MacBook Pro 13" 2022 M2 (A2338 EMC 8162) MacBook Pro 13" 2020 M1 (A2338 EMC 3578) MacBook Pro 13" 2020 (A2289 EMC 3456) MacBook Pro 13" 2020 (A2251 A2159 - EMC 3348) Macbook Pro 13" Retina Début 2019 (A1989 A2159) MacBook Pro 13" Mi 2018 (A1989 EMC 3214) MacBook Pro 13" Retina Mi 2017 (A1708 A1706) MacBook Pro 13" Retina Fin 2016 (A1708 A1706) MacBook Pro 13" Retina Début 2015 (A1502 - EMC 2835) MacBook Pro 13" Retina Mi 2014 (A1502 - EMC 2875) MacBook Pro 13" Retina Fin 2013 (A1502 - EMC 2678) MacBook Pro 13" Retina Début 2013 (A1425 - EMC 2672) MacBook Pro Retina 13" 2020 (A2338)MacBook Pro 13" Retina Fin 2012 (A1425 - EMC 2557) MacBook Pro 13" Unibody Mi 2012 (A1278 - EMC 2554) MacBook Pro 13" Unibody Fin 2011 (A1278 - EMC 2555) MacBook Pro 13" Unibody Début 2011 (A1278 - EMC 2419) MacBook Pro 13" Unibody Mi 2010 (A1278 - EMC 2351) MacBook Pro 13" Unibody Mi 2009 (A1278 - EMC 2326) MacBook Pro 13" Unibody Fin 2008 (A1278 - EMC 2254)Macbook Pro 14 pouces 2024 M4 Max (A3185) MacBook Pro 14 pouces 2024 M4 Pro (A3401) MacBook Pro 14 pouces 2024 M4 (A3112) Macbook Pro 14 pouces 2023 M3 Pro M3 Pro Max (A2992) Macbook Pro 14 pouces 2023 M3 (A2918) MacBook Pro 14 pouces 2023 M2 Pro M2 Max (A2779) MacBook Pro 14 pouces M1 Pro M1 Max 2021 (A2442)MacBook Pro 15" Retina Mi 2019 (A1990 - EMC 3359) MacBook Pro 15" Retina Mi 2018 (A1990 - EMC 3215) MacBook Pro 15" Retina Mi 2017 (A1707 - EMC 3162) MacBook Pro 15" Retina Fin 2016 (A1707 - EMC 3072) MacBook Pro 15" Retina Mi 2015 (A1398 - EMC 2909/2910) MacBook Pro 15" Retina Mi 2014 (A1398 - EMC 2876 & 2881) MacBook Pro 15" Retina fin 2013 (A1398 - EMC 2674 & 2745) MacBook Pro 15" Retina Début 2013 (A1398 - EMC 2673) MacBook Pro 15" Retina Mi 2012 (A1398 - EMC 2512) MacBook Pro 15" Unibody Mi 2012 (A1286 - EMC 2556)MacBook Pro 15" Unibody Fin 2011 (A1286 - EMC 2563) MacBook Pro 15" Unibody Début 2011 (A1286 - EMC 2353-1) MacBook Pro 15" Unibody Mi 2010 (A1286 - EMC 2353) MacBook Pro 15" Unibody Mi 2009 (A1286 - EMC 2324 & 2325) MacBook Pro 15" Unibody Début 2009 (A1286 - EMC 2255) MacBook Pro 15" Unibody Fin 2008 (A1286 - EMC 2255) MacBook Pro 15" Début 2008 (A1260 - EMC 2198) MacBook Pro 15" Mi/Fin 2007 (A1226 - EMC 2136) MacBook Pro 15" Fin 2006 (A1211 - EMC 2120) MacBook Pro 15" Original 2006 (A1150 - EMC 2101) -
Guide de réparation : Vitre arrière Galaxy S20 Fe
À la suite d’un choc, d’une chute ou avec le temps, la vitre arrière de votre Galaxy S20 FE peut se fissurer ou se rayer. Ce type de dommage est fréquent et impacte non seulement l’esthétique du smartphone, mais peut également compromettre son étanchéité. Une coque arrière endommagée peut laisser entrer la poussière ou l’humidité, risquant ainsi d’abîmer les composants internes. Pour redonner un aspect neuf à votre téléphone tout en le protégeant efficacement, le remplacement de la vitre arrière s’impose.
Chez SOSav, nous savons que l’arrière des smartphones modernes, souvent en verre, est aussi exposé que l’écran. Pourtant, changer de téléphone pour une simple coque arrière fissurée n’est ni écologique ni économique. C’est pourquoi nous vous offrons une alternative simple : remplacez la vitre arrière vous-même à l’aide de nos tutoriels détaillés et accessibles à tous.
Pour faciliter la réparation de la vitre arrière de votre Galaxy S20 FE, nous avons mis à votre disposition un guide complet. Vous y trouverez toutes les étapes illustrées pour réaliser cette intervention en toute sécurité, même si vous n’avez jamais démonté de smartphone auparavant. Il suffit d’un peu de patience et des bons outils pour retrouver un téléphone comme neuf !
Pourquoi remplacer soi-même la vitre arrière de son Galaxy S20 FE ?
Avant tout pour faire des économies. Inutile de passer par un réparateur ou de changer tout l’appareil. En effectuant cette réparation vous-même, vous réduisez les frais, évitez les délais d’attente, et prolongez la durée de vie de votre téléphone. Ce geste contribue également à limiter les déchets électroniques : un choix à la fois pratique et responsable.
Pensez à éteindre complètement votre téléphone et à retirer la carte SIM avant de commencer la réparation pour éviter tout incident.
Signes d’une vitre arrière à remplacer :
- Fissures ou éclats visibles
- Rayures profondes ou nombreuses
- Décollement partiel de la coque
- Perte d’étanchéité (poussière ou humidité à l’intérieur)
- Aspect esthétique détérioré
Le remplacement de la coque arrière permet de redonner un aspect neuf à votre Galaxy S20 FE tout en assurant sa protection contre les agressions extérieures du quotidien.
Kit outils Spécial - N°1 8.01€ Voir le produit visibility
Comment remplacer vitre arrière pour Galaxy S20 Fe - Guide images
Pour cela, accédez aux paramètres de votre téléphone afin d’identifier précisément le numéro de modèle.
Nous vous proposons ici un guide de réparation dédié au modèle SM-G780F.
Les étapes décrites sont également valables pour la version 5G du Galaxy S20 FE.
Utilisez ensuite un sèche-cheveux ou un pistolet à air chaud pour chauffer le pourtour de la face arrière pendant une trentaine de secondes.
Si vous disposez du coussin thermique, placez-le au micro-ondes pendant environ 2 minutes, puis appliquez-le durant 40 secondes sur le dos de l’appareil.
Positionnez la ventouse sur la partie inférieure de la vitre arrière et tirez délicatement afin d’introduire le médiator en métal perforé entre la vitre et le châssis afin de créer un espace d’insertion.
Insérez alors les médiators rouges dans l’ouverture, retirez le médiator métallique.
N'hésitez pas à chauffer à nouveau quelques secondes, au sèche-cheveux ou au décapeur thermique si vous sentez de la résistance.
Nettoyez les résidus de joint et de colle de votre face arrière.
Posez un filet de colle tout autour du châssis dans toucher aux composants internes.
Mettez sous presse pendant 20 minutes à l'aide de pinces, ou sous une pile de livres.
