MacBook Pro 13" 2022 M2 (A2338 EMC 8162) MacBook Pro 13" 2020 M1 (A2338 EMC 3578) MacBook Pro 13" 2020 (A2289 EMC 3456) MacBook Pro 13" 2020 (A2251 A2159 - EMC 3348) Macbook Pro 13" Retina Début 2019 (A1989 A2159) MacBook Pro 13" Mi 2018 (A1989 EMC 3214) MacBook Pro 13" Retina Mi 2017 (A1708 A1706) MacBook Pro 13" Retina Fin 2016 (A1708 A1706) MacBook Pro 13" Retina Début 2015 (A1502 - EMC 2835) MacBook Pro 13" Retina Mi 2014 (A1502 - EMC 2875) MacBook Pro 13" Retina Fin 2013 (A1502 - EMC 2678) MacBook Pro 13" Retina Début 2013 (A1425 - EMC 2672) MacBook Pro Retina 13" 2020 (A2338)MacBook Pro 13" Retina Fin 2012 (A1425 - EMC 2557) MacBook Pro 13" Unibody Mi 2012 (A1278 - EMC 2554) MacBook Pro 13" Unibody Fin 2011 (A1278 - EMC 2555) MacBook Pro 13" Unibody Début 2011 (A1278 - EMC 2419) MacBook Pro 13" Unibody Mi 2010 (A1278 - EMC 2351) MacBook Pro 13" Unibody Mi 2009 (A1278 - EMC 2326) MacBook Pro 13" Unibody Fin 2008 (A1278 - EMC 2254)Macbook Pro 14 pouces 2024 M4 Max (A3185) MacBook Pro 14 pouces 2024 M4 Pro (A3401) MacBook Pro 14 pouces 2024 M4 (A3112) Macbook Pro 14 pouces 2023 M3 Pro M3 Pro Max (A2992) Macbook Pro 14 pouces 2023 M3 (A2918) MacBook Pro 14 pouces 2023 M2 Pro M2 Max (A2779) MacBook Pro 14 pouces M1 Pro M1 Max 2021 (A2442)MacBook Pro 15" Retina Mi 2019 (A1990 - EMC 3359) MacBook Pro 15" Retina Mi 2018 (A1990 - EMC 3215) MacBook Pro 15" Retina Mi 2017 (A1707 - EMC 3162) MacBook Pro 15" Retina Fin 2016 (A1707 - EMC 3072) MacBook Pro 15" Retina Mi 2015 (A1398 - EMC 2909/2910) MacBook Pro 15" Retina Mi 2014 (A1398 - EMC 2876 & 2881) MacBook Pro 15" Retina fin 2013 (A1398 - EMC 2674 & 2745) MacBook Pro 15" Retina Début 2013 (A1398 - EMC 2673) MacBook Pro 15" Retina Mi 2012 (A1398 - EMC 2512) MacBook Pro 15" Unibody Mi 2012 (A1286 - EMC 2556)MacBook Pro 15" Unibody Fin 2011 (A1286 - EMC 2563) MacBook Pro 15" Unibody Début 2011 (A1286 - EMC 2353-1) MacBook Pro 15" Unibody Mi 2010 (A1286 - EMC 2353) MacBook Pro 15" Unibody Mi 2009 (A1286 - EMC 2324 & 2325) MacBook Pro 15" Unibody Début 2009 (A1286 - EMC 2255) MacBook Pro 15" Unibody Fin 2008 (A1286 - EMC 2255) MacBook Pro 15" Début 2008 (A1260 - EMC 2198) MacBook Pro 15" Mi/Fin 2007 (A1226 - EMC 2136) MacBook Pro 15" Fin 2006 (A1211 - EMC 2120) MacBook Pro 15" Original 2006 (A1150 - EMC 2101) -
Guide de réparation : Connecteur de charge Galaxy S20+
Avec le temps, ou à la suite d’un choc ou d’un mauvais branchement, le port de charge de votre Galaxy S20 Plus peut être endommagé ou ne plus fonctionner correctement. Vous avez peut-être remarqué que le câble n’est plus détecté, que la charge est instable, voire totalement absente, malgré l’utilisation de chargeurs fonctionnels. Dans certains cas, la recharge s’interrompt sans raison, ou vous devez manipuler le câble pour qu’il établisse un contact. Ces signes indiquent que le connecteur USB-C est probablement usé, dessoudé ou défectueux, rendant son remplacement indispensable pour réutiliser pleinement votre appareil.
