mi 2015 (A1398 - EMC 2909/2910) MacBook Pro 15" Retina Mi 2014 (A1398 - EMC 2876 & 2881) MacBook Pro 15" Retina fin 2013 (A1398 - EMC 2674 & 2745) MacBook Pro 15" Retina Début 2013 (A1398 - EMC 2673) MacBook Pro 15" Retina Mi 2012 (A1398 - EMC 2512) MacBook Pro 15" Unibody Mi 2012 (A1286 - EMC 2556)MacBook Pro 15" Unibody Fin 2011 (A1286 - EMC 2563) MacBook Pro 15" Unibody Début 2011 (A1286 - EMC 2353-1) MacBook Pro 15" Unibody Mi 2010 (A1286 - EMC 2353) MacBook Pro 15" Unibody Mi 2009 (A1286 - EMC 2324 & 2325) MacBook Pro 15" Unibody Début 2009 (A1286 - EMC 2255) MacBook Pro 15" Unibody Fin 2008 (A1286 - EMC 2255) MacBook Pro 15" Début 2008 (A1260 - EMC 2198) MacBook Pro 15" Mi/Fin 2007 (A1226 - EMC 2136) MacBook Pro 15" Fin 2006 (A1211 - EMC 2120) MacBook Pro 15" Original 2006 (A1150 - EMC 2101) -
Guide de réparation : ecran seul iPhone Air
Ce guide de réparation pour l'iPhone Air (2025) se concentre sur l'intervention la plus sollicitée : le remplacement de la dalle d'affichage. Que vous deviez corriger un écran brisé, une vitre fissurée ou un défaut d'affichage sur ce modèle ultra-fin, cette procédure pas à pas vous accompagne avec précision. En apprenant à transférer les composants sensibles comme la nappe Face ID, vous pourrez restaurer l'esthétique et la réactivité de votre smartphone sans passer par le service après-vente constructeur.
Compte tenu de sa finesse record de 5,6 mm, l'écran de l'iPhone Air est une pièce d'ingénierie aussi performante que délicate. À la suite d'un choc ou d'une pression excessive, des défauts peuvent apparaître : un tactile qui ne répond plus, des lignes colorées traversant la dalle OLED, ou un écran restant totalement noir malgré les vibrations de l'appareil. Ces pannes, bien qu'immobilisantes, ne signifient pas la fin de vie de votre iPhone.
Chez SOSav, nous prônons la durabilité. Remplacer un iPhone Air complet pour un simple bris de glace n'est pas une solution économiquement responsable. C’est pourquoi nous mettons à votre disposition notre savoir-faire technique pour vous permettre de réaliser cette réparation vous-même, en toute sérénité.
Pour faciliter cette manipulation sur un appareil aussi compact, notre manuel de démontage détaille chaque geste crucial. De l'ouverture délicate de la face avant jusqu'à la pose d'un nouveau joint d'étanchéité, ce guide vous épaule pour garantir une réparation propre et sécurisée, même pour les moins expérimentés.
Pourquoi changer vous-même l’écran de votre iPhone Air ?
L'intérêt est avant tout financier : vous évitez les forfaits de réparation premium souvent très onéreux pour ce modèle récent. C'est aussi un gain de temps considérable, vous évitant de vous séparer de votre outil de travail pendant plusieurs jours. Enfin, en choisissant de réparer, vous participez activement à la réduction des déchets électroniques et à la préservation des ressources nécessaires à la fabrication du titane et des composants de pointe.
Précaution importante : avant toute manipulation, réalisez une sauvegarde complète de vos données sur iCloud ou un ordinateur. Une attention particulière doit être portée à la nappe Face ID, indispensable à la sécurité biométrique de votre appareil.
Symptômes ou pannes traités dans ce tutoriel :
- Vitre Ceramic Shield 2 brisée ou fendue
- Tactile capricieux ou totalement inopérant
- Taches noires ou lignes de couleurs sur l'affichage OLED
- Luminosité défaillante ou scintillements de l'écran
- Décollement de la vitre suite à un choc
Réparer un iPhone Air demande une grande minutie, notamment lors de la récupération des capteurs de proximité et du Face ID sur l'ancienne dalle. Restaurer votre écran avec une pièce de qualité vous permettra de retrouver l'éclat des 3000 nits et la fluidité du 120Hz d'origine à un coût maîtrisé.
Aperçu des étapes de l'intervention :
Voici le déroulement chronologique pour remplacer votre bloc écran :
- Ouverture : Accès aux composants en soulevant délicatement la face avant.
- Déconnexion : Retrait des blindages et libération de l'écran défectueux.
- Transfert technique : Récupération méticuleuse de la nappe du capteur de proximité et du Face ID pour réinstallation sur le nouvel écran.
- Protection : Mise en place d'un nouveau joint d'étanchéité pour préserver l'indice IP68.
- Assemblage : Reconnexion de la nouvelle dalle et fermeture sécurisée de l'iPhone Air.
Écran (Qualité Soft OLED) - iPhone Air 119.90€ Voir le produit visibility
Ecran (Officiel) iPhone Air - Service Pack Apple
395.91€
Outils requis
Outil pour décoller la batterie d'un iPhone (avec stickers magnétiques) 8.91€ Voir le produit visibility
Décapeur thermique petit format
8.91€
Voir tous les outils
Pièces en option
Kit Outils Universel 8.91€ Voir le produit visibility
