MacBook Pro 13" 2022 M2 (A2338 EMC 8162) MacBook Pro 13" 2020 M1 (A2338 EMC 3578) MacBook Pro 13" 2020 (A2289 EMC 3456) MacBook Pro 13" 2020 (A2251 A2159 - EMC 3348) Macbook Pro 13" Retina Début 2019 (A1989 A2159) MacBook Pro 13" Mi 2018 (A1989 EMC 3214) MacBook Pro 13" Retina Mi 2017 (A1708 A1706) MacBook Pro 13" Retina Fin 2016 (A1708 A1706) MacBook Pro 13" Retina Début 2015 (A1502 - EMC 2835) MacBook Pro 13" Retina Mi 2014 (A1502 - EMC 2875) MacBook Pro 13" Retina Fin 2013 (A1502 - EMC 2678) MacBook Pro 13" Retina Début 2013 (A1425 - EMC 2672) MacBook Pro Retina 13" 2020 (A2338)MacBook Pro 13" Retina Fin 2012 (A1425 - EMC 2557) MacBook Pro 13" Unibody Mi 2012 (A1278 - EMC 2554) MacBook Pro 13" Unibody Fin 2011 (A1278 - EMC 2555) MacBook Pro 13" Unibody Début 2011 (A1278 - EMC 2419) MacBook Pro 13" Unibody Mi 2010 (A1278 - EMC 2351) MacBook Pro 13" Unibody Mi 2009 (A1278 - EMC 2326) MacBook Pro 13" Unibody Fin 2008 (A1278 - EMC 2254)Macbook Pro 14 pouces 2024 M4 Max (A3185) MacBook Pro 14 pouces 2024 M4 Pro (A3401) MacBook Pro 14 pouces 2024 M4 (A3112) Macbook Pro 14 pouces 2023 M3 Pro M3 Pro Max (A2992) Macbook Pro 14 pouces 2023 M3 (A2918) MacBook Pro 14 pouces 2023 M2 Pro M2 Max (A2779) MacBook Pro 14 pouces M1 Pro M1 Max 2021 (A2442)MacBook Pro 15" Retina Mi 2019 (A1990 - EMC 3359) MacBook Pro 15" Retina Mi 2018 (A1990 - EMC 3215) MacBook Pro 15" Retina Mi 2017 (A1707 - EMC 3162) MacBook Pro 15" Retina Fin 2016 (A1707 - EMC 3072) MacBook Pro 15" Retina Mi 2015 (A1398 - EMC 2909/2910) MacBook Pro 15" Retina Mi 2014 (A1398 - EMC 2876 & 2881) MacBook Pro 15" Retina fin 2013 (A1398 - EMC 2674 & 2745) MacBook Pro 15" Retina Début 2013 (A1398 - EMC 2673) MacBook Pro 15" Retina Mi 2012 (A1398 - EMC 2512) MacBook Pro 15" Unibody Mi 2012 (A1286 - EMC 2556)MacBook Pro 15" Unibody Fin 2011 (A1286 - EMC 2563) MacBook Pro 15" Unibody Début 2011 (A1286 - EMC 2353-1) MacBook Pro 15" Unibody Mi 2010 (A1286 - EMC 2353) MacBook Pro 15" Unibody Mi 2009 (A1286 - EMC 2324 & 2325) MacBook Pro 15" Unibody Début 2009 (A1286 - EMC 2255) MacBook Pro 15" Unibody Fin 2008 (A1286 - EMC 2255) MacBook Pro 15" Début 2008 (A1260 - EMC 2198) MacBook Pro 15" Mi/Fin 2007 (A1226 - EMC 2136) MacBook Pro 15" Fin 2006 (A1211 - EMC 2120) MacBook Pro 15" Original 2006 (A1150 - EMC 2101) -
Guide de réparation : Batterie Redmi Note 12
Après plusieurs mois d'utilisation ou à la suite d’un choc, la batterie de votre Xiaomi Redmi Note 12 4G peut montrer des signes de faiblesse. Cela se manifeste souvent par une autonomie réduite, des redémarrages intempestifs, une chauffe inhabituelle ou un refus de charge. Même si le smartphone reste fonctionnel, une batterie défaillante nuit fortement à l’expérience utilisateur au quotidien. Parmi les problèmes récurrents : pourcentage de batterie instable, extinction soudaine, charge lente ou absence de réaction au branchement d’un câble.
