Galaxy A72 Galaxy A71 Galaxy A70 Galaxy A60 Galaxy A56 5G Galaxy A55 5G Galaxy A54 Galaxy A53 5G Galaxy A52s 5G Galaxy A52 Galaxy A51 5G Galaxy A51Galaxy A50s Galaxy A50 Galaxy A42 Galaxy A41 Galaxy A40s Galaxy A40 Galaxy A36 5G Galaxy A35 5G Galaxy A34 Galaxy A33 5G Galaxy A33 Galaxy A32 5G Galaxy A32Galaxy A31 Galaxy A30s Galaxy A30 Galaxy A26 5G Galaxy A25 5G Galaxy A24 4G Galaxy A23 5G Galaxy A23 Galaxy A22 5G Galaxy A22 Galaxy A21s Galaxy A21Galaxy A20s Galaxy A20e Galaxy A20 Galaxy A17 Galaxy A17 4G Galaxy A16 5G Galaxy A16 Galaxy A15 Galaxy A14 5G Galaxy A14 Galaxy A13 5G Galaxy A13 Galaxy A12Galaxy J8 Galaxy J7+ Galaxy J7 Pro Galaxy J7 Prime Galaxy J7 Max Galaxy J7 Core Galaxy J7 (2018) Galaxy J7 (2017) Galaxy J7 (2016) Galaxy J7 Galaxy J6+ Galaxy J6 (2018)Galaxy S25 FE Galaxy S25 Ultra Galaxy S25+ Galaxy S25 Galaxy S24 FE Galaxy S24 Ultra Galaxy S24+ Galaxy S24 Galaxy S23 FE Galaxy S23 Ultra Galaxy S23+ Galaxy S23Galaxy S22 Ultra Galaxy S22+ Galaxy S22 Galaxy S21 FE Galaxy S21+ Galaxy S21 Ultra Galaxy S21 Galaxy S20+ Galaxy S20 Ultra Galaxy S20 FE 5G Galaxy S20 FE Galaxy S20Galaxy S10e Galaxy S10+ Galaxy S10 Lite Galaxy S10 5G Galaxy S10 Galaxy S9+ Galaxy S9 Galaxy S8+ Galaxy S8 Active Galaxy S8Galaxy Ace 1 Galaxy Ace 2 Galaxy Ace 3 Galaxy Ace 4 Galaxy Ace 4 Lite Galaxy Ace Duos Galaxy Ace Style Galaxy AlphaGalaxy C5 Galaxy C5 Pro Galaxy C5000 Galaxy C7 Galaxy C7 Prime Galaxy C7 Pro Galaxy C8 Galaxy C9 Galaxy C9 Pro Galaxy Core 2 Galaxy Core LTE Galaxy Core Prime Galaxy Core Prime VEGalaxy Gio S5660 Galaxy Grand 2 Galaxy Grand Max Galaxy Grand Neo Galaxy Grand Plus Galaxy Grand Prime Galaxy Grand Prime +Série 11 et plus
Zenfone 9 Zenfone 6 Zenfone 5 Zenfone 4 Selfie Pro Zenfone 4 Zenfone 3 Ultra Zenfone 3 Max Zenfone 3 Deluxe Zenfone 3 Zenfone 2 Laser Zenfone 2Motorola Edge série 50 Motorola Edge série 40 Motorola Edge série 30 Motorola Edge série 20 Motorola Razr 50 Ultra Motorola Razr 50 Série Moto G8 -
Guides pour Huawei Honor 5X
Vous avez besoin d’aide pour votre réparation Honor 5X ? Vous pouvez compter sur les experts de SOSav avec ces nombreux guides de réparation Honor 5X. Nous savons que les accidents arrivent et que certains composants peuvent s’user au fil du temps. C’est pourquoi nous vous proposons des tutos qui vous permettront de lutter contre cette obsolescence programmée. Il vous suffit d’opter pour le tuto qui correspond à votre panne pour savoir comment se déroule la réparation Honor 5X en détail. Réalisés par nos techniciens, ces guides sont illustrés et commentés. Toutes les étapes retracent de A à Z les manoeuvres à effectuer pour changer un écran cassé, une batterie usagée, etc. En cas de doute, toute notre équipe technique se tient prête à répondre à vos questions.
