iPhone 15 Pro Max iPhone 15 Pro iPhone 15 Plus iPhone 15 iPhone 14 Pro Max iPhone 14 Pro iPhone 14 Plus iPhone 14Galaxy A
Galaxy A90 Galaxy A80 Galaxy A72 Galaxy A71 Galaxy A70 Galaxy A60 Galaxy A55 5G Galaxy A54 Galaxy A53 5G Galaxy A52s 5G Galaxy A52 Galaxy A51 5G Galaxy A51Galaxy A50s Galaxy A50 Galaxy A42 Galaxy A41 Galaxy A40s Galaxy A40 Galaxy A35 5G Galaxy A34 Galaxy A33 5G Galaxy A33 Galaxy A32 5G Galaxy A32 Galaxy A31Galaxy A30s Galaxy A30 Galaxy A25 5G Galaxy A24 4G Galaxy A23 5G Galaxy A23 Galaxy A22 5G Galaxy A22 Galaxy A21s Galaxy A21Galaxy A20s Galaxy A20e Galaxy A20 Galaxy A15 Galaxy A14 5G Galaxy A14 Galaxy A13 5G Galaxy A13 Galaxy A12 Galaxy A11Galaxy J8 Galaxy J7+ Galaxy J7 Pro Galaxy J7 Prime Galaxy J7 Max Galaxy J7 Core Galaxy J7 (2018) Galaxy J7 (2017) Galaxy J7 (2016) Galaxy J7 Galaxy J6+ Galaxy J6 (2018)Galaxy S24 Ultra Galaxy S24+ Galaxy S24 Galaxy S23 FE Galaxy S23 Ultra Galaxy S23+ Galaxy S23 Galaxy S22 Ultra Galaxy S22+ Galaxy S22Galaxy S21 FE Galaxy S21+ Galaxy S21 Ultra Galaxy S21 Galaxy S20 FE 5G Galaxy S20+ Galaxy S20 Ultra Galaxy S20 FE Galaxy S20Galaxy S10e Galaxy S10+ Galaxy S10 Lite Galaxy S10 5G Galaxy S10 Galaxy S9+ Galaxy S9 Galaxy S8+ Galaxy S8 Active Galaxy S8Galaxy Ace 1 Galaxy Ace 2 Galaxy Ace 3 Galaxy Ace 4 Galaxy Ace 4 Lite Galaxy Ace Duos Galaxy Ace Style Galaxy AlphaGalaxy C5 Galaxy C5 Pro Galaxy C5000 Galaxy C7 Galaxy C7 Prime Galaxy C7 Pro Galaxy C8 Galaxy C9 Galaxy C9 Pro Galaxy Core 2 Galaxy Core LTE Galaxy Core Prime Galaxy Core Prime VEGalaxy Gio S5660 Galaxy Grand 2 Galaxy Grand Max Galaxy Grand Neo Galaxy Grand Plus Galaxy Grand Prime Galaxy Grand Prime +Série 11 et plus
Xiaomi Mi 11 Pro Xiaomi Mi 11 Lite 5G Xiaomi Mi 11 Ultra Xiaomi Mi 11 Lite Xiaomi Mi 11i Xiaomi Mi 11 Xiaomi Mi 10T Pro Xiaomi Mi 10T Lite Xiaomi Mi 10T Xiaomi Mi 10 Pro Xiaomi Mi 10 Lite Xiaomi Mi 10Xiaomi Mi 9T Pro Xiaomi Mi 9T Xiaomi Mi 9 SE Xiaomi Mi 9 Lite Xiaomi Mi 9 Xiaomi Mi8 SE Xiaomi Mi 8 Pro Xiaomi Mi 8 Lite Xiaomi Mi 8 Xiaomi Mi 6Xiaomi Redmi 13C Xiaomi Redmi 12C Xiaomi Redmi 12 4G/5G Xiaomi Redmi 10 (2022) Xiaomi Redmi 10C Xiaomi Redmi 10A Xiaomi Redmi 10 Xiaomi Redmi 9AT Xiaomi Redmi 9T Xiaomi Redmi 9C Xiaomi Redmi 9A Xiaomi Redmi 9Xiaomi Redmi 8A Xiaomi Redmi 8 Xiaomi Redmi 7A Xiaomi Redmi 7 Xiaomi Redmi 6A Xiaomi Redmi 6 Xiaomi Redmi 5A Xiaomi Redmi 5 Plus Xiaomi Redmi 5Xiaomi Redmi Note 13 Pro+ 5G Xiaomi Redmi Note 13 Pro 5G Xiaomi Redmi Note 13 Pro 4G Xiaomi Redmi Note 13 5G Xiaomi Redmi Note 13 4G Xiaomi Redmi Note 12S Xiaomi Redmi Note 12 Pro+ Xiaomi Redmi Note 12 Pro 5G Xiaomi Redmi Note 12 Pro 4G Xiaomi Redmi Note 12 5G Xiaomi Redmi Note 12 4G Xiaomi Redmi Note 11 Pro+ 5G Xiaomi Redmi Note 11 Pro 4G/5GSérie Mate
Kärcher WD 7300 Kärcher WD2200 Kärcher WD2250 Kärcher WD3 PREMIUM Kärcher WD3200 Kärcher WD3300 Kärcher WD3300M Kärcher WD3500 Kärcher WD3500P Kärcher WD4Kärcher 2001 Kärcher 2101 Kärcher 2111 Kärcher 2201 Kärcher 2201F Kärcher 2251 Kärcher 2301 Kärcher 2501 Kärcher 2601 Kärcher 3000PLUS Kärcher 3001 Kärcher 3011 Kärcher 3501Kärcher 4000Plus Kärcher DS5800 Kärcher FC5 Kärcher K1000 Kärcher K2201 Kärcher KB6060C Kärcher MV2 Kärcher MV3 Kärcher MV3 PREMIUM Kärcher MV4 Kärcher MV4 PREMIUM Kärcher MV5 Kärcher MV5PREMIUMKärcher SC1 EASY FIX Kärcher SC1000 Kärcher SC1002 Kärcher SC1010 Kärcher SC1020 Kärcher SC1030 Kärcher SC1030B Kärcher SC1035B Kärcher SC1040 Kärcher SC1050 Kärcher SC1052 Kärcher SC1402 Kärcher SC1475Kärcher SC1502 Kärcher SC1502I Kärcher SC1650 Kärcher SC1650BE Kärcher SC1702 Kärcher SC1702I Kärcher SC1702I6002 Kärcher SC2 Kärcher SC2 EASY FIX Kärcher SC2000 Kärcher SC2500C Kärcher SC2500C127V Kärcher SC2500C220Kärcher SC2550 Kärcher SC2550C Kärcher SC2600C Kärcher SC2600CB Kärcher SC3 Kärcher SC3 Premium Kärcher SC3000 Kärcher SC3100 Kärcher SC3100B Kärcher SC4 Kärcher SC4100 Kärcher SC4100C Kärcher SC4100CBTrottinettes
Compétences
Compétences Electroniques
Compétences électroniques
Souder un composant électronique
Guide de réparation : Souder un composant électronique Compétences électroniques
