MacBook Pro 13" 2022 M2 (A2338 EMC 8162) MacBook Pro 13" 2020 M1 (A2338 EMC 3578) MacBook Pro 13" 2020 (A2289 EMC 3456) MacBook Pro 13" 2020 (A2251 A2159 - EMC 3348) Macbook Pro 13" Retina Début 2019 (A1989 A2159) MacBook Pro 13" Mi 2018 (A1989 EMC 3214) MacBook Pro 13" Retina Mi 2017 (A1708 A1706) MacBook Pro 13" Retina Fin 2016 (A1708 A1706) MacBook Pro 13" Retina Début 2015 (A1502 - EMC 2835) MacBook Pro 13" Retina Mi 2014 (A1502 - EMC 2875) MacBook Pro 13" Retina Fin 2013 (A1502 - EMC 2678) MacBook Pro 13" Retina Début 2013 (A1425 - EMC 2672) MacBook Pro Retina 13" 2020 (A2338)MacBook Pro 13" Retina Fin 2012 (A1425 - EMC 2557) MacBook Pro 13" Unibody Mi 2012 (A1278 - EMC 2554) MacBook Pro 13" Unibody Fin 2011 (A1278 - EMC 2555) MacBook Pro 13" Unibody Début 2011 (A1278 - EMC 2419) MacBook Pro 13" Unibody Mi 2010 (A1278 - EMC 2351) MacBook Pro 13" Unibody Mi 2009 (A1278 - EMC 2326) MacBook Pro 13" Unibody Fin 2008 (A1278 - EMC 2254)Macbook Pro 14 pouces 2024 M4 Max (A3185) MacBook Pro 14 pouces 2024 M4 Pro (A3401) MacBook Pro 14 pouces 2024 M4 (A3112) Macbook Pro 14 pouces 2023 M3 Pro M3 Pro Max (A2992) Macbook Pro 14 pouces 2023 M3 (A2918) MacBook Pro 14 pouces 2023 M2 Pro M2 Max (A2779) MacBook Pro 14 pouces M1 Pro M1 Max 2021 (A2442)MacBook Pro 15" Retina Mi 2019 (A1990 - EMC 3359) MacBook Pro 15" Retina Mi 2018 (A1990 - EMC 3215) MacBook Pro 15" Retina Mi 2017 (A1707 - EMC 3162) MacBook Pro 15" Retina Fin 2016 (A1707 - EMC 3072) MacBook Pro 15" Retina Mi 2015 (A1398 - EMC 2909/2910) MacBook Pro 15" Retina Mi 2014 (A1398 - EMC 2876 & 2881) MacBook Pro 15" Retina fin 2013 (A1398 - EMC 2674 & 2745) MacBook Pro 15" Retina Début 2013 (A1398 - EMC 2673) MacBook Pro 15" Retina Mi 2012 (A1398 - EMC 2512) MacBook Pro 15" Unibody Mi 2012 (A1286 - EMC 2556)MacBook Pro 15" Unibody Fin 2011 (A1286 - EMC 2563) MacBook Pro 15" Unibody Début 2011 (A1286 - EMC 2353-1) MacBook Pro 15" Unibody Mi 2010 (A1286 - EMC 2353) MacBook Pro 15" Unibody Mi 2009 (A1286 - EMC 2324 & 2325) MacBook Pro 15" Unibody Début 2009 (A1286 - EMC 2255) MacBook Pro 15" Unibody Fin 2008 (A1286 - EMC 2255) MacBook Pro 15" Début 2008 (A1260 - EMC 2198) MacBook Pro 15" Mi/Fin 2007 (A1226 - EMC 2136) MacBook Pro 15" Fin 2006 (A1211 - EMC 2120) MacBook Pro 15" Original 2006 (A1150 - EMC 2101) -
Guide de réparation : Vitre arrière Galaxy A71
Quand faut-il envisager de changer la vitre arrière de votre Galaxy A71 ?
Suite à une chute ou un impact, la coque arrière de votre Samsung Galaxy A71 peut se fissurer, se détacher ou présenter des éclats visibles. Même si cela n'affecte pas directement le fonctionnement de l’appareil, une vitre endommagée peut altérer l’esthétique du téléphone, compromettre son étanchéité ou faciliter l’infiltration de poussière.
