Xiaomi Pad
MacBook Pro 13" 2022 M2 (A2338 EMC 8162) MacBook Pro 13" 2020 M1 (A2338 EMC 3578) MacBook Pro 13" 2020 (A2289 EMC 3456) MacBook Pro 13" 2020 (A2251 A2159 - EMC 3348) Macbook Pro 13" Retina Début 2019 (A1989 A2159) MacBook Pro 13" Mi 2018 (A1989 EMC 3214) MacBook Pro 13" Retina Mi 2017 (A1708 A1706) MacBook Pro 13" Retina Fin 2016 (A1708 A1706) MacBook Pro 13" Retina Début 2015 (A1502 - EMC 2835) MacBook Pro 13" Retina Mi 2014 (A1502 - EMC 2875) MacBook Pro 13" Retina Fin 2013 (A1502 - EMC 2678) MacBook Pro 13" Retina Début 2013 (A1425 - EMC 2672) MacBook Pro Retina 13" 2020 (A2338)MacBook Pro 13" Retina Fin 2012 (A1425 - EMC 2557) MacBook Pro 13" Unibody Mi 2012 (A1278 - EMC 2554) MacBook Pro 13" Unibody Fin 2011 (A1278 - EMC 2555) MacBook Pro 13" Unibody Début 2011 (A1278 - EMC 2419) MacBook Pro 13" Unibody Mi 2010 (A1278 - EMC 2351) MacBook Pro 13" Unibody Mi 2009 (A1278 - EMC 2326) MacBook Pro 13" Unibody Fin 2008 (A1278 - EMC 2254)Macbook Pro 14 pouces 2024 M4 Max (A3185) MacBook Pro 14 pouces 2024 M4 Pro (A3401) MacBook Pro 14 pouces 2024 M4 (A3112) Macbook Pro 14 pouces 2023 M3 Pro M3 Pro Max (A2992) Macbook Pro 14 pouces 2023 M3 (A2918) MacBook Pro 14 pouces 2023 M2 Pro M2 Max (A2779) MacBook Pro 14 pouces M1 Pro M1 Max 2021 (A2442)MacBook Pro 15" Retina Mi 2019 (A1990 - EMC 3359) MacBook Pro 15" Retina Mi 2018 (A1990 - EMC 3215) MacBook Pro 15" Retina Mi 2017 (A1707 - EMC 3162) MacBook Pro 15" Retina Fin 2016 (A1707 - EMC 3072) MacBook Pro 15" Retina Mi 2015 (A1398 - EMC 2909/2910) MacBook Pro 15" Retina Mi 2014 (A1398 - EMC 2876 & 2881) MacBook Pro 15" Retina fin 2013 (A1398 - EMC 2674 & 2745) MacBook Pro 15" Retina Début 2013 (A1398 - EMC 2673) MacBook Pro 15" Retina Mi 2012 (A1398 - EMC 2512) MacBook Pro 15" Unibody Mi 2012 (A1286 - EMC 2556)MacBook Pro 15" Unibody Fin 2011 (A1286 - EMC 2563) MacBook Pro 15" Unibody Début 2011 (A1286 - EMC 2353-1) MacBook Pro 15" Unibody Mi 2010 (A1286 - EMC 2353) MacBook Pro 15" Unibody Mi 2009 (A1286 - EMC 2324 & 2325) MacBook Pro 15" Unibody Début 2009 (A1286 - EMC 2255) MacBook Pro 15" Unibody Fin 2008 (A1286 - EMC 2255) MacBook Pro 15" Début 2008 (A1260 - EMC 2198) MacBook Pro 15" Mi/Fin 2007 (A1226 - EMC 2136) MacBook Pro 15" Fin 2006 (A1211 - EMC 2120) MacBook Pro 15" Original 2006 (A1150 - EMC 2101) -
Guide de réparation : Vitre arrière, batterie, vibreur et HP iPhone 16 Pro max
Ce guide de réparation pour l'iPhone 16 Pro Max regroupe quatre interventions essentielles, accessibles via l'ouverture par la face arrière : le remplacement de la vitre arrière, de la batterie, du vibreur (Taptic Engine) et du haut-parleur externe. Que vous ayez subi un bris de verre au dos, une perte d'autonomie, une absence de vibrations ou un son grésillant, cette procédure pas à pas vous permet de cibler chaque composant et de remettre votre smartphone en parfait état de marche.
