MacBook Pro 13" 2022 M2 (A2338 EMC 8162) MacBook Pro 13" 2020 M1 (A2338 EMC 3578) MacBook Pro 13" 2020 (A2289 EMC 3456) MacBook Pro 13" 2020 (A2251 A2159 - EMC 3348) Macbook Pro 13" Retina Début 2019 (A1989 A2159) MacBook Pro 13" Mi 2018 (A1989 EMC 3214) MacBook Pro 13" Retina Mi 2017 (A1708 A1706) MacBook Pro 13" Retina Fin 2016 (A1708 A1706) MacBook Pro 13" Retina Début 2015 (A1502 - EMC 2835) MacBook Pro 13" Retina Mi 2014 (A1502 - EMC 2875) MacBook Pro 13" Retina Fin 2013 (A1502 - EMC 2678) MacBook Pro 13" Retina Début 2013 (A1425 - EMC 2672) MacBook Pro Retina 13" 2020 (A2338)MacBook Pro 13" Retina Fin 2012 (A1425 - EMC 2557) MacBook Pro 13" Unibody Mi 2012 (A1278 - EMC 2554) MacBook Pro 13" Unibody Fin 2011 (A1278 - EMC 2555) MacBook Pro 13" Unibody Début 2011 (A1278 - EMC 2419) MacBook Pro 13" Unibody Mi 2010 (A1278 - EMC 2351) MacBook Pro 13" Unibody Mi 2009 (A1278 - EMC 2326) MacBook Pro 13" Unibody Fin 2008 (A1278 - EMC 2254)Macbook Pro 14 pouces 2024 M4 Max (A3185) MacBook Pro 14 pouces 2024 M4 Pro (A3401) MacBook Pro 14 pouces 2024 M4 (A3112) Macbook Pro 14 pouces 2023 M3 Pro M3 Pro Max (A2992) Macbook Pro 14 pouces 2023 M3 (A2918) MacBook Pro 14 pouces 2023 M2 Pro M2 Max (A2779) MacBook Pro 14 pouces M1 Pro M1 Max 2021 (A2442)MacBook Pro 15" Retina Mi 2019 (A1990 - EMC 3359) MacBook Pro 15" Retina Mi 2018 (A1990 - EMC 3215) MacBook Pro 15" Retina Mi 2017 (A1707 - EMC 3162) MacBook Pro 15" Retina Fin 2016 (A1707 - EMC 3072) MacBook Pro 15" Retina Mi 2015 (A1398 - EMC 2909/2910) MacBook Pro 15" Retina Mi 2014 (A1398 - EMC 2876 & 2881) MacBook Pro 15" Retina fin 2013 (A1398 - EMC 2674 & 2745) MacBook Pro 15" Retina Début 2013 (A1398 - EMC 2673) MacBook Pro 15" Retina Mi 2012 (A1398 - EMC 2512) MacBook Pro 15" Unibody Mi 2012 (A1286 - EMC 2556)MacBook Pro 15" Unibody Fin 2011 (A1286 - EMC 2563) MacBook Pro 15" Unibody Début 2011 (A1286 - EMC 2353-1) MacBook Pro 15" Unibody Mi 2010 (A1286 - EMC 2353) MacBook Pro 15" Unibody Mi 2009 (A1286 - EMC 2324 & 2325) MacBook Pro 15" Unibody Début 2009 (A1286 - EMC 2255) MacBook Pro 15" Unibody Fin 2008 (A1286 - EMC 2255) MacBook Pro 15" Début 2008 (A1260 - EMC 2198) MacBook Pro 15" Mi/Fin 2007 (A1226 - EMC 2136) MacBook Pro 15" Fin 2006 (A1211 - EMC 2120) MacBook Pro 15" Original 2006 (A1150 - EMC 2101) -
Guide de réparation : Ecran, haut-parleurs, vibreur et batterie iPhone 15 Pro max
Votre iPhone 15 Pro Max vous joue des tours ? Écran fissuré, haut-parleur qui grésille, vibreur hors service ou batterie qui ne tient plus la journée ? Ces désagréments rendent vite l'utilisation de votre smartphone pénible et gâchent votre expérience au quotidien ? Pas d'inquiétude, vous êtes au bon endroit pour remettre votre iPhone en état !
Les experts de SOSav vous ont concocté un guide de réparation complet, illustré et commenté étape par étape, qui regroupe quatre interventions essentielles sur votre iPhone 15 Pro Max : le remplacement de l'écran, du haut-parleur, du vibreur (Taptic Engine) et de la batterie. Un tutoriel tout-en-un pensé pour vous accompagner facilement, même sans être un spécialiste de la tech.
Suivez nos instructions claires pour effectuer ces réparations vous-même, faire de vraies économies par rapport à un passage en boutique officielle, et offrir une seconde vie à votre appareil. Un beau geste pour votre portefeuille… et pour la planète !
