MacBook Pro 13" 2022 M2 (A2338 EMC 8162) MacBook Pro 13" 2020 M1 (A2338 EMC 3578) MacBook Pro 13" 2020 (A2289 EMC 3456) MacBook Pro 13" 2020 (A2251 A2159 - EMC 3348) Macbook Pro 13" Retina Début 2019 (A1989 A2159) MacBook Pro 13" Mi 2018 (A1989 EMC 3214) MacBook Pro 13" Retina Mi 2017 (A1708 A1706) MacBook Pro 13" Retina Fin 2016 (A1708 A1706) MacBook Pro 13" Retina Début 2015 (A1502 - EMC 2835) MacBook Pro 13" Retina Mi 2014 (A1502 - EMC 2875) MacBook Pro 13" Retina Fin 2013 (A1502 - EMC 2678) MacBook Pro 13" Retina Début 2013 (A1425 - EMC 2672) MacBook Pro Retina 13" 2020 (A2338)MacBook Pro 13" Retina Fin 2012 (A1425 - EMC 2557) MacBook Pro 13" Unibody Mi 2012 (A1278 - EMC 2554) MacBook Pro 13" Unibody Fin 2011 (A1278 - EMC 2555) MacBook Pro 13" Unibody Début 2011 (A1278 - EMC 2419) MacBook Pro 13" Unibody Mi 2010 (A1278 - EMC 2351) MacBook Pro 13" Unibody Mi 2009 (A1278 - EMC 2326) MacBook Pro 13" Unibody Fin 2008 (A1278 - EMC 2254)Macbook Pro 14 pouces 2024 M4 Max (A3185) MacBook Pro 14 pouces 2024 M4 Pro (A3401) MacBook Pro 14 pouces 2024 M4 (A3112) Macbook Pro 14 pouces 2023 M3 Pro M3 Pro Max (A2992) Macbook Pro 14 pouces 2023 M3 (A2918) MacBook Pro 14 pouces 2023 M2 Pro M2 Max (A2779) MacBook Pro 14 pouces M1 Pro M1 Max 2021 (A2442)MacBook Pro 15" Retina Mi 2019 (A1990 - EMC 3359) MacBook Pro 15" Retina Mi 2018 (A1990 - EMC 3215) MacBook Pro 15" Retina Mi 2017 (A1707 - EMC 3162) MacBook Pro 15" Retina Fin 2016 (A1707 - EMC 3072) MacBook Pro 15" Retina Mi 2015 (A1398 - EMC 2909/2910) MacBook Pro 15" Retina Mi 2014 (A1398 - EMC 2876 & 2881) MacBook Pro 15" Retina fin 2013 (A1398 - EMC 2674 & 2745) MacBook Pro 15" Retina Début 2013 (A1398 - EMC 2673) MacBook Pro 15" Retina Mi 2012 (A1398 - EMC 2512) MacBook Pro 15" Unibody Mi 2012 (A1286 - EMC 2556)MacBook Pro 15" Unibody Fin 2011 (A1286 - EMC 2563) MacBook Pro 15" Unibody Début 2011 (A1286 - EMC 2353-1) MacBook Pro 15" Unibody Mi 2010 (A1286 - EMC 2353) MacBook Pro 15" Unibody Mi 2009 (A1286 - EMC 2324 & 2325) MacBook Pro 15" Unibody Début 2009 (A1286 - EMC 2255) MacBook Pro 15" Unibody Fin 2008 (A1286 - EMC 2255) MacBook Pro 15" Début 2008 (A1260 - EMC 2198) MacBook Pro 15" Mi/Fin 2007 (A1226 - EMC 2136) MacBook Pro 15" Fin 2006 (A1211 - EMC 2120) MacBook Pro 15" Original 2006 (A1150 - EMC 2101) -
Guide de réparation : Batterie MacBook Pro 13" 2020 A2251
Après plusieurs années d'utilisation, la batterie de votre MacBook Pro 13" 2020 (A2251) peut montrer des signes d'usure. Vous remarquerez peut-être que l'autonomie chute brutalement, que l'ordinateur s'éteint tout seul même avec un pourcentage de charge restant, ou que la charge devient capricieuse. Il arrive aussi que macOS affiche le message « Entretien recommandé » dans les préférences de batterie, signe que la cellule a perdu une partie significative de sa capacité. Une batterie gonflée peut également déformer la coque inférieure ou faire remonter le trackpad, ce qui pose un vrai problème de sécurité.
Pourquoi remplacer soi-même la batterie de son MacBook Pro 13" 2020 ?
Pour faire de belles économies, éviter les frais de main-d'œuvre parfois très élevés chez Apple et l'immobilisation prolongée de votre ordinateur. C'est aussi un geste pour la planète, qui permet de limiter les déchets électroniques.
Précaution importante : pensez à sauvegarder vos données via Time Machine ou iCloud avant la manipulation.
Signes d'une batterie à remplacer :
- Autonomie qui diminue rapidement (moins de la moitié des 10 h annoncées)
- MacBook qui s'éteint sans prévenir, même avec de la charge restante
- Message « Entretien recommandé » affiché dans macOS
- État de la batterie inférieur à 80 % dans les préférences système
- Nombre de cycles supérieur à 1000
- Temps de recharge anormalement long
- Batterie gonflée déformant la coque inférieure ou faisant remonter le trackpad
- MacBook qui ne s'allume plus sans être branché au secteur
Aperçu des étapes du remplacement de la batterie :
- Ouverture : Retrait de la coque arrière du MacBook à l'aide d'un tournevis Pentalobe P5.
- Sécurité : Déconnexion de la batterie pour éviter tout court-circuit.
- Trackpad : Retrait du trackpad pour accéder à la batterie.
- Extraction : Retrait de la batterie Li-Po 58,2 Wh.
- Pose : Mise en place de la nouvelle batterie.
- Trackpad : Remontage du trackpad.
- Reconnexion : Rebranchement de la batterie.
- Finalisation : Fermeture du MacBook après vérification.
Kit Outils Mac (MacBook, MacBook Pro...) 17.91€ Voir le produit visibility
Batterie A2171 - Macbook Pro 13 62.91€ Voir le produit visibility
