Xiaomi Pad
MacBook Pro 13" 2022 M2 (A2338 EMC 8162) MacBook Pro 13" 2020 M1 (A2338 EMC 3578) MacBook Pro 13" 2020 (A2289 EMC 3456) MacBook Pro 13" 2020 (A2251 A2159 - EMC 3348) Macbook Pro 13" Retina Début 2019 (A1989 A2159) MacBook Pro 13" Mi 2018 (A1989 EMC 3214) MacBook Pro 13" Retina Mi 2017 (A1708 A1706) MacBook Pro 13" Retina Fin 2016 (A1708 A1706) MacBook Pro 13" Retina Début 2015 (A1502 - EMC 2835) MacBook Pro 13" Retina Mi 2014 (A1502 - EMC 2875) MacBook Pro 13" Retina Fin 2013 (A1502 - EMC 2678) MacBook Pro 13" Retina Début 2013 (A1425 - EMC 2672) MacBook Pro Retina 13" 2020 (A2338)MacBook Pro 13" Retina Fin 2012 (A1425 - EMC 2557) MacBook Pro 13" Unibody Mi 2012 (A1278 - EMC 2554) MacBook Pro 13" Unibody Fin 2011 (A1278 - EMC 2555) MacBook Pro 13" Unibody Début 2011 (A1278 - EMC 2419) MacBook Pro 13" Unibody Mi 2010 (A1278 - EMC 2351) MacBook Pro 13" Unibody Mi 2009 (A1278 - EMC 2326) MacBook Pro 13" Unibody Fin 2008 (A1278 - EMC 2254)Macbook Pro 14 pouces 2024 M4 Max (A3185) MacBook Pro 14 pouces 2024 M4 Pro (A3401) MacBook Pro 14 pouces 2024 M4 (A3112) Macbook Pro 14 pouces 2023 M3 Pro M3 Pro Max (A2992) Macbook Pro 14 pouces 2023 M3 (A2918) MacBook Pro 14 pouces 2023 M2 Pro M2 Max (A2779) MacBook Pro 14 pouces M1 Pro M1 Max 2021 (A2442)MacBook Pro 15" Retina Mi 2019 (A1990 - EMC 3359) MacBook Pro 15" Retina Mi 2018 (A1990 - EMC 3215) MacBook Pro 15" Retina Mi 2017 (A1707 - EMC 3162) MacBook Pro 15" Retina Fin 2016 (A1707 - EMC 3072) MacBook Pro 15" Retina Mi 2015 (A1398 - EMC 2909/2910) MacBook Pro 15" Retina Mi 2014 (A1398 - EMC 2876 & 2881) MacBook Pro 15" Retina fin 2013 (A1398 - EMC 2674 & 2745) MacBook Pro 15" Retina Début 2013 (A1398 - EMC 2673) MacBook Pro 15" Retina Mi 2012 (A1398 - EMC 2512) MacBook Pro 15" Unibody Mi 2012 (A1286 - EMC 2556)MacBook Pro 15" Unibody Fin 2011 (A1286 - EMC 2563) MacBook Pro 15" Unibody Début 2011 (A1286 - EMC 2353-1) MacBook Pro 15" Unibody Mi 2010 (A1286 - EMC 2353) MacBook Pro 15" Unibody Mi 2009 (A1286 - EMC 2324 & 2325) MacBook Pro 15" Unibody Début 2009 (A1286 - EMC 2255) MacBook Pro 15" Unibody Fin 2008 (A1286 - EMC 2255) MacBook Pro 15" Début 2008 (A1260 - EMC 2198) MacBook Pro 15" Mi/Fin 2007 (A1226 - EMC 2136) MacBook Pro 15" Fin 2006 (A1211 - EMC 2120) MacBook Pro 15" Original 2006 (A1150 - EMC 2101) -
Guide de réparation : Prise Jack + Haut-parleur interne
Comment remplacer prise jack + haut-parleur interne pour - Guide images
Avant de commencer le changement de la nappe comprenant la prise jack ainsi que le haut-parleur interne, nous vous conseillons d'éteindre votre Galaxy note 3.
Faites glisser une spatule en nylon afin de soulever la coque arrière du Galaxy note 3 .
Une fois soulevée, vous pouvez ôter complètement la batterie de votre Galaxy note 3.
Poussez délicatement sur la carte SIM puis la tirer afin de la sortir de son logement.
Vous n'avez plus qu'à la saisir afin de finir de l'extraire de son logement.
A l'aide d'un tournevis cruciforme, dévissez les 12 vis entourées en rouge.
Ces vis retiennent le châssis interne au bloc LCD et sont entourées en rouge sur la photo.
Afin de le soulever légèrement, insérez une spatule en nylon entre le châssis interne et le bloc LCD de votre Galaxy Note 3.
Puis faites la glisser sur les 2 côtés, comme sur les photos ci contre, afin de déclipser le châssis interne.
Répétez l'opération jusqu'à ce que le châssis soit complètement déclipsé de votre Galaxy Note 3.
Soulevez les 7 connecteurs encadré en rouge sur la photo ci-contre, avec l'aide de la spatule.
Commencez par le connecteur de chargement.
Egalement avec la spatule, déconnectez le connecteur du tactile, puis celui de la caméra avant.
Déconnectez à présent le connecteur du capteur de proximité, puis celui du haut parleur et de la prise jack.
Maintenant, déconnectez le connecteur de l'écran LCD.
Puis pour finir de déconnecter les différents périphériques attachés à la carte mère, soulevez le connecteur de l'antenne.
Soulevez désormais délicatement la carte mère afin de l'ôter totalement de votre Galaxy Note 3.
ATTENTION aux nappes préalablement déconnectées, elles peuvent géner la sortie de la carte-mère. Ne pas hésiter à les pousser légèrement tout en prenant garde de ne pas les endommager.
Utilisez désormais un tournevis cruciforme pour retirer la vis (entourée en rouge) retenant la prise jack au bloc LCD de votre Galaxy Note 3.
Reprendre la spatule en nylon, puis introduisez sa pointe dans la prise jack.
Faites ensuite levier afin de déloger la prise jack de son emplacement.
La prise jack et le haut-parleur interne forment un seul élément sur le Galaxy Note 3.
Il faut donc désormais, à l'aide d'une spatule en nylon, faire délicatement levier pour décoller le haut-parleur interne.
Celui-ci est collé, il est possible d'avoir besoin de légèrement forcer pour le décoller.
Finissez d'extraire la nappe de son logement.
A présent votre nappe jack + haut parleur interne est entièrement démontée, vous pouvez procéder au remplacement de celle-ci.
