Xiaomi Pad
MacBook Pro 13" 2022 M2 (A2338 EMC 8162) MacBook Pro 13" 2020 M1 (A2338 EMC 3578) MacBook Pro 13" 2020 (A2289 EMC 3456) MacBook Pro 13" 2020 (A2251 A2159 - EMC 3348) Macbook Pro 13" Retina Début 2019 (A1989 A2159) MacBook Pro 13" Mi 2018 (A1989 EMC 3214) MacBook Pro 13" Retina Mi 2017 (A1708 A1706) MacBook Pro 13" Retina Fin 2016 (A1708 A1706) MacBook Pro 13" Retina Début 2015 (A1502 - EMC 2835) MacBook Pro 13" Retina Mi 2014 (A1502 - EMC 2875) MacBook Pro 13" Retina Fin 2013 (A1502 - EMC 2678) MacBook Pro 13" Retina Début 2013 (A1425 - EMC 2672) MacBook Pro Retina 13" 2020 (A2338)MacBook Pro 13" Retina Fin 2012 (A1425 - EMC 2557) MacBook Pro 13" Unibody Mi 2012 (A1278 - EMC 2554) MacBook Pro 13" Unibody Fin 2011 (A1278 - EMC 2555) MacBook Pro 13" Unibody Début 2011 (A1278 - EMC 2419) MacBook Pro 13" Unibody Mi 2010 (A1278 - EMC 2351) MacBook Pro 13" Unibody Mi 2009 (A1278 - EMC 2326) MacBook Pro 13" Unibody Fin 2008 (A1278 - EMC 2254)Macbook Pro 14 pouces 2024 M4 Max (A3185) MacBook Pro 14 pouces 2024 M4 Pro (A3401) MacBook Pro 14 pouces 2024 M4 (A3112) Macbook Pro 14 pouces 2023 M3 Pro M3 Pro Max (A2992) Macbook Pro 14 pouces 2023 M3 (A2918) MacBook Pro 14 pouces 2023 M2 Pro M2 Max (A2779) MacBook Pro 14 pouces M1 Pro M1 Max 2021 (A2442)MacBook Pro 15" Retina Mi 2019 (A1990 - EMC 3359) MacBook Pro 15" Retina Mi 2018 (A1990 - EMC 3215) MacBook Pro 15" Retina Mi 2017 (A1707 - EMC 3162) MacBook Pro 15" Retina Fin 2016 (A1707 - EMC 3072) MacBook Pro 15" Retina Mi 2015 (A1398 - EMC 2909/2910) MacBook Pro 15" Retina Mi 2014 (A1398 - EMC 2876 & 2881) MacBook Pro 15" Retina fin 2013 (A1398 - EMC 2674 & 2745) MacBook Pro 15" Retina Début 2013 (A1398 - EMC 2673) MacBook Pro 15" Retina Mi 2012 (A1398 - EMC 2512) MacBook Pro 15" Unibody Mi 2012 (A1286 - EMC 2556)MacBook Pro 15" Unibody Fin 2011 (A1286 - EMC 2563) MacBook Pro 15" Unibody Début 2011 (A1286 - EMC 2353-1) MacBook Pro 15" Unibody Mi 2010 (A1286 - EMC 2353) MacBook Pro 15" Unibody Mi 2009 (A1286 - EMC 2324 & 2325) MacBook Pro 15" Unibody Début 2009 (A1286 - EMC 2255) MacBook Pro 15" Unibody Fin 2008 (A1286 - EMC 2255) MacBook Pro 15" Début 2008 (A1260 - EMC 2198) MacBook Pro 15" Mi/Fin 2007 (A1226 - EMC 2136) MacBook Pro 15" Fin 2006 (A1211 - EMC 2120) MacBook Pro 15" Original 2006 (A1150 - EMC 2101) -
Guide de réparation : Prise Jack + Haut-parleur interne
Comment remplacer prise jack + haut-parleur interne pour - Guide images
Avant de commencer le démontage dela prise jack et du haut-parleur interne, nous vous conseillons d'éteindre votre Galaxy Note 1.
Pour ceci, appuyez sur le bouton power situé sur la droite du téléphone.
Avant de démonter votre Note 1, retirez le stylet de son emplacement pour ne pas gêner les futures manipulations.
Insérez la spatule dans l'ergo prévu, puis soulevez légèrement la coque arrière du Galaxy Note 1 .
Une fois légèrement soulevée, vous pouvez la saisir et la retirer complètement avec vos doigts.
La coque arrière de votre Galaxy Note 1 est désormais démontée, en cas de besoin, remplacez-la par une neuve.
A l'aide de la spatule en nylon, relevez la batterie depuis l'interstice prévu à cet effet.
Une fois soulevée, vous pouvez ôter complètement la batterie du Galaxy Note 1.
Posez votre doigt sur la carte SIM, en exercant une légère pression puis tirez dessus afin de l'extraire de son emplacement.
Poussez doucement sur la carte micro SD avec la spatule en nylon, afin de la rentrer délicatement, puis relâchez.
Celle-ci doit alors sortir d'elle même.
Comme pour la carte SIM, posez votre doigt en exercant une légère pression puis tirez dessus pour la déloger de son emplacement.
Dévissez les 9 vis cruciformes entourées en rouge sur la photo qui retiennent le châssis interne de votre Note 1 au châssis de l'écran.
Insérez de nouveau la spatule en nylon entre le châssis interne et le bloc LCD de votre Galaxy Note 1.
Puis faites-la glisser sur les cotés afin de déclipser le châssis interne du le bloc LCD.
Vous pouvez à présent retirer complètement le bloc LCD du Galaxy Note 1.
Reprenez la spatule en nylon pour déconnecter les 5 connecteurs retenant la carte mère au châssis du LCD.
Continuez ensuite en faisant délicatement levier sur la nappe de gestion du bouton home pour la déconnecter.
Répétez le même geste de levier pour déconnecter la nappe de gestion du tactile.
Faites de même pour la nappe de gestion de la prise jack en effectuant un léger effet de levier avec la spatule.
Toujours en utilisant la spatule, faites levier pour soulever la nappe de gestion de la caméra avant.
Faites une dernière fois levier pour débrancher la nappe de gestion du LCD.
Déconnectez ensuite l'antenne WiFi de la carte-mère de votre Galaxy Note 1.
Dévissez les 2 vis cruciforme entourées en rouge sur la photo, retenant la carte mère de votre Note 1 au châssis de l'écran.
Glissez doucement la spatule en nylon entre le châssis de l'écran et la carte mère puis soulevez délicatement.
Aucune résistance ne doit se faire sentir, n'hésitez pas à pousser légèrement les nappes pouvant gêner à l'extraction de la carte mère.
Attrapez soigneusement la carte mère pour la retirer totalement du châssis du LCD.
Dévissez les 2 vis cruciformes entourées en rouge sur la photo, servant à retenir la prise jack de votre Note 1 au châssis du LCD.
Avec la pince du kit outil, saisissez le support maintenant la prise jack ainsi que le capteur de proximité et la caméra avant. Retirez-les délicatement.
En utilisant le coté plat de la spatule en nylon, poussez sur le haut-parleur interne afin de le soulever.
Une fois levé, poussez-le jusqu'à ce qu'il soit complètement sorti de son logement.
Cette fois, insérez la pointe de la spatule dans la prise jack puis soulever.
La prise jack doit sortir de son emplacement sans difficulté.
La prise jack et le haut-parleur interne de votre Galaxy Note 1 sont désormais démontés.
En cas de besoin remplacez-les par une pièce neuve.