Chez SOSav, nous savons que même si le Redmi Note 12 4G est un smartphone fiable, sa batterie Li-Po de 5000 mAh n’est pas inusable. Compatible avec la recharge rapide 33W, elle permet de retrouver 50 % de charge en seulement 22 minutes (selon les données constructeur). Mais avec le temps, ses performances peuvent diminuer, surtout en cas d’usage intensif ou après un choc. Remplacer la batterie vous-même à l’aide de nos guides illustrés est une solution économique, fiable et durable, qui prolonge la vie de votre smartphone.
Signes d’une batterie à remplacer :
- Autonomie anormalement faible
- Redémarrages imprévus
- Batterie qui gonfle ou chauffe excessivement
- Charge très lente voire absente
- Pourcentage erratique ou bloqué
- Problèmes de reconnaissance du chargeur
Batterie BN5M - Xiaomi Redmi Note 12 4G 17.91€ Voir le produit visibility
Batterie - Xiaomi Redmi Note 12 4G (Officielle)
38.61€
Outils requis
iSesamo (Spatule en métal) 8.01€ Voir le produit visibility
Tapis de réparation magnétique en silicone BEST (40x30 cm)
13.41€
Pièces en option
Kit outils Spécial - N°1 8.01€ Voir le produit visibility
Comment changer batterie pour Redmi Note 12 - Guide vidéo
Comment remplacer batterie pour Redmi Note 12 - Guide images
- identifiez le numéro de modèle de votre appareil : chaque smartphone possède une référence précise, souvent indiquée à l’arrière de l'appareil, sur la boîte d’origine ou dans les paramètres (à la rubrique À propos du téléphone). Ce numéro de modèle vous permet de vérifier la compatibilité des pièces détachées et des tutoriels. Une erreur de modèle pourrait compromettre la réparation.
Préparez un espace de travail propre et bien éclairé : installez-vous sur une surface plane, dégagée et propre afin d’éviter de perdre des vis ou d’endommager des composants sensibles. Un environnement bien organisé vous aidera à suivre les étapes plus facilement et efficacement.
Éteindre le téléphone.
Enlever le tiroir SIM.
Pour cela, plusieurs outils s’offrent à vous :
Coussin chauffant : Placez-le au micro-ondes environ 1 minute puis installez-le sur la vitre arrière quelques secondes. La chaleur va assouplir l’adhésif, ce qui facilitera le retrait sans endommager la vitre.
Décapeur thermique / sèche-cheveux : Utilisez-le à température basse ou moyenne, à une distance de 10 à 15 cm. Déplacez l’appareil constamment pour diffuser la chaleur uniformément. Ne restez pas immobile sur un point précis, car cela pourrait abîmer les composants internes ou fragiliser la vitre.
Disposez la ventouse et introduisez le médiator fin entre le châssis et la face arrière.
Remplacez le médiator par ceux en plastique avant d'entamer la rotation de ces derniers pour les faire circuler sur tout le tour de l'appareil.
Retournez le téléphone pour insérer la spatule de l'autre coté du châssis. Faites le circuler tout autour de l'appareil.
Déconnectez la nappe du lecteur d'empreintes pour mettre de coté le châssis intermédiaire.
Tirez la partie principale vers l'extérieur pour détacher la batterie du téléphone.
Récupérez le film transparent du fond du châssis.
Remettre le sticker sur la nouvelle batterie et faire le tutoriel en sens inverse.
