MacBook Pro 13" 2022 M2 (A2338 EMC 8162) MacBook Pro 13" 2020 M1 (A2338 EMC 3578) MacBook Pro 13" 2020 (A2289 EMC 3456) MacBook Pro 13" 2020 (A2251 A2159 - EMC 3348) Macbook Pro 13" Retina Début 2019 (A1989 A2159) MacBook Pro 13" Mi 2018 (A1989 EMC 3214) MacBook Pro 13" Retina Mi 2017 (A1708 A1706) MacBook Pro 13" Retina Fin 2016 (A1708 A1706) MacBook Pro 13" Retina Début 2015 (A1502 - EMC 2835) MacBook Pro 13" Retina Mi 2014 (A1502 - EMC 2875) MacBook Pro 13" Retina Fin 2013 (A1502 - EMC 2678) MacBook Pro 13" Retina Début 2013 (A1425 - EMC 2672) MacBook Pro Retina 13" 2020 (A2338)MacBook Pro 13" Retina Fin 2012 (A1425 - EMC 2557) MacBook Pro 13" Unibody Mi 2012 (A1278 - EMC 2554) MacBook Pro 13" Unibody Fin 2011 (A1278 - EMC 2555) MacBook Pro 13" Unibody Début 2011 (A1278 - EMC 2419) MacBook Pro 13" Unibody Mi 2010 (A1278 - EMC 2351) MacBook Pro 13" Unibody Mi 2009 (A1278 - EMC 2326) MacBook Pro 13" Unibody Fin 2008 (A1278 - EMC 2254)Macbook Pro 14 pouces 2024 M4 Max (A3185) MacBook Pro 14 pouces 2024 M4 Pro (A3401) MacBook Pro 14 pouces 2024 M4 (A3112) Macbook Pro 14 pouces 2023 M3 Pro M3 Pro Max (A2992) Macbook Pro 14 pouces 2023 M3 (A2918) MacBook Pro 14 pouces 2023 M2 Pro M2 Max (A2779) MacBook Pro 14 pouces M1 Pro M1 Max 2021 (A2442)MacBook Pro 15" Retina Mi 2019 (A1990 - EMC 3359) MacBook Pro 15" Retina Mi 2018 (A1990 - EMC 3215) MacBook Pro 15" Retina Mi 2017 (A1707 - EMC 3162) MacBook Pro 15" Retina Fin 2016 (A1707 - EMC 3072) MacBook Pro 15" Retina Mi 2015 (A1398 - EMC 2909/2910) MacBook Pro 15" Retina Mi 2014 (A1398 - EMC 2876 & 2881) MacBook Pro 15" Retina fin 2013 (A1398 - EMC 2674 & 2745) MacBook Pro 15" Retina Début 2013 (A1398 - EMC 2673) MacBook Pro 15" Retina Mi 2012 (A1398 - EMC 2512) MacBook Pro 15" Unibody Mi 2012 (A1286 - EMC 2556)MacBook Pro 15" Unibody Fin 2011 (A1286 - EMC 2563) MacBook Pro 15" Unibody Début 2011 (A1286 - EMC 2353-1) MacBook Pro 15" Unibody Mi 2010 (A1286 - EMC 2353) MacBook Pro 15" Unibody Mi 2009 (A1286 - EMC 2324 & 2325) MacBook Pro 15" Unibody Début 2009 (A1286 - EMC 2255) MacBook Pro 15" Unibody Fin 2008 (A1286 - EMC 2255) MacBook Pro 15" Début 2008 (A1260 - EMC 2198) MacBook Pro 15" Mi/Fin 2007 (A1226 - EMC 2136) MacBook Pro 15" Fin 2006 (A1211 - EMC 2120) MacBook Pro 15" Original 2006 (A1150 - EMC 2101) -
Guide de réparation : Vitre arrière Redmi Note 12
Une chute ou un choc trop violent et la vitre arrière de votre Xiaomi Redmi Note 12 4G peut se fissurer, se briser ou se décoller. Même si cela n'empêche pas le téléphone de fonctionner, une coque arrière endommagée compromet la solidité, l'étanchéité et l'esthétique de votre appareil. Dans certains cas, cela peut aussi provoquer des infiltrations de poussière ou nuire à la dissipation de la chaleur.
Le Redmi Note 12 4G est doté d’une vitre arrière en verre au design soigné, parfaitement ajustée au châssis. Elle protège non seulement les composants internes, mais permet aussi de maintenir une bonne rigidité de l’ensemble du smartphone. Si la vitre est cassée, il est possible de la remplacer soi-même sans devoir changer toute la coque. Grâce à notre tutoriel illustré, le remplacement se fait étape par étape, facilement et en toute sécurité, avec les outils adaptés.
Réparer la vitre arrière vous-même permet de retrouver un téléphone comme neuf, tout en évitant les frais d’une intervention en atelier. C’est également une solution écologique qui prolonge la durée de vie de votre appareil.
Signes indiquant qu’il faut remplacer la vitre arrière :
- Fissures visibles ou éclats de verre
- Vitre arrière décollée ou mal fixée
- Bords tranchants ou inconfortables à la prise en main
- Poussières ou traces d’humidité dans le téléphone
- Perte d’adhérence des stickers internes
- Esthétique dégradée du smartphone
Vitre arrière - Xiaomi Redmi Note 12 4G graphite (Officielle) 29.61€ Voir le produit visibility
Pièces en option
Kit outils Spécial - N°1 8.01€ Voir le produit visibility
Comment changer vitre arrière pour Redmi Note 12 - Guide vidéo
Comment remplacer vitre arrière pour Redmi Note 12 - Guide images
- identifiez le numéro de modèle de votre appareil : chaque smartphone possède une référence précise, souvent indiquée à l’arrière de l'appareil, sur la boîte d’origine ou dans les paramètres (à la rubrique À propos du téléphone). Ce numéro de modèle vous permet de vérifier la compatibilité des pièces détachées et des tutoriels. Une erreur de modèle pourrait compromettre la réparation.
- préparez un espace de travail propre et bien éclairé : installez-vous sur une surface plane, dégagée et propre afin d’éviter de perdre des vis ou d’endommager des composants sensibles. Un environnement bien organisé vous aidera à suivre les étapes plus facilement et efficacement.
Avant toute manipulation, il est indispensable d’éteindre l’appareil pour éviter les courts-circuits ou tout risque de dommage électrique. Si possible, débranchez également la batterie dès les premières étapes de démontage.
En respectant ces conseils, vous mettez toutes les chances de votre côté pour une réparation réussie !
- Coussin chauffant : Placez-le au micro-ondes environ 1 minute puis installez-le sur la vitre arrière quelques secondes. La chaleur va assouplir l’adhésif, ce qui facilitera le retrait sans endommager la vitre.
- Décapeur thermique / sèche-cheveux : Utilisez-le à température basse ou moyenne, à une distance de 10 à 15 cm. Déplacez l’appareil constamment pour diffuser la chaleur uniformément. Ne restez pas immobile sur un point précis, car cela pourrait abîmer les composants internes ou fragiliser la vitre.
Une fois l’adhésif ramolli, , disposez la ventouse et introduisez le médiator fin entre le châssis et la face arrière. Remplacez le médiator par ceux en plastique avant d'entamer la rotation de ces derniers pour les faire circuler sur tout le tour de l'appareil.
