MacBook Pro 13" 2022 M2 (A2338 EMC 8162) MacBook Pro 13" 2020 M1 (A2338 EMC 3578) MacBook Pro 13" 2020 (A2289 EMC 3456) MacBook Pro 13" 2020 (A2251 A2159 - EMC 3348) Macbook Pro 13" Retina Début 2019 (A1989 A2159) MacBook Pro 13" Mi 2018 (A1989 EMC 3214) MacBook Pro 13" Retina Mi 2017 (A1708 A1706) MacBook Pro 13" Retina Fin 2016 (A1708 A1706) MacBook Pro 13" Retina Début 2015 (A1502 - EMC 2835) MacBook Pro 13" Retina Mi 2014 (A1502 - EMC 2875) MacBook Pro 13" Retina Fin 2013 (A1502 - EMC 2678) MacBook Pro 13" Retina Début 2013 (A1425 - EMC 2672) MacBook Pro Retina 13" 2020 (A2338)MacBook Pro 13" Retina Fin 2012 (A1425 - EMC 2557) MacBook Pro 13" Unibody Mi 2012 (A1278 - EMC 2554) MacBook Pro 13" Unibody Fin 2011 (A1278 - EMC 2555) MacBook Pro 13" Unibody Début 2011 (A1278 - EMC 2419) MacBook Pro 13" Unibody Mi 2010 (A1278 - EMC 2351) MacBook Pro 13" Unibody Mi 2009 (A1278 - EMC 2326) MacBook Pro 13" Unibody Fin 2008 (A1278 - EMC 2254)Macbook Pro 14 pouces 2024 M4 Max (A3185) MacBook Pro 14 pouces 2024 M4 Pro (A3401) MacBook Pro 14 pouces 2024 M4 (A3112) Macbook Pro 14 pouces 2023 M3 Pro M3 Pro Max (A2992) Macbook Pro 14 pouces 2023 M3 (A2918) MacBook Pro 14 pouces 2023 M2 Pro M2 Max (A2779) MacBook Pro 14 pouces M1 Pro M1 Max 2021 (A2442)MacBook Pro 15" Retina Mi 2019 (A1990 - EMC 3359) MacBook Pro 15" Retina Mi 2018 (A1990 - EMC 3215) MacBook Pro 15" Retina Mi 2017 (A1707 - EMC 3162) MacBook Pro 15" Retina Fin 2016 (A1707 - EMC 3072) MacBook Pro 15" Retina Mi 2015 (A1398 - EMC 2909/2910) MacBook Pro 15" Retina Mi 2014 (A1398 - EMC 2876 & 2881) MacBook Pro 15" Retina fin 2013 (A1398 - EMC 2674 & 2745) MacBook Pro 15" Retina Début 2013 (A1398 - EMC 2673) MacBook Pro 15" Retina Mi 2012 (A1398 - EMC 2512) MacBook Pro 15" Unibody Mi 2012 (A1286 - EMC 2556)MacBook Pro 15" Unibody Fin 2011 (A1286 - EMC 2563) MacBook Pro 15" Unibody Début 2011 (A1286 - EMC 2353-1) MacBook Pro 15" Unibody Mi 2010 (A1286 - EMC 2353) MacBook Pro 15" Unibody Mi 2009 (A1286 - EMC 2324 & 2325) MacBook Pro 15" Unibody Début 2009 (A1286 - EMC 2255) MacBook Pro 15" Unibody Fin 2008 (A1286 - EMC 2255) MacBook Pro 15" Début 2008 (A1260 - EMC 2198) MacBook Pro 15" Mi/Fin 2007 (A1226 - EMC 2136) MacBook Pro 15" Fin 2006 (A1211 - EMC 2120) MacBook Pro 15" Original 2006 (A1150 - EMC 2101) -
Guide de réparation : Batterie et sticker magnétique IPHONE 17 PRO
Après plusieurs mois ou années d’utilisation, la batterie de votre iPhone 17 Pro peut montrer des signes d’usure : autonomie en chute libre, extinctions inopinées malgré un pourcentage de charge restant, ou message « Entretien recommandé » affiché dans iOS. Le remplacement de la batterie vous permet de retrouver une autonomie neuve sans passer par un service après-vente coûteux.
Pourquoi réaliser soi-même la réparation de son iPhone 17 Pro ? Pour faire de belles économies, éviter les frais de main-d’œuvre parfois très élevés chez Apple et l’immobilisation prolongée de votre appareil. C’est aussi un geste pour la planète, qui permet de limiter les déchets électroniques.
Précaution importante : pensez à sauvegarder vos données via iCloud ou iTunes avant la manipulation.
Attention : Pour conserver la protection contre l’eau et la poussière, il est indispensable de remplacer le joint d’étanchéité lors du remontage. À noter également, la batterie est désormais maintenue par un sticker magnétique qui nécessite un outil spécifique de type Qantil pour être décollé proprement sans endommager la cellule ni le châssis.
Aperçu des étapes du remplacement de la batterie :
La réparation commence par le retrait de l’écran par chauffage progressif du pourtour du châssis. On procède ensuite au dévissage de la plaquette qui maintient la batterie, puis à la récupération de la plaquette grâce à l’outil Qantil qui permet de décoller le sticker magnétique sans forcer. Le remontage s’effectue en sens inverse : repose du sticker magnétique neuf, mise en place de la nouvelle batterie dans le châssis, puis remontage de l’écran avec joint d’étanchéité neuf pour préserver la certification IP68.
Votre appareil ne s’allume plus ou présente des arrêts fréquents
L’autonomie de la batterie est nettement réduite
Le sticker magnétique est décollé ou endommagé
Vous remarquez une surchauffe inhabituelle lors de l’utilisation
Des messages d’erreur liés à la batterie apparaissent à l’écran
