MacBook Pro 13" 2022 M2 (A2338 EMC 8162) MacBook Pro 13" 2020 M1 (A2338 EMC 3578) MacBook Pro 13" 2020 (A2289 EMC 3456) MacBook Pro 13" 2020 (A2251 A2159 - EMC 3348) Macbook Pro 13" Retina Début 2019 (A1989 A2159) MacBook Pro 13" Mi 2018 (A1989 EMC 3214) MacBook Pro 13" Retina Mi 2017 (A1708 A1706) MacBook Pro 13" Retina Fin 2016 (A1708 A1706) MacBook Pro 13" Retina Début 2015 (A1502 - EMC 2835) MacBook Pro 13" Retina Mi 2014 (A1502 - EMC 2875) MacBook Pro 13" Retina Fin 2013 (A1502 - EMC 2678) MacBook Pro 13" Retina Début 2013 (A1425 - EMC 2672) MacBook Pro Retina 13" 2020 (A2338)MacBook Pro 13" Retina Fin 2012 (A1425 - EMC 2557) MacBook Pro 13" Unibody Mi 2012 (A1278 - EMC 2554) MacBook Pro 13" Unibody Fin 2011 (A1278 - EMC 2555) MacBook Pro 13" Unibody Début 2011 (A1278 - EMC 2419) MacBook Pro 13" Unibody Mi 2010 (A1278 - EMC 2351) MacBook Pro 13" Unibody Mi 2009 (A1278 - EMC 2326) MacBook Pro 13" Unibody Fin 2008 (A1278 - EMC 2254)Macbook Pro 14 pouces 2024 M4 Max (A3185) MacBook Pro 14 pouces 2024 M4 Pro (A3401) MacBook Pro 14 pouces 2024 M4 (A3112) Macbook Pro 14 pouces 2023 M3 Pro M3 Pro Max (A2992) Macbook Pro 14 pouces 2023 M3 (A2918) MacBook Pro 14 pouces 2023 M2 Pro M2 Max (A2779) MacBook Pro 14 pouces M1 Pro M1 Max 2021 (A2442)MacBook Pro 15" Retina Mi 2019 (A1990 - EMC 3359) MacBook Pro 15" Retina Mi 2018 (A1990 - EMC 3215) MacBook Pro 15" Retina Mi 2017 (A1707 - EMC 3162) MacBook Pro 15" Retina Fin 2016 (A1707 - EMC 3072) MacBook Pro 15" Retina Mi 2015 (A1398 - EMC 2909/2910) MacBook Pro 15" Retina Mi 2014 (A1398 - EMC 2876 & 2881) MacBook Pro 15" Retina fin 2013 (A1398 - EMC 2674 & 2745) MacBook Pro 15" Retina Début 2013 (A1398 - EMC 2673) MacBook Pro 15" Retina Mi 2012 (A1398 - EMC 2512) MacBook Pro 15" Unibody Mi 2012 (A1286 - EMC 2556)MacBook Pro 15" Unibody Fin 2011 (A1286 - EMC 2563) MacBook Pro 15" Unibody Début 2011 (A1286 - EMC 2353-1) MacBook Pro 15" Unibody Mi 2010 (A1286 - EMC 2353) MacBook Pro 15" Unibody Mi 2009 (A1286 - EMC 2324 & 2325) MacBook Pro 15" Unibody Début 2009 (A1286 - EMC 2255) MacBook Pro 15" Unibody Fin 2008 (A1286 - EMC 2255) MacBook Pro 15" Début 2008 (A1260 - EMC 2198) MacBook Pro 15" Mi/Fin 2007 (A1226 - EMC 2136) MacBook Pro 15" Fin 2006 (A1211 - EMC 2120) MacBook Pro 15" Original 2006 (A1150 - EMC 2101) -
Guide de réparation : Démontage complet iPhone Air
Le démontage intégral de l'iPhone Air (2025) est une opération de haute précision qui permet d'accéder à l'ensemble des technologies miniaturisées de ce modèle d'exception. Qu'il s'agisse de remplacer une batterie Li-Ion fatiguée, de restaurer la connectivité avec un nouveau module 5G ou de transférer la carte mère dans un nouveau châssis en titane, cette procédure est la solution ultime pour une réparation durable. En isolant chaque composant, des micros aux antennes réseau, vous avez la possibilité de cibler précisément chaque panne pour redonner toutes ses capacités à votre iPhone.