Chez SOSav, nous savons que le port de charge est un composant particulièrement sollicité au quotidien. Et sur un smartphone aussi avancé que le Galaxy S20+, un problème de connectique peut vite devenir handicapant. Inutile de changer de téléphone pour autant : il est tout à fait possible de remplacer uniquement la nappe de charge, à moindre coût. Grâce à notre expertise et à nos tutoriels détaillés, vous pouvez réaliser vous-même cette réparation, sans connaissances poussées en électronique.
Pour vous accompagner dans le remplacement du connecteur de charge de votre Galaxy S20 Plus, nous mettons à votre disposition un guide complet. Il vous expliquera chaque étape avec clarté, photos à l’appui, même si vous êtes débutant. Bon à savoir : la nappe de charge est reliée à d'autres composants (micro, antenne, etc.), il faudra donc procéder avec soin lors de l’extraction, et reconnecter chaque élément dans le bon ordre pour assurer le bon fonctionnement de l'appareil.
Pourquoi changer vous-même le port de charge de votre Galaxy S20+ ?
D’abord pour faire des économies considérables. Il n’est pas nécessaire de confier votre smartphone à un réparateur professionnel pour une panne aussi localisée. En remplaçant vous-même le connecteur, vous réduisez les coûts de réparation tout en conservant l’usage complet de votre appareil. De plus, cette démarche évite un remplacement inutile du téléphone, ce qui limite l’impact environnemental lié aux déchets électroniques.
Pensez à éteindre totalement l’appareil et à sauvegarder vos données avant d'entamer toute manipulation.
Symptômes d’un connecteur de charge défectueux :
- Le téléphone ne se recharge plus
- La charge est instable ou intermittente
- Le câble doit être manipulé pour que la charge démarre
- Le Galaxy S20 Plus n’est pas reconnu par un ordinateur en USB
- Message d’humidité détectée alors que le port est sec
- Échauffement anormal pendant la charge
Le Galaxy S20+ prend en charge la recharge rapide 25W, la charge sans fil 15W et même la recharge inversée à 4.5W. Un connecteur en parfait état est donc indispensable pour profiter de toutes ces fonctionnalités en toute sécurité.
Kit outils Spécial - N°1 8.01€ Voir le produit visibility
Comment remplacer connecteur de charge pour Galaxy S20+ - Guide images
Pour cela, accédez aux réglages de votre téléphone afin d’identifier précisément le numéro de modèle.
Le tutoriel que nous vous proposons ici est adapté au modèle SM-G985.
Cet accessoire est disponible dans le kit outil spécial n°1, proposé en complément.
Utilisez un sèche-cheveux ou un décapeur thermique pour chauffer le contour de la coque arrière pendant environ 30 secondes.
Si vous avez un coussin chauffant, placez-le au micro-ondes pendant 2 minutes, puis appliquez-le pendant environ 40 secondes au dos du téléphone.
Placez la ventouse sur la partie basse de la vitre arrière, puis tirez doucement afin d’insérer le médiator en métal ajouré entre la vitre et le cadre pour créer un léger interstice.
Glissez ensuite les médiators rouges dans l’espace, puis retirez le médiator métallique.
N’hésitez pas à réchauffer brièvement la zone avec un sèche-cheveux ou un pistolet thermique si vous ressentez une certaine résistance.
Décollez la partie basse de la nappe NFC qui se trouve sur le HP externe avec le levier, si besoin chauffez quelques secondes avec votre sèche-cheveux ou le décapeur thermique.
Déclipsez le cache puis soulevez la partie métallique vers la nappe.
Déconnectez la batterie ainsi que la nappe NFC pour la retirer.
Soulevez-le avec le levier en nylon pour le retirer.
Soulevez le connecteur de charge endommagé et sortez-le du châssis.
♻️ Pensez au recyclage ! Mettez vos déchets électroniques dans le bac de tri approprié.
Retirer tous les stickers de protection.Une fois que vous avez refais ce tutoriel en sens inverse :
Nettoyez les résidus de stickers, sur le châssis ainsi que sur la vitre arrière, avant d'appliquer un léger filet de colle sur le pourtour du châssis avant de venir y poser la vitre arrière.
Laisser le tout sous presse environ une heure, à l'aide de pinces ou sous une pile de livres.
