Xiaomi Pad
MacBook Pro 13" 2022 M2 (A2338 EMC 8162) MacBook Pro 13" 2020 M1 (A2338 EMC 3578) MacBook Pro 13" 2020 (A2289 EMC 3456) MacBook Pro 13" 2020 (A2251 A2159 - EMC 3348) Macbook Pro 13" Retina Début 2019 (A1989 A2159) MacBook Pro 13" Mi 2018 (A1989 EMC 3214) MacBook Pro 13" Retina Mi 2017 (A1708 A1706) MacBook Pro 13" Retina Fin 2016 (A1708 A1706) MacBook Pro 13" Retina Début 2015 (A1502 - EMC 2835) MacBook Pro 13" Retina Mi 2014 (A1502 - EMC 2875) MacBook Pro 13" Retina Fin 2013 (A1502 - EMC 2678) MacBook Pro 13" Retina Début 2013 (A1425 - EMC 2672) MacBook Pro Retina 13" 2020 (A2338)MacBook Pro 13" Retina Fin 2012 (A1425 - EMC 2557) MacBook Pro 13" Unibody Mi 2012 (A1278 - EMC 2554) MacBook Pro 13" Unibody Fin 2011 (A1278 - EMC 2555) MacBook Pro 13" Unibody Début 2011 (A1278 - EMC 2419) MacBook Pro 13" Unibody Mi 2010 (A1278 - EMC 2351) MacBook Pro 13" Unibody Mi 2009 (A1278 - EMC 2326) MacBook Pro 13" Unibody Fin 2008 (A1278 - EMC 2254)Macbook Pro 14 pouces 2024 M4 Max (A3185) MacBook Pro 14 pouces 2024 M4 Pro (A3401) MacBook Pro 14 pouces 2024 M4 (A3112) Macbook Pro 14 pouces 2023 M3 Pro M3 Pro Max (A2992) Macbook Pro 14 pouces 2023 M3 (A2918) MacBook Pro 14 pouces 2023 M2 Pro M2 Max (A2779) MacBook Pro 14 pouces M1 Pro M1 Max 2021 (A2442)MacBook Pro 15" Retina Mi 2019 (A1990 - EMC 3359) MacBook Pro 15" Retina Mi 2018 (A1990 - EMC 3215) MacBook Pro 15" Retina Mi 2017 (A1707 - EMC 3162) MacBook Pro 15" Retina Fin 2016 (A1707 - EMC 3072) MacBook Pro 15" Retina Mi 2015 (A1398 - EMC 2909/2910) MacBook Pro 15" Retina Mi 2014 (A1398 - EMC 2876 & 2881) MacBook Pro 15" Retina fin 2013 (A1398 - EMC 2674 & 2745) MacBook Pro 15" Retina Début 2013 (A1398 - EMC 2673) MacBook Pro 15" Retina Mi 2012 (A1398 - EMC 2512) MacBook Pro 15" Unibody Mi 2012 (A1286 - EMC 2556)MacBook Pro 15" Unibody Fin 2011 (A1286 - EMC 2563) MacBook Pro 15" Unibody Début 2011 (A1286 - EMC 2353-1) MacBook Pro 15" Unibody Mi 2010 (A1286 - EMC 2353) MacBook Pro 15" Unibody Mi 2009 (A1286 - EMC 2324 & 2325) MacBook Pro 15" Unibody Début 2009 (A1286 - EMC 2255) MacBook Pro 15" Unibody Fin 2008 (A1286 - EMC 2255) MacBook Pro 15" Début 2008 (A1260 - EMC 2198) MacBook Pro 15" Mi/Fin 2007 (A1226 - EMC 2136) MacBook Pro 15" Fin 2006 (A1211 - EMC 2120) MacBook Pro 15" Original 2006 (A1150 - EMC 2101) -
Guide de réparation : Haut parleur externe
Comment remplacer haut parleur externe pour - Guide images
Avant de commencer le démontage du haut-parleur externe, nous vous conseillons d'éteindre votre Galaxy Note 1.
Avant de démonter votre Note 1, retirez le stylet de son emplacement pour ne pas gêner les futures manipulations.
Insérez la spatule dans l'ergo prévu, puis soulevez légèrement la coque arrière du Galaxy Note 1 .
Une fois légèrement soulevée, vous pouvez la saisir et la retirer complètement avec vos doigts.
La coque arrière de votre Galaxy Note 1 est désormais démontée, en cas de besoin, remplacez-la par une neuve.
A l'aide de la spatule en nylon, relevez la batterie depuis l'interstice prévu à cet effet.
Une fois soulevée, vous pouvez ôter complètement la batterie du Galaxy Note 1.
Posez votre doigt sur la carte SIM, en exercant une légère pression puis tirez dessus afin de l'extraire de son emplacement.
Poussez doucement sur la carte micro SD avec la spatule en nylon, afin de la rentrer délicatement, puis relâchez.
Celle-ci doit alors sortir d'elle même.
Comme pour la carte SIM, posez votre doigt en exercant une légère pression puis tirez dessus pour la déloger de son emplacement.
Dévissez les 9 vis cruciformes entourées en rouge sur la photo qui retiennent le châssis interne de votre Note 1 au châssis de l'écran.
Insérez de nouveau la spatule en nylon entre le châssis interne et le bloc LCD de votre Galaxy Note 1.
Puis faites-la glisser sur les cotés afin de déclipser le châssis interne du le bloc LCD.
Vous pouvez à présent retirer complètement le bloc LCD du Galaxy Note 1.
Dévissez les 3 vis cruciformes entourées en rouge sur la photo, retenant le haut parleur externe de votre Note 1 au châssis de l'écran.
Glissez la spatule entre le haut-parleur externe et le châssis de l'écran.
Puis soulevez le haut-parleur en effectuant un quart de tour.
Attrapez le haut-parleur externe et retirez-le complétement.
Le haut-parleur externe de votre Galaxy Note 1 est désormais démonté.
En cas de besoin remplacez-le pour une pièce neuve.