Le Galaxy A71 est doté d’un dos en plastique rigide au design brillant. Ce panneau est fixé à l’aide d’un adhésif puissant pour garantir une bonne tenue. Cependant, ce type de surface reste sensible aux chocs et aux torsions. Le remplacement de la vitre arrière permet de restaurer l’apparence d’origine de l’appareil tout en renforçant sa protection.
Chez SOSav, nous mettons à votre disposition des vitres arrière compatibles et testées, ainsi qu’un guide de réparation illustré étape par étape. Grâce à nos conseils clairs, vous pouvez effectuer cette réparation à domicile, même sans expérience technique particulière.
Pourquoi changer soi-même la coque arrière du Galaxy A71 ?
Effectuer le remplacement par vos propres moyens est une alternative économique à un passage en atelier. Cela vous permet également de conserver votre appareil plus longtemps en bon état. En optant pour la réparation plutôt que le remplacement, vous adoptez une démarche plus respectueuse de l’environnement.
Avant toute intervention, éteignez complètement l’appareil et retirez le tiroir de la carte SIM.
Signes qu’il est temps de remplacer la vitre arrière :
- Fissures visibles sur la coque
- Éclats ou morceaux manquants
- Décollage partiel de la surface arrière
- Accumulation de poussière ou infiltration d’humidité
- Coque rayée ou ternie qui nuit au confort d'utilisation
Compatibilité et précautions avant intervention
Le Galaxy A71 existe sous plusieurs variantes, notamment SM-A715F et SM-A715F/DS. Avant de commander une vitre de remplacement, pensez à vérifier cette information dans Paramètres > À propos du téléphone. Toutes nos pièces sont rigoureusement sélectionnées pour être compatibles avec ces modèles et peuvent être installées avec les outils disponibles en option.
Une fois la nouvelle vitre arrière posée, votre Galaxy A71 retrouvera un aspect soigné et une protection optimale, prolongeant ainsi sa durée de vie.
Vitre arrière (Officielle) - Galaxy A71 Bleu 31.41€ Voir le produit visibility
Vitre arrière NOIRE (Officielle) - Galaxy A71
31.41€
Outils requis
Décapeur thermique petit format 8.91€ Voir le produit visibility
Poche chauffante - Petit format
6.21€
Voir tous les outils
Pièces en option
Kit outils Spécial - N°1 8.01€ Voir le produit visibility
Comment remplacer vitre arrière pour Galaxy A71 - Guide images
Pour ce faire, rendez-vous dans les paramètres de votre appareil, puis ouvrez la section À propos du téléphone. Ou taper les numéros *#06# sur votre téléphone.
Le présent guide est spécifiquement conçu pour les modèles SM-A715F et SM-A715F/DS.
En cas de téléphone hors service, certains éléments visuels peuvent vous aider à l’identifier :
- Écran de grande taille avec poinçon centré pour la caméra frontale
- Module photo rectangulaire à l’arrière intégrant 4 capteurs
- Présence d’un port jack 3,5 mm
- Finition brillante typique de la gamme "Prism Crush"
Si vous avez un doute, notre équipe technique SOSav est à votre disposition pour vous aider à confirmer le modèle.
Une identification précise est indispensable pour réussir votre réparation et éviter les erreurs de compatibilité.
Une fois votre référence vérifiée : Éteignez votre smartphone.
Cet accessoire est inclus dans le kit outils spécial n°1, disponible en option sur notre boutique en ligne, conçu pour vous accompagner tout au long de votre réparation.
Si vous disposez d’un coussin chauffant, passez-le au micro-ondes pendant environ 2 minutes, puis appliquez-le sur la partie arrière du téléphone durant 40 secondes. Utilisez un sèche-cheveux ou un décapeur thermique pour diffuser de la chaleur sur les contours de la face arrière pendant environ 30 secondes.
Placez la ventouse sur la partie inférieure de la vitre arrière et tirez délicatement pour insérer le médiator en métal troué entre le verre et le châssis, vous allez créer un point d'insertion.
Insérez les médiators en plastique rouge et retirez le médiator en métal.
Déposez un filet de colle tout autour du châssis et mettez sous presse pendant au moins une demi heure avec des pinces ou sous une pile de livres.
Retirer la vitre arrière. Retirer le joint usagé de votre vitre arrière. A la fin de notre réparation nous recollerons cette pièce.
♻️ Point recyclage ! Pensez à mettre votre vitre arrière cassée dans le bac de tri approprié.