L'iPhone 16 Pro Max, avec son dos en verre et son châssis en titane de grade 5, reste exposé aux chocs malgré sa robustesse. Une vitre arrière fissurée, une batterie qui se vide trop vite, un Taptic Engine muet ou un haut-parleur étouffé sont autant de pannes courantes qui rendent l'expérience utilisateur frustrante. Bonne nouvelle : Apple a introduit sur cette génération un nouvel adhésif batterie à activation électrique, qui simplifie considérablement le retrait de la cellule lors du démontage.
Chez SOSav, nous prônons la durabilité. Remplacer un iPhone 16 Pro Max complet pour une seule pièce défaillante n'est pas une solution économiquement responsable. C'est pourquoi nous mettons à votre disposition notre savoir-faire technique pour vous permettre de réaliser ces réparations vous-même, en toute sérénité. Notre manuel de démontage détaille chaque geste crucial, de l'ouverture par l'arrière jusqu'à la pose d'un nouveau joint d'étanchéité, pour garantir une réparation propre et sécurisée, même pour les moins expérimentés.
Pourquoi réaliser vous-même ces réparations sur votre iPhone 16 Pro Max ?
L'intérêt est avant tout financier : vous évitez les forfaits de réparation premium souvent très onéreux pour ce modèle haut de gamme, surtout lorsque plusieurs pièces sont à changer. C'est aussi un gain de temps considérable, vous évitant de vous séparer de votre appareil pendant plusieurs jours. Enfin, en choisissant de réparer, vous participez activement à la réduction des déchets électroniques et à la préservation des ressources nécessaires à la fabrication du titane et des composants de pointe.
Précaution importante : avant toute manipulation, réalisez une sauvegarde complète de vos données sur iCloud ou un ordinateur. Une attention particulière doit être portée aux nappes internes et au remplacement des joints d'étanchéité pour préserver la certification IP68.
Symptômes ou pannes traités dans ce tutoriel :
- Vitre arrière brisée, fissurée ou éclatée
- Autonomie en chute libre, extinctions inopinées ou état de batterie inférieur à 80 %
- Batterie gonflée déformant la coque arrière
- Charge rapide ou MagSafe 25W qui ne fonctionne plus correctement
- Absence totale de vibrations ou vibrations irrégulières
- Retours haptiques inopérants lors des interactions tactiles
- Cliquetis ou bruit métallique provenant du Taptic Engine
- Haut-parleur externe muet, grésillant ou volume anormalement faible
- Son étouffé en lecture multimédia ou en mode haut-parleur
Réparer un iPhone 16 Pro Max par l'arrière offre l'avantage d'un accès direct aux composants principaux sans toucher à l'écran. Avec des pièces de rechange de qualité, vous retrouverez l'autonomie, les vibrations précises et le son puissant d'origine à un coût maîtrisé.
Aperçu des étapes de l'intervention :
Voici le déroulement chronologique pour mener à bien ces quatre réparations :
- Ouverture : Décollage de la vitre arrière en verre par chauffage progressif.
- Sécurité : Déconnexion immédiate de la batterie pour éviter tout court-circuit.
- Retrait de la batterie : Activation électrique du nouvel adhésif pour faciliter le décollage de la cellule.
- Vibreur : Démontage du Taptic Engine et remplacement par un module neuf.
- Haut-parleur externe : Dépose et substitution du module audio en partie basse.
- Vitre arrière : Préparation de la nouvelle vitre et application de l'adhésif périphérique.
- Protection : Mise en place d'un nouveau joint d'étanchéité pour préserver l'indice IP68.
- Assemblage : Reconnexion des nappes et fermeture sécurisée de l'iPhone 16 Pro Max.
Kit Outils Universel 8.91€ Voir le produit visibility
