Xiaomi Pad
MacBook Pro 13" 2022 M2 (A2338 EMC 8162) MacBook Pro 13" 2020 M1 (A2338 EMC 3578) MacBook Pro 13" 2020 (A2289 EMC 3456) MacBook Pro 13" 2020 (A2251 A2159 - EMC 3348) Macbook Pro 13" Retina Début 2019 (A1989 A2159) MacBook Pro 13" Mi 2018 (A1989 EMC 3214) MacBook Pro 13" Retina Mi 2017 (A1708 A1706) MacBook Pro 13" Retina Fin 2016 (A1708 A1706) MacBook Pro 13" Retina Début 2015 (A1502 - EMC 2835) MacBook Pro 13" Retina Mi 2014 (A1502 - EMC 2875) MacBook Pro 13" Retina Fin 2013 (A1502 - EMC 2678) MacBook Pro 13" Retina Début 2013 (A1425 - EMC 2672) MacBook Pro Retina 13" 2020 (A2338)MacBook Pro 13" Retina Fin 2012 (A1425 - EMC 2557) MacBook Pro 13" Unibody Mi 2012 (A1278 - EMC 2554) MacBook Pro 13" Unibody Fin 2011 (A1278 - EMC 2555) MacBook Pro 13" Unibody Début 2011 (A1278 - EMC 2419) MacBook Pro 13" Unibody Mi 2010 (A1278 - EMC 2351) MacBook Pro 13" Unibody Mi 2009 (A1278 - EMC 2326) MacBook Pro 13" Unibody Fin 2008 (A1278 - EMC 2254)Macbook Pro 14 pouces 2024 M4 Max (A3185) MacBook Pro 14 pouces 2024 M4 Pro (A3401) MacBook Pro 14 pouces 2024 M4 (A3112) Macbook Pro 14 pouces 2023 M3 Pro M3 Pro Max (A2992) Macbook Pro 14 pouces 2023 M3 (A2918) MacBook Pro 14 pouces 2023 M2 Pro M2 Max (A2779) MacBook Pro 14 pouces M1 Pro M1 Max 2021 (A2442)MacBook Pro 15" Retina Mi 2019 (A1990 - EMC 3359) MacBook Pro 15" Retina Mi 2018 (A1990 - EMC 3215) MacBook Pro 15" Retina Mi 2017 (A1707 - EMC 3162) MacBook Pro 15" Retina Fin 2016 (A1707 - EMC 3072) MacBook Pro 15" Retina Mi 2015 (A1398 - EMC 2909/2910) MacBook Pro 15" Retina Mi 2014 (A1398 - EMC 2876 & 2881) MacBook Pro 15" Retina fin 2013 (A1398 - EMC 2674 & 2745) MacBook Pro 15" Retina Début 2013 (A1398 - EMC 2673) MacBook Pro 15" Retina Mi 2012 (A1398 - EMC 2512) MacBook Pro 15" Unibody Mi 2012 (A1286 - EMC 2556)MacBook Pro 15" Unibody Fin 2011 (A1286 - EMC 2563) MacBook Pro 15" Unibody Début 2011 (A1286 - EMC 2353-1) MacBook Pro 15" Unibody Mi 2010 (A1286 - EMC 2353) MacBook Pro 15" Unibody Mi 2009 (A1286 - EMC 2324 & 2325) MacBook Pro 15" Unibody Début 2009 (A1286 - EMC 2255) MacBook Pro 15" Unibody Fin 2008 (A1286 - EMC 2255) MacBook Pro 15" Début 2008 (A1260 - EMC 2198) MacBook Pro 15" Mi/Fin 2007 (A1226 - EMC 2136) MacBook Pro 15" Fin 2006 (A1211 - EMC 2120) MacBook Pro 15" Original 2006 (A1150 - EMC 2101) -
Guide de réparation : Vitres arrière Galaxy Z Flip3
Suite à une chute accidentelle, votre Galaxy Z Flip 3 a subi des dégâts considérables, entraînant des fissures sur les deux vitres arrière ou sur une seule. Ces dommages esthétiques peuvent également compromettre l'intégrité de votre téléphone, exposant ses composants internes à la poussière et à l'humidité. Il est donc crucial de remplacer les vitres arrière pour restaurer l'apparence et la protection de votre smartphone.
Chez SOSav, nous comprenons à quel point les vitres arrière, tout comme les écrans, sont vulnérables aux impacts. Cependant, faut-il vraiment jeter votre téléphone pour une simple casse de vitre ? Bien sûr que non ! Nous vous proposons une solution abordable et efficace pour remettre votre Galaxy Z Flip 3 en parfait état. Pour cela, nous avons créé un guide détaillé pour vous accompagner dans le remplacement des vitres arrière. Ce tutoriel complet inclut des instructions claires, des photos étape par étape et des conseils pratiques, afin que vous puissiez réaliser la réparation facilement et en toute autonomie.
En réparant les vitres arrière de votre Galaxy Z Flip 3, vous prolongez la durée de vie de votre appareil tout en faisant un geste pour l'environnement. En évitant de jeter un smartphone encore fonctionnel, vous luttez contre l’obsolescence programmée et réduisez les déchets électroniques. Si vous avez des questions ou besoin d’aide à n’importe quelle étape, les techniciens SOSav sont là pour vous accompagner.
Pensez à sauvegarder vos données personnelles avant de commencer la réparation.
- Fissures ou éclats visibles sur les vitres arrière
- Rayures profondes affectant l’apparence
- Risque d’infiltration de poussière ou d’humidité
- Aspect esthétique dégradé
- Perte de protection des composants internes
Kit outils Spécial - N°1 8.01€ Voir le produit visibility
Lot d'adhésifs (Officiel) Samsung Galaxy Z Flip3 - Kit A
4.41€
Comment changer vitres arrière pour Galaxy Z Flip3 - Guide vidéo
Comment remplacer vitres arrière pour Galaxy Z Flip3 - Guide images
Vous avez bien reçu vos pièces ? Vous pouvez commencer la réparation.
Eteindre votre téléphone si cela est possible, ou laissez-le se décharger tout seul.
Retirez le tiroir contenant la carte SIM avec l'outil présent dans le Kit.
Coussin chauffant : Passez le coussin au micro-ondes environ 1-2 minutes avant de le mettre sur le dos du smartphone
Décapeur thermique : Chauffez le contour de l'appareil, à une distance de 5cm, pendant 20 à 30 secondes.
Collez la ventouse sur le bas du téléphone.
Introduisez le médiator troué entre le châssis et la vitre arrière.
Collez la ventouse sur le coin du téléphone, là où il n'a pas d'écran.
Introduisez le médiator troué entre le châssis et la vitre.
Insérez les médiators en plastique sous le médiator en métal, retirez le médiator en métal.
Faites circuler les médiators sur tout le contour du téléphone pour décoller pas à pas la vitre arrière délicatement. Faire attention sur la partie haute à ne pas trop enfoncer les médiators pour ne pas endommager le petit écran LCD.
Retirez le cache de la nappe.
Déconnectez la nappe de l'écran LCD avec le levier en nylon.
Mettre de côté et nettoyer les traces de stickers.
