Xiaomi Pad
MacBook Pro 13" 2022 M2 (A2338 EMC 8162) MacBook Pro 13" 2020 M1 (A2338 EMC 3578) MacBook Pro 13" 2020 (A2289 EMC 3456) MacBook Pro 13" 2020 (A2251 A2159 - EMC 3348) Macbook Pro 13" Retina Début 2019 (A1989 A2159) MacBook Pro 13" Mi 2018 (A1989 EMC 3214) MacBook Pro 13" Retina Mi 2017 (A1708 A1706) MacBook Pro 13" Retina Fin 2016 (A1708 A1706) MacBook Pro 13" Retina Début 2015 (A1502 - EMC 2835) MacBook Pro 13" Retina Mi 2014 (A1502 - EMC 2875) MacBook Pro 13" Retina Fin 2013 (A1502 - EMC 2678) MacBook Pro 13" Retina Début 2013 (A1425 - EMC 2672) MacBook Pro Retina 13" 2020 (A2338)MacBook Pro 13" Retina Fin 2012 (A1425 - EMC 2557) MacBook Pro 13" Unibody Mi 2012 (A1278 - EMC 2554) MacBook Pro 13" Unibody Fin 2011 (A1278 - EMC 2555) MacBook Pro 13" Unibody Début 2011 (A1278 - EMC 2419) MacBook Pro 13" Unibody Mi 2010 (A1278 - EMC 2351) MacBook Pro 13" Unibody Mi 2009 (A1278 - EMC 2326) MacBook Pro 13" Unibody Fin 2008 (A1278 - EMC 2254)Macbook Pro 14 pouces 2024 M4 Max (A3185) MacBook Pro 14 pouces 2024 M4 Pro (A3401) MacBook Pro 14 pouces 2024 M4 (A3112) Macbook Pro 14 pouces 2023 M3 Pro M3 Pro Max (A2992) Macbook Pro 14 pouces 2023 M3 (A2918) MacBook Pro 14 pouces 2023 M2 Pro M2 Max (A2779) MacBook Pro 14 pouces M1 Pro M1 Max 2021 (A2442)MacBook Pro 15" Retina Mi 2019 (A1990 - EMC 3359) MacBook Pro 15" Retina Mi 2018 (A1990 - EMC 3215) MacBook Pro 15" Retina Mi 2017 (A1707 - EMC 3162) MacBook Pro 15" Retina Fin 2016 (A1707 - EMC 3072) MacBook Pro 15" Retina Mi 2015 (A1398 - EMC 2909/2910) MacBook Pro 15" Retina Mi 2014 (A1398 - EMC 2876 & 2881) MacBook Pro 15" Retina fin 2013 (A1398 - EMC 2674 & 2745) MacBook Pro 15" Retina Début 2013 (A1398 - EMC 2673) MacBook Pro 15" Retina Mi 2012 (A1398 - EMC 2512) MacBook Pro 15" Unibody Mi 2012 (A1286 - EMC 2556)MacBook Pro 15" Unibody Fin 2011 (A1286 - EMC 2563) MacBook Pro 15" Unibody Début 2011 (A1286 - EMC 2353-1) MacBook Pro 15" Unibody Mi 2010 (A1286 - EMC 2353) MacBook Pro 15" Unibody Mi 2009 (A1286 - EMC 2324 & 2325) MacBook Pro 15" Unibody Début 2009 (A1286 - EMC 2255) MacBook Pro 15" Unibody Fin 2008 (A1286 - EMC 2255) MacBook Pro 15" Début 2008 (A1260 - EMC 2198) MacBook Pro 15" Mi/Fin 2007 (A1226 - EMC 2136) MacBook Pro 15" Fin 2006 (A1211 - EMC 2120) MacBook Pro 15" Original 2006 (A1150 - EMC 2101) -
Guide de réparation : Batterie MacBook Air 13" 2020 M1 A2337-EMC 3598
Après plusieurs années d'utilisation, la batterie de votre MacBook Air 13" 2020 M1 peut montrer des signes d'usure. Vous remarquerez peut-être que l'autonomie chute brutalement, que l'ordinateur s'éteint tout seul même avec un pourcentage de charge restant, ou que la charge devient capricieuse. Il arrive aussi que macOS affiche le message « Entretien recommandé » dans les préférences de batterie, signe que la cellule a perdu une partie significative de sa capacité. Une batterie gonflée peut également déformer la coque inférieure ou le trackpad, ce qui pose un vrai problème de sécurité. Sans une batterie fiable, il devient difficile de profiter pleinement de la mobilité de votre MacBook.
Chez SOSav, nous savons que les batteries Li-Po, y compris celle du MacBook Air M1 2020 (référence A2389, 49,9 Wh) prévue pour environ 1000 cycles de charge, finissent par s'user au fil du temps. Pas besoin pour autant de changer tout l'appareil. Nous vous proposons une solution simple et économique : remplacez vous-même la batterie, en suivant nos tutoriels pas à pas pensés pour tous les niveaux.
Pour vous aider à changer la batterie de votre MacBook Air 13" M1, nous avons préparé un guide étape par étape. Illustré par des photos claires, il vous accompagne tout au long de l'opération, que vous soyez débutant ou habitué aux réparations d'ordinateurs portables.
Pourquoi remplacer soi-même la batterie du MacBook Air M1 ?
Avant tout pour faire de belles économies. Pas besoin de passer par un Apple Store ou un atelier agréé, dont les tarifs peuvent dépasser les 150 €. En réalisant l'échange vous-même, vous évitez les frais de main-d'œuvre ainsi que les délais d'attente souvent longs des services après-vente. C'est aussi un geste pour la planète, qui permet de limiter les déchets électroniques.
Avant de commencer, pensez à sauvegarder vos données via Time Machine ou iCloud pour éviter toute perte pendant la manipulation.
Signes d'une batterie à remplacer :
- Autonomie qui diminue rapidement (moins de la moitié des 18 h annoncées)
- MacBook qui s'éteint sans prévenir, même avec de la charge restante
- Message « Entretien recommandé » affiché dans macOS
- État de la batterie inférieur à 80 % dans les préférences système
- Nombre de cycles supérieur à 1000
- Temps de recharge anormalement long
- Batterie gonflée déformant la coque inférieure ou le trackpad
- MacBook qui ne s'allume plus sans être branché au secteur
Le MacBook Air 13" M1 est équipé d'une batterie Li-Po A2389 de 49,9 Wh (11,39 V, 4380 mAh), conçue pour offrir jusqu'à 18 heures d'autonomie en lecture vidéo. Avec les bons outils et une batterie compatible de qualité, vous pourrez redonner un second souffle à votre MacBook sans vous ruiner, et continuer à l'utiliser sereinement pour de longues années.
Kit Outils Mac (MacBook, MacBook Pro...) 17.91€ Voir le produit visibility
