Galaxy A72 Galaxy A71 Galaxy A70 Galaxy A60 Galaxy A56 5G Galaxy A55 5G Galaxy A54 Galaxy A53 5G Galaxy A52s 5G Galaxy A52 Galaxy A51 5G Galaxy A51Galaxy A50s Galaxy A50 Galaxy A42 Galaxy A41 Galaxy A40s Galaxy A40 Galaxy A36 5G Galaxy A35 5G Galaxy A34 Galaxy A33 5G Galaxy A33 Galaxy A32 5G Galaxy A32Galaxy A31 Galaxy A30s Galaxy A30 Galaxy A26 5G Galaxy A25 5G Galaxy A24 4G Galaxy A23 5G Galaxy A23 Galaxy A22 5G Galaxy A22 Galaxy A21s Galaxy A21Galaxy A20s Galaxy A20e Galaxy A20 Galaxy A17 Galaxy A17 4G Galaxy A16 5G Galaxy A16 Galaxy A15 Galaxy A14 5G Galaxy A14 Galaxy A13 5G Galaxy A13 Galaxy A12Galaxy J8 Galaxy J7+ Galaxy J7 Pro Galaxy J7 Prime Galaxy J7 Max Galaxy J7 Core Galaxy J7 (2018) Galaxy J7 (2017) Galaxy J7 (2016) Galaxy J7 Galaxy J6+ Galaxy J6 (2018)Galaxy S25 FE Galaxy S25 Ultra Galaxy S25+ Galaxy S25 Galaxy S24 FE Galaxy S24 Ultra Galaxy S24+ Galaxy S24 Galaxy S23 FE Galaxy S23 Ultra Galaxy S23+ Galaxy S23Galaxy S22 Ultra Galaxy S22+ Galaxy S22 Galaxy S21 FE Galaxy S21+ Galaxy S21 Ultra Galaxy S21 Galaxy S20+ Galaxy S20 Ultra Galaxy S20 FE 5G Galaxy S20 FE Galaxy S20Galaxy S10e Galaxy S10+ Galaxy S10 Lite Galaxy S10 5G Galaxy S10 Galaxy S9+ Galaxy S9 Galaxy S8+ Galaxy S8 Active Galaxy S8Galaxy Ace 1 Galaxy Ace 2 Galaxy Ace 3 Galaxy Ace 4 Galaxy Ace 4 Lite Galaxy Ace Duos Galaxy Ace Style Galaxy AlphaGalaxy C5 Galaxy C5 Pro Galaxy C5000 Galaxy C7 Galaxy C7 Prime Galaxy C7 Pro Galaxy C8 Galaxy C9 Galaxy C9 Pro Galaxy Core 2 Galaxy Core LTE Galaxy Core Prime Galaxy Core Prime VEGalaxy Gio S5660 Galaxy Grand 2 Galaxy Grand Max Galaxy Grand Neo Galaxy Grand Plus Galaxy Grand Prime Galaxy Grand Prime +Série 11 et plus
Zenfone 9 Zenfone 6 Zenfone 5 Zenfone 4 Selfie Pro Zenfone 4 Zenfone 3 Ultra Zenfone 3 Max Zenfone 3 Deluxe Zenfone 3 Zenfone 2 Laser Zenfone 2Motorola Edge série 50 Motorola Edge série 40 Motorola Edge série 30 Motorola Edge série 20 Motorola Razr 50 Ultra Motorola Razr 50 Série Moto G8 -
Guides pour Huawei Honor 8
Venir ici, c’est déjà le signe que vous avez le bon réflexe : vous lancer dans la réparation Honor 8. Et vous trouverez tous les conseils nécessaires dans ces guides de réparation réalisés par les experts de SOSav. Que ce soit pour changer un écran cassé, une caméra qui ne fonctionne plus ou une batterie un peu trop fatiguée, vous trouverez forcément le tuto qu’il vous faut. En fonction de la panne rencontrée, vous pouvez vous orienter vers le bon guide entièrement gratuit. Nos techniciens partagent tout leur savoir-faire et leur expérience afin de vous expliquer comment remédier aux pannes les plus courantes et retrouver un smartphone comme neuf. Chaque étape est illustrée et commentée pour vous accompagner au mieux tout au long de votre réparation Honor 8. Vous apprendrez ainsi que réparer son Honor 8 n’est pas si difficile et vous fera faire d’importantes économies. Et si vous avez encore des questions, n’hésitez pas à contacter notre service technique pour vous aider !