0 réparation pour Huawei Honor 5X
Réparation Huawei Honor 5X
N’attendez plus pour vous lancer dans la réparation Honor 5X ! Non, ce n’est pas réservé à l’élite des professionnels ! C’est un mythe que nous souhaitons déconstruire et c’est pour cela que nous partageons avec vous toute notre expérience. Nous souhaitons prouver que réparer son Honor 5X est possible sans connaissances techniques poussées. Il suffit de prendre son temps et de suivre les conseils de nos techniciens. Vous verrez toutes les économies par rapport à l’intervention d’un pro ! Réparer son Honor 5X tout seul, c’est profiter d’un tarif jusqu’à trois fois moins élevé que passer par un spécialiste. Et n’en parlons même pas par rapport à l’achat d’un nouveau smartphone. Et puis vous limitez aussi votre impact CO2 en ne changeant pas téléphone au moindre bobo.
Réparer son Honor 5X n’est donc pas si compliqué. Mais nous vous conseillons, comme avant chaque réparation smartphone, d’effectuer une sauvegarde complète de vos données par précaution. Il est d’ailleurs recommandé de faire des sauvegardes régulières en cas de problème. Une fois votre sauvegarde faite, vous pouvez attaquer votre réparation Honor 5X ! Il faut d’abord retirer la coque arrière et dévisser pas mal de vis pour extraire la batterie. Pour l’écran, il faudra être encore plus patient.
Présentation Huawei Honor 5X
Sorti début 2016, le Honor 5X est un smartphone milieu de gamme produit par le fabricant Chinois Huawei. Il succède au modèle 4X du même fabricant sorti 1 an plus tôt. Ce nouveau smartphone de la gamme "Honor" fait évoluer de manière sensible sa fiche technique sur certains points : Le 5X dispose en effet d'un écran IPS Full HD de 5,5 pouces, une puce Qualcomm Snapdragon 616 composée de huit cœurs Cortex-A53 cadencés à 1,5 GHz, de 2 Go de mémoire vive, une puce graphique Adreno 405, un capteur photo principal de 13 Mpx capable de filmer en Full HD (30 i/s), un autre frontal de 5 Mpx, 16 Go de stockage interne (+ extension par carte microSD), une fonction double SIM, une compatibilité avec la 4G, le Wi-Fi b/g/n, du A-GPS. Le Honor 5X est dépourvu et ne possède pas de capacités NFC.
Côté réparation Honor 5X, rien de nouveau. Tout se passe par la coque arrière qui doit être retirée avant de pouvoir accéder à l’ensemble des composants. Un démontage qui rappelle la plupart des modèles de Huawei et qui ne dépaysera pas les habitués de la marque. Le Honor 5X est un peu plus long à démonter mais est relativement modulable.
Identification Huawei Honor 5X
La manière la plus simple d'identifier un Honor 5X est de noter le numéro de modèle présent sur la coque arrière. Ce dernier doit porter le numéro de modèle KIW-L21.
S'il vous est impossible de relever ce numéro de modèle, vous pouvez cependant le distinguer grâce à certains points :
- Surface arrière en aluminium
- Les boutons d'ajustement du volume se situent à droite sur la tranche du téléphone
- Présence d'un capteur d'empreinte au dos du téléphone
- Le téléphone possède un double emplacement pour carte SIM
Si vous avez des doutes, n’hésitez pas à nous contacter pour que nous puissions vous aider dans votre identification Honor 5X. C’est une étape cruciale pour suivre le bon guide de réparation et ne pas commettre d’erreur.