Bon à savoir :
Sur l'iPhone 15 Pro Max, le remplacement de l'écran nécessite le transfert du bloc Face ID et de la nappe de proximité sur la nouvelle dalle afin de conserver toutes les fonctionnalités d'origine. La batterie est quant à elle maintenue par des adhésifs en tirette à retirer avec précaution. Rassurez-vous, chaque manipulation est expliquée en détail dans notre tutoriel pas à pas.
Avant de commencer, pensez à sauvegarder l'ensemble de vos données pour éviter toute perte en cas de mauvaise manipulation.
Symptômes fréquents :
- Écran cassé, fissuré ou rayé
- Écran noir ou affichage défectueux (bandes colorées, pixels morts)
- Tactile qui ne répond plus correctement
- Son grésillant, étouffé ou haut-parleur totalement muet
- Volume anormalement faible lors des appels ou en lecture multimédia
- Absence de vibrations ou vibrations irrégulières
- Retours haptiques inopérants lors des interactions tactiles
- Autonomie qui chute brutalement ou extinctions inattendues
- Recharge anormalement longue ou batterie gonflée
- État de la batterie inférieur à 80 % dans les réglages
Questions fréquentes sur le remplacement de l'écran :
Le Face ID fonctionnera-t-il toujours après le changement d'écran ?
Oui, à condition de bien transférer le bloc de capteurs (caméra TrueDepth, projecteur de points, capteur de proximité) de votre ancien écran vers le nouveau. Ces composants sont appairés à votre carte mère et ne peuvent pas être remplacés. Notre tutoriel détaille précisément cette étape délicate mais incontournable.
Vais-je perdre la fonction True Tone après la réparation ?
C'est possible avec un écran compatible non original, iOS affichant un message signalant l'origine de la pièce. L'écran reste cependant pleinement fonctionnel : luminosité, tactile et Dynamic Island continuent de marcher normalement.
Peut-on remplacer uniquement la vitre ou faut-il changer tout l'écran ?
Sur l'iPhone 15 Pro Max, la vitre et la dalle OLED sont fusionnées. Il est donc nécessaire de remplacer l'écran complet pour garantir un résultat fiable et durable.
Questions fréquentes sur le remplacement du haut-parleur :
Mon haut-parleur grésille, est-ce forcément une panne matérielle ?
Pas toujours. Commencez par nettoyer la grille avec une brosse souple et vérifier les réglages audio (volume, égaliseur, mode mono). Si le grésillement persiste, la membrane est probablement abîmée et le haut-parleur doit être remplacé.
La réparation concerne-t-elle aussi l'écouteur interne pour les appels ?
Non, le haut-parleur principal se situe en bas de l'appareil et sert à la lecture multimédia et au mode main libre. L'écouteur d'appel, logé en haut près du Face ID, est une pièce distincte.
L'effet stéréo sera-t-il conservé après remplacement ?
Oui, tant que le haut-parleur principal installé est compatible avec l'iPhone 15 Pro Max, le rendu stéréo (qui combine le haut-parleur du bas et l'écouteur du haut) reste intact.
Questions fréquentes sur le remplacement du vibreur (Taptic Engine) :
Qu'est-ce que le Taptic Engine exactement ?
Il s'agit du module de vibration avancé d'Apple, qui gère à la fois les vibrations classiques (notifications, appels) et tous les retours haptiques ressentis lors des interactions avec l'écran (clavier, appui long sur certaines icônes, etc.).
Pourquoi mon vibreur émet-il un cliquetis ou un bruit métallique ?
Ce bruit provient souvent d'une fixation desserrée ou d'un composant interne endommagé après un choc. Dans ce cas, le remplacement du Taptic Engine est la solution la plus fiable.
Les retours haptiques fonctionneront-ils comme avant ?
Oui, à condition d'installer une pièce compatible de qualité. Les vibrations et les retours tactiles retrouvent leur précision d'origine après le remplacement.
Questions fréquentes sur le remplacement de la batterie :
Comment savoir si ma batterie a vraiment besoin d'être changée ?
Rendez-vous dans Réglages > Batterie > État de la batterie. En dessous de 80 % de capacité maximale, ou si le message « Entretien batterie » apparaît, le remplacement devient pertinent. Des extinctions soudaines et une autonomie en chute libre sont également des signes révélateurs.
Le message « Batterie inconnue » va-t-il s'afficher après le remplacement ?
Avec une batterie compatible non originale, iOS peut effectivement afficher un message concernant l'origine de la pièce. La batterie reste toutefois entièrement fonctionnelle et fournit la même autonomie, seul le suivi de santé détaillé peut être limité.
Comment retirer les adhésifs en tirette sans les casser ?
Il faut tirer la bande doucement, à plat et dans un angle faible par rapport à la batterie. En cas de casse, un peu de chaleur douce et de l'alcool isopropylique permettent de décoller la batterie sans forcer. Notre tutoriel illustre précisément la bonne technique.
Combien de temps dure la nouvelle batterie ?
Une batterie compatible de qualité offre des performances équivalentes à celles d'origine, avec une durée de vie d'environ 500 à 1000 cycles de recharge selon l'usage, soit en moyenne 2 à 3 ans d'utilisation normale.
Kit Outils Universel 8.91€ Voir le produit visibility