0 réparation pour Huawei Honor 8
Réparation Huawei Honor 8
Réparer mon Honor 8 ? Sans moi ! Et pourtant… Vous venez de changer d’avis en consultant notre vingtaine de guides. Et vous avez bien raison. Réparer son Honor 8 soi-même n’a que des avantages. Cela vous revient jusqu’à trois fois moins cher que de passer par un professionnel puisque la main d’oeuvre, c’est vous ! Logique. Mais c’est aussi faire un geste écologique puisque vous ne jetez pas votre mobile pour un simple écran cassé. Vous ne tombez donc pas dans le piège de l’obsolescence programmée et limitez votre impact CO2 sur notre planète. Vous restez également maître de votre téléphone tout au long de sa vie, sans dépendre des lenteurs du SAV constructeurs.
Comme vous pouvez le voir dans nos tutos, la réparation Honor 8 commence obligatoirement par le retrait de la vitre arrière qu’il faut minutieusement décoller. Le châssis interne doit ensuite être dévissé pour pouvoir retirer la batterie et accéder aux restes des composants. Une des réparations Honor 8 les plus courantes mais aussi l’une des plus longues est le changement de l’écran. Comme sur la plupart des modèles Huawei, il faut retirer la majorité des composants pour l’isoler. Hormis cela, la réparation Honor 8 ne présente pas de difficultés majeures, alors n’attendez pas pour tenter l’aventure.
Présentation Huawei Honor 8
Le Honor 8 est un smartphone de la marque Huawei. Il succède au modèle Honor 7 sorti précédemment. Le Honor 8 se veut représentatif à sa sortie de la marque Honor (il est considéré à l'époque comme flagship). Ce dernier embarque un processeur 8 cores HiSilicon Kirin 950 et un processeur graphique Mali-T880. La batterie utilisée sur le Honor 8 affiche une capacité de 3000mAH et la capacité du téléphone est proposée en deux versions : 32 ou 64GB.
L'écran du Honor 8 affiche une résolution de 1080x1920 pixels à technologie anti-reflets. La partie photo n'est pas négligée : 12Megapixels (deux caméras) pour l'arrière et 8 Megapixels pour l'avant. Un capteur d'empreinte vient s'ajouter aux fonctionnalités du téléphone, ainsi qu'une led infrarouge et une led d'activité.
La réparation Honor 8 ne requiert pas de connaissances techniques particulières. Tous ceux qui ont déjà démonté un smartphone Huawei ne seront pas dépaysés. Il est nécessaire de décoller minutieusement la vitre arrière et de déconnecter le capteur d’empreinte pour accéder sereinement aux entrailles de la bête. Le changement de batterie est ensuite assez rapide tandis que remplacer son écran prendra plus de temps. Comme pour tous les autres modèles, il faudra passer par un démontage complet de la plupart des éléments afin de pouvoir isoler l’écran. Pour réparer son Honor 8, il faut simplement suivre les conseils de nos experts dans nos tutos et faire preuve de patience pour ne pas faire d’erreurs. A vous de jouer !
Identification Huawei Honor 8
L'identification du Huawei Honor 8 peut se réaliser en vous rendant dans le menu "Paramètres" puis "A propos du téléphone".
Dans le cas contraire, certains détails peuvent vous aider à mieux identifier le téléphone :
- Surface arrière intégralement vitrée
- Capteur d'empreinte de forme ronde
- Double capteur photo (deux caméras)
- Présence du logo "Honor" à l'avant du téléphone
En cas de doute, n’hésitez pas à nous solliciter afin de vous aider pour votre identification Honor 8. Il est essentiel de reconnaître son modèle pour se référer au bon tuto de réparation et ne pas faire d’erreur lors du démontage. Bien identifier son Honor 8, c’est aussi pouvoir choisir correctement les bonnes pièces détachées dans la mesure où les composants ne sont pas compatibles, ou très rarement, d’un modèle à l’autre.