Ce guide vous apprend pas-à-pas à souder un composant électroniqueUtilité : Souder un composant sur une carte électronique
Comment remplacer souder un composant électronique pour Compétences électroniques - Guide images
Avant de débuter la soudure de votre composant électronique, munissez-vous et préparez le matériel suivant :- Un fer à souder posé sur son support ainsi qu'une éponge humide- Un support Loupe/troisième main- Une bobine d'étain adaptée à la taille de votre soudure (nous utiliserons ici de l'étain de 0,6mm)- Le composant que vous souhaitez souder- Une pince coupante (non visible sur la photo ci-contre)- La carte sur laquelle le composant va être soudéLors du processus de soudure, une odeur d'étain en fusion plus ou moins agréable peut se dégager.Nous vous conseillons (au possible) de ventiler l'intérieur de la pièce dans laquelle vous allez effectuer la soudure (ventilateur, fenêtre ouverte...) afin d'atténuer cette gêne.
Si vous disposez d'une station de soudure comme sur les photos de cette étape, ou si votre fer à souder possède un réglage de témpérature, réglez cette dernière entre 250 et 300 degrés.Branchez ensuite votre station ou votre fer à souder sur une prise électrique puis appuyez sur l'interrupteur ON/OFF afin de la/le mettre sous tension.
Durant la phase de chauffe du fer à souder (comprise généralement entre 2 et 5 minutes), placez l'éponge de votre fer à souder sous l'eau puis essorez la.L'éponge vous servira à nettoyer la panne/pointe du fer à souder une fois la soudure terminée.
Votre fer à souder atteint sa température opérationnelle après 2 à 5 minutes.Une fois cette température atteinte, saisissez votre composant électronique puis placez-le à l'emplacement de la carte sur laquelle vous souhaitez le souder.Insérez ce dernier jusqu'à ce qu'il touche la carte, comme indiqué sur les photos 2, 3 et 4 de cette étape.Certains composants tels que les condensateurs ou diodes sont polarisés et nécessitent d'être placés dans un sens particulier. Référez-vous à la notice de montage de votre matériel si vous disposez de cette derniere.Si il s'agit d'un remplacement de composant, pensez à mémoriser sa position et sa polarité avant de le retirer/déssouder.
Placez la carte électronique à l'envers puis saisissez les deux pattes du composant que vous souhaitez souder.Puis, écartez ces pattes de la même manière que sur les photos 1 et 2 de cette étape.
Votre fer à souder atteint sa température opérationnelle après 2 à 5 minutes.Une fois cette température opérationnelle atteinte, saisissez le fer puis procédez à un nettoyage de la panne (c'est-à-dire l'élément le plus pointu du fer).Pour cela, faites glisser la panne en la frottant d'avant en arrière sur l'éponge mouillée, comme indiqué sur les photos de cette étape.Nous vous conseillons de réaliser ce nettoyage après chaque soudure afin de prolonger la durée de vie de la panne de votre fer à souder.
Positionnez ensuite la carte sur le support troisième main.Saisissez, à présent, le fer à souder ainsi que le fil d'étain.Placez dans un premier temps le fil d'étain sur la première patte à souder du composant puis placez ensuite la pointe du fer à souder dessus durant une à deux secondes maximum.Répétez cette opération pour chaque patte du composant à souder.Un dégagement de fumée blanche peut se produire, ceci est tout à fait normal.Une soudure propre ne doit pas avoir la forme d'une grosse boule et ne doit pas être en contact avec d'autres pattes (court-circuit)Il est conseillé, au possible, de ne pas respirer la fumée dégagée lors de la soudure.
Utilisez ensuite la pince coupante afin de sectionner la première patte du composant que vous venez de souder.Répétez cette opération pour chaque patte du composant que vous avez soudé.
Votre composant est désormais soudé.Répétez ce guide pour les autres composants à souder sur votre carte si cela est nécessaire.
Pour remonter votre Compétences électroniques suivez ce guide en sens inverse.