Avec seulement 5,6 mm d'épaisseur, l'architecture interne de l'iPhone Air est un chef-d'œuvre de densité. À la suite d'une immersion prolongée, d'un choc violent ou d'une défaillance logicielle persistante, plusieurs composants peuvent nécessiter une intervention : un connecteur de charge capricieux, des caméras qui ne font plus la mise au point ou des boutons latéraux qui ne répondent plus. Ce guide complet a été conçu pour vous permettre de naviguer dans cette structure complexe en toute sécurité.
Chez SOSav, nous croyons qu'aucun appareil, aussi technologique soit-il, ne devrait être jeté pour un composant défectueux. C’est pourquoi nos experts ont élaboré ce tutoriel détaillé, vous offrant une alternative économique et écologique aux services de remplacement standard. En réalisant vous-même l'intervention, vous reprenez le contrôle sur votre matériel.
Pour réussir cette manipulation sur l'iPhone le plus fin jamais conçu, notre manuel de démontage vous accompagne à chaque étape. De l'ouverture délicate de la vitre arrière en Ceramic Shield jusqu'à l'extraction de l'écran LTPO OLED, chaque geste est expliqué pour prévenir tout dommage sur les nappes ultra-fines qui parcourent le châssis.
Pourquoi choisir le démontage complet de votre iPhone Air ?
Cette approche permet de réaliser des économies majeures sur les pièces détachées et d'éviter les délais d'immobilisation en atelier. C'est aussi l'occasion unique de nettoyer les composants internes (comme les micros ou le haut-parleur) ou de remplacer des éléments spécifiques comme le vibreur ou l'antenne Bluetooth. Réparer plutôt que remplacer est un geste responsable qui minimise l'impact environnemental lié à la fabrication de nouveaux terminaux en titane et en terres rares.
Précaution importante : Avant de commencer, effectuez impérativement une sauvegarde de vos données. Le démontage complet implique le retrait de la carte mère, une étape cruciale qui nécessite calme et organisation pour ne perdre aucune des vis spécifiques.
Composants et pannes abordés dans ce guide :
- Batterie déchargée ou gonflée
- Problèmes de réseau (antennes 1, 2, WiFi ou module 5G)
- Défauts de capture (caméras frontale et dorsale)
- Son étouffé ou absent (micro principal, auxiliaire ou haut-parleur interne)
- Châssis ou boutons latéraux endommagés
- Écran OLED cassé ou vitre arrière fissurée
L'iPhone Air utilise des technologies de pointe comme la puce A19 Pro et des antennes à haute sensibilité. Restaurer ces éléments avec des pièces de qualité vous garantit de retrouver les performances d'origine de votre appareil tout en préservant son intégrité structurelle.
Voici la chronologie de l'intervention pour mettre l'appareil à nu :
- Accès initial : Ouverture par la vitre arrière et déconnexion de celle-ci après retrait de la batterie.
- Connectivité et Audio : Retrait du connecteur de charge, des micros (principal et auxiliaire), du vibreur et des antennes réseau (n°1 et n°2).
- Optique : Extraction des modules caméras arrière et avant.
- Cœur du système : Dépose du haut-parleur interne et retrait délicat de la carte mère.
- Réseaux avancés : Retrait des antennes Bluetooth, WiFi et du module spécifique 5G.
- Finitions : Démontage des boutons latéraux et extraction finale de l'écran.
Caméra avant - iPhone Air 80.91€ Voir le produit visibility
Caméra arrière - iPhone Air
89.91€
Outils requis
Outil pour décoller la batterie d'un iPhone (avec stickers magnétiques) 8.91€ Voir le produit visibility
Décapeur thermique petit format
8.91€
Voir tous les outils
Pièces en option
Kit Outils Universel 8.91€ Voir le produit visibility
