MacBook Pro 13" 2022 M2 (A2338 EMC 8162) MacBook Pro 13" 2020 M1 (A2338 EMC 3578) MacBook Pro 13" 2020 (A2289 EMC 3456) MacBook Pro 13" 2020 (A2251 A2159 - EMC 3348) Macbook Pro 13" Retina Début 2019 (A1989 A2159) MacBook Pro 13" Mi 2018 (A1989 EMC 3214) MacBook Pro 13" Retina Mi 2017 (A1708 A1706) MacBook Pro 13" Retina Fin 2016 (A1708 A1706) MacBook Pro 13" Retina Début 2015 (A1502 - EMC 2835) MacBook Pro 13" Retina Mi 2014 (A1502 - EMC 2875) MacBook Pro 13" Retina Fin 2013 (A1502 - EMC 2678) MacBook Pro 13" Retina Début 2013 (A1425 - EMC 2672) MacBook Pro Retina 13" 2020 (A2338)MacBook Pro 13" Retina Fin 2012 (A1425 - EMC 2557) MacBook Pro 13" Unibody Mi 2012 (A1278 - EMC 2554) MacBook Pro 13" Unibody Fin 2011 (A1278 - EMC 2555) MacBook Pro 13" Unibody Début 2011 (A1278 - EMC 2419) MacBook Pro 13" Unibody Mi 2010 (A1278 - EMC 2351) MacBook Pro 13" Unibody Mi 2009 (A1278 - EMC 2326) MacBook Pro 13" Unibody Fin 2008 (A1278 - EMC 2254)Macbook Pro 14 pouces 2024 M4 Max (A3185) MacBook Pro 14 pouces 2024 M4 Pro (A3401) MacBook Pro 14 pouces 2024 M4 (A3112) Macbook Pro 14 pouces 2023 M3 Pro M3 Pro Max (A2992) Macbook Pro 14 pouces 2023 M3 (A2918) MacBook Pro 14 pouces 2023 M2 Pro M2 Max (A2779) MacBook Pro 14 pouces M1 Pro M1 Max 2021 (A2442)MacBook Pro 15" Retina Mi 2019 (A1990 - EMC 3359) MacBook Pro 15" Retina Mi 2018 (A1990 - EMC 3215) MacBook Pro 15" Retina Mi 2017 (A1707 - EMC 3162) MacBook Pro 15" Retina Fin 2016 (A1707 - EMC 3072) MacBook Pro 15" Retina Mi 2015 (A1398 - EMC 2909/2910) MacBook Pro 15" Retina Mi 2014 (A1398 - EMC 2876 & 2881) MacBook Pro 15" Retina fin 2013 (A1398 - EMC 2674 & 2745) MacBook Pro 15" Retina Début 2013 (A1398 - EMC 2673) MacBook Pro 15" Retina Mi 2012 (A1398 - EMC 2512) MacBook Pro 15" Unibody Mi 2012 (A1286 - EMC 2556)MacBook Pro 15" Unibody Fin 2011 (A1286 - EMC 2563) MacBook Pro 15" Unibody Début 2011 (A1286 - EMC 2353-1) MacBook Pro 15" Unibody Mi 2010 (A1286 - EMC 2353) MacBook Pro 15" Unibody Mi 2009 (A1286 - EMC 2324 & 2325) MacBook Pro 15" Unibody Début 2009 (A1286 - EMC 2255) MacBook Pro 15" Unibody Fin 2008 (A1286 - EMC 2255) MacBook Pro 15" Début 2008 (A1260 - EMC 2198) MacBook Pro 15" Mi/Fin 2007 (A1226 - EMC 2136) MacBook Pro 15" Fin 2006 (A1211 - EMC 2120) MacBook Pro 15" Original 2006 (A1150 - EMC 2101) -
Guide de réparation : Démontage complet Google Pixel 7
Le démontage complet du Google Pixel 7 permet d'accéder à tous les composants de l'appareil pour les remplacer un par un : batterie 4355 mAh, haut-parleur interne, modules caméras ou carte mère.
Particularité importante : le Pixel 7 s'ouvre par l'écran (et non par la vitre arrière). Le connecteur de charge est une pièce soudée à la carte mère et nécessite du matériel de dessoudage spécifique.
Outillage recommandé : notre kit outils spécial n°4 contient le tournevis Torx et les accessoires nécessaires.
Précaution importante : pensez à sauvegarder vos données personnelles avant la manipulation.
Attention : le Pixel 7 est certifié IP68. Remplacez les joints d'étanchéité et les adhésifs de l'écran lors du remontage.
- Batterie qui gonfle ou autonomie en chute libre
- Charge rapide 20W filaire ou sans fil défaillante
- Photos floues ou OIS défaillant sur le capteur 50 Mpx
- Ultra grand-angle 12 Mpx ou caméra frontale hors service
- Haut-parleurs muets ou grésillants
- Lecteur d'empreintes sous écran qui ne répond plus
- Ouverture : Retrait de l'écran par chauffage progressif.
- Écran : Déconnexion de la nappe de l'écran.
- Protection : Retrait de la plaquette de protection.
- Extraction de l'énergie : Déconnexion et retrait de la batterie 4355 mAh.
- Protections : Retrait des plaquettes de protection restantes.
- Modules photo : Retrait des objectifs photo (50 Mpx et ultra grand-angle 12 Mpx).
- Audio interne : Retrait du haut-parleur interne.
- Cœur du système : Déconnexion et retrait de la carte mère (Google Tensor G2).
- Remontage : Repose des composants internes, de la batterie et de la plaquette de protection.
- Finalisation : Remontage de l'écran et fermeture du Pixel 7 avec adhésif neuf.
Kit outils Spécial - N°4 7.11€ Voir le produit visibility
